Setting and using NVS and BT Settings with Static Partition Manager
Hi!
We are currently in the process of migrating our nrf5 SDK code to NCS, on nrf52833-based hardware.
After being stuck for a while on the basic init process of MCUBoot, I was finally able to get MCUBoot to run our app (see previous ticket RE: MCUBoot, Zephyr, and static partition manager - Thanks Sigurd for all your help!).
My problem currently is that all the MCUBoot changes, most specifically the Static Partition Manager, have caused our app to consistently fail on boot with the following error:
 "bt_settings: settings_subsys_init failed (err -45)".
Reading up on this, err 45 = EDEADLK (https://docs.zephyrproject.org/apidoc/latest/group__system__errno.html#ga55cc70ce0ba661298f3c412095dfeeb6), which is "Resource deadlock avoided".
Before all the changes leading to MCUBoot + PM, I had been able to init and use the NVS without issues, as well as the BT settings init.
Pre-MCUBoot and PM, I had defined our flash like so (in overlay):
/delete-node/ &storage_partition;
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		settings_partition: partition@77000 {
			label = "settings";
			reg = <0x00077000 0x00002000>;
        storage_partition: partition@79000 {
			label = "storage";
			reg = <0x00079000 0x00007000>;
With chosen as follows (same overlay file):
    chosen {
        zephyr,settings-partition = &settings_partition;
And our NVS init code is as follows:
#define NVS_PARTITION		storage_partition
#define NVS_PARTITION_DEVICE	FIXED_PARTITION_DEVICE(NVS_PARTITION)
#define NVS_PARTITION_OFFSET	FIXED_PARTITION_OFFSET(NVS_PARTITION)
static struct nvs_fs fs;
void flash_manager_init()
    int rc=0;
	struct flash_pages_info info;
	/* define the nvs file system by settings with:
	 *	sector_size equal to the pagesize,
	 *	3 sectors
	 *	starting at NVS_PARTITION_OFFSET
	fs.flash_device = NVS_PARTITION_DEVICE;
	if (!device_is_ready(fs.flash_device)) {
		printk("Flash device %s is not ready\n", fs.flash_device->name);
		return;
	fs.offset = NVS_PARTITION_OFFSET;
	rc = flash_get_page_info_by_offs(fs.flash_device, fs.offset, &info);
	if (rc) {
		printk("Unable to get page info\n");
		return;
	fs.sector_size = info.size;
	fs.sector_count = 4U;
	rc = nvs_mount(&fs);
	if (rc) {
		printk("Flash Init failed\n");
		return;
Our new pm_static.yml file is:
app:
  address: 0x9200
  end_address: 0x40000
  region: flash_primary
mcuboot:
  address: 0x0
  end_address: 0x9000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x9000
  end_address: 0x9200
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x9000
  orig_span: &id001
  - mcuboot_pad
  - app
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x9200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x40000
  end_address: 0x77000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
settings_partition:
  address: 0x77000
  end_address: 0x79000
  placement:
    align:
      start: 0x1000
storage_partition:
  address: 0x79000
  end_address: 0x80000
  placement:
    align:
      start: 0x1000
sram_primary:
  address: 0x20000000
  end_address: 0x20020000
  region: sram_primary
I have tried to change the number of sectors to 7 to match the 7 sectors for storage_partition in the pm_static.yml, to no avail (same -45 error).
My questions are as follows:
  • How do I go about replacing the "zephyr,settings-partition = &settings_partition;" once I remove the flash0 override from our overlay file?
  • How do I go about pointing from my code (like the existing NVS_PARTITION define) to the PM partitions for nvs init, if possible?
  • If not possible - how do I go about initing and using nvs?
Thanks!
Roi
  • Do you NEED a multi-image build to setup a custom isolated NVS? I think I am facing a situation where BLE is overwriting an NVS that I setup as in the Zephyr NVS example just using the storage_partition, but up until this point I haven't actually had to setup a multi-image build.
    The tutorial you link unfortunately really doesn't explain well how to enable and configure NVS with the Partition Manager for the first time, more just goes over what it is and why Nordic use it and has a vague go at explaining where to look. Can you recommend any other resource, also happy to make a thread if that's a better idea.
  • I've managed it now, just needed to add CONFIG_BOOTLOADER_MCUBOOT=y, and add that pm_static.yml to my application directory.
    I will say though I did have weird issues whereby I had to delete my original build config and create it again before it would recognize the new partition without error.
  • Good job fixing this!
    Yep, you sometimes have to delete the build folder.
    Multi-Image build != partition manager.
    But pm_static.yml is only for the partition manager,
    However, you can use DTS partitioning instead if you want.
    That being said, if you want to use MCUboot, which you probably will, then the partition manager and multi image build will be automatically enabled.
    (In v2.7.0 sysbuild becomes an alternative for multi image build)
  • I have the same problem now as described in this thread. the peripheral_hr_settings_nvs_mcuboot does not compile any more. i use 2.6.1 sdk. what needs to be changed?
  • Hi p1ng,
    I cannot update the sample uploaded here for every nRF Connect SDK version.
    The method for fixing the issue should still be the same though, so it will be up to you to learn how the sample works, and then implement the same fix in your applicaiton.
    Sigurd Hellesvik
