Custom board VSCode plugin and SDK connect v2.2.0
Hello everyone,
I am having a big problem in defining a custom board using the new VSCode plugin.
I tried to follow a few tutorials and videos, but the ones I found are outdated (they refer to Segger and SDK V.1.5) and some of the instructions they
give are not valid anymore. I tried to
- create a completely new board using VSCode, but I got a lot of compilation errors that I do not entirely understand
- create a board by using an existing one (NRF52833_DK) as model, just changing names to the board. This compiles, but then I cannot even see a led blinking. I checked with ozone, and I can control leds, so I don't think there is an issue with the hardware
- started from different examples both from zephyr and nordic (zephyr blinky, nordic peripheral uart), but I got nothing.
Is there any official guide I can follow to solve this issue? My board is a very trivial one, and the baby step I would like to realize is to just blink the onboard leds for now....
Thanks in advance for your help!
Lorenzo
  • Hello, thanks for your reply but yes, I already checked the guide and it is not helping, the device I created like this does not work as it is supposed to.
    In the meanwhile, I tried with a different custom board we used for a few years featuring an nrf52840 (so we can exclude problems on the new hardware design) and I get the same issue: I am not even able to blink an led.
    I read somewhere in the forum that some people are having problems with the pin reset configuration? I added this code
    board_runner_args(nrfjprog "--softreset")
    to the board.cmake file, but once again nothing changes. I checked with Ozone if I can control the LEDs, and this works fine, but the code does not run.
    I feel like I am missing something very basic, but I couldn't figure it out so far.....
    I have inquired internally regarding this and will get back to you as soon as I get a response.
    -Priyanka
    Could you share your build log in order to understand more about the problem?
    thanks for looking into the issue. Please find here the build log. To be on the safe side, I created again the custom board from scratch by following the procedure in the Visual Studio Code plugin; to avoid complexities I only indicated the 3 GPIOs that control the leds in the .dts .
    The behaviour is the same as before: building and flashing go well, but no led blinks. I checked for issues on the Reset pin, but apart from being disabled it has a voltage of 3.3V, so in any case it should not put the board in a weird state.
     *  Executing task: nRF Connect: Build [pristine]: blinky_third/build_1_customboard (active)
    Building blinky_third
    west build --build-dir /Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/build_1_customboard /Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third --pristine --board custom_board -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third" -DCONF_FILE:STRING="/Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/prj.conf"
    -- Application: /Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third
    -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter
    -- Cache files will be written to: /Users/lbe/Library/Caches/zephyr
    -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr)
    -- Board: custom_board
    -- Found host-tools: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/v2.2.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/boards/arm/custom_board/custom_board.dts
    -- Generated zephyr.dts: /Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/build_1_customboard/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/build_1_customboard/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/build_1_customboard/zephyr/dts.cmake
    Parsing /opt/nordic/ncs/v2.2.0/zephyr/Kconfig
    Loaded configuration '/Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/boards/arm/custom_board/custom_board_defconfig'
    Merged configuration '/Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/prj.conf'
    Configuration saved to '/Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/build_1_customboard/zephyr/.config'
    Kconfig header saved to '/Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/build_1_customboard/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/lbe/workspace/Playground/Test_NRF_VSCode/blinky_third/build_1_customboard
    [1/155] Preparing syscall dependency handling
    [2/155] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1
    [3/155] Generating misc/generated/syscalls_subdirs.trigger
    [4/155] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [5/155] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [6/155] Generating include/generated/driver-validation.h
    [7/155] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [8/155] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [9/155] Generating include/generated/offsets.h
    [10/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [11/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [12/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [13/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [14/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [15/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [16/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [17/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [18/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [19/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [20/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [21/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [22/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [23/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [24/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [25/155] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [26/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [27/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [28/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [29/155] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [30/155] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [31/155] Generating linker_zephyr_pre0.cmd
    [32/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [33/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [34/155] Generating linker_zephyr_pre1.cmd
    [35/155] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [36/155] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [37/155] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [38/155] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [39/155] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [40/155] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [41/155] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [42/155] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [43/155] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [44/155] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [45/155] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [46/155] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [47/155] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [48/155] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [49/155] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [50/155] Linking C static library zephyr/arch/common/libisr_tables.a
    [51/155] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [52/155] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [53/155] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [54/155] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [55/155] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [56/155] Linking C static library zephyr/arch/common/libarch__common.a
    [57/155] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [58/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [59/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [60/155] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [61/155] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [62/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [63/155] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [64/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [65/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [66/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [67/155] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [68/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [69/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [70/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [71/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [72/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [73/155] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [74/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [75/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [76/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [77/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [78/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [79/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [80/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [81/155] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [82/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [83/155] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [84/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [85/155] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [86/155] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    [87/155] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf52833.c.obj
    [88/155] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [89/155] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [90/155] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [91/155] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [92/155] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [93/155] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [94/155] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [95/155] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
    [96/155] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [97/155] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [98/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [99/155] Linking C static library zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a
    [100/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [101/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [102/155] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [103/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [104/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [105/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [106/155] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [107/155] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [108/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [109/155] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [110/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [111/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [112/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [113/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [114/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [115/155] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [116/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [117/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [118/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [119/155] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [120/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [121/155] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [122/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [123/155] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [124/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [125/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [126/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [127/155] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    [128/155] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [129/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [130/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [131/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [132/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [133/155] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [134/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [135/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [136/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [137/155] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [138/155] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [139/155] Building C object CMakeFiles/app.dir/src/main.c.obj
    [140/155] Linking C static library zephyr/libzephyr.a
    [141/155] Linking C static library app/libapp.a
    [142/155] Linking C static library zephyr/kernel/libkernel.a
    [143/155] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [144/155] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [145/155] Linking C executable zephyr/zephyr_pre0.elf
    [146/155] Generating dev_handles.c
    [147/155] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [148/155] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [149/155] Linking C executable zephyr/zephyr_pre1.elf
    [150/155] Generating linker.cmd
    [151/155] Generating isr_tables.c, isrList.bin
    [152/155] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [153/155] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [154/155] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [155/155] Linking C executable zephyr/zephyr.elf
               FLASH:       17488 B       512 KB      3.34%
                 RAM:        4288 B       128 KB      3.27%
            IDT_LIST:          0 GB         2 KB      0.00%
