Setting and using NVS and BT Settings with Static Partition Manager
Hi!
We are currently in the process of migrating our nrf5 SDK code to NCS, on nrf52833-based hardware.
After being stuck for a while on the basic init process of MCUBoot, I was finally able to get MCUBoot to run our app (see previous ticket RE: MCUBoot, Zephyr, and static partition manager - Thanks Sigurd for all your help!).
My problem currently is that all the MCUBoot changes, most specifically the Static Partition Manager, have caused our app to consistently fail on boot with the following error:
 "bt_settings: settings_subsys_init failed (err -45)".
Reading up on this, err 45 = EDEADLK (https://docs.zephyrproject.org/apidoc/latest/group__system__errno.html#ga55cc70ce0ba661298f3c412095dfeeb6), which is "Resource deadlock avoided".
Before all the changes leading to MCUBoot + PM, I had been able to init and use the NVS without issues, as well as the BT settings init.
Pre-MCUBoot and PM, I had defined our flash like so (in overlay):
/delete-node/ &storage_partition;
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		settings_partition: partition@77000 {
			label = "settings";
			reg = <0x00077000 0x00002000>;
        storage_partition: partition@79000 {
			label = "storage";
			reg = <0x00079000 0x00007000>;
With chosen as follows (same overlay file):
    chosen {
        zephyr,settings-partition = &settings_partition;
And our NVS init code is as follows:
#define NVS_PARTITION		storage_partition
#define NVS_PARTITION_DEVICE	FIXED_PARTITION_DEVICE(NVS_PARTITION)
#define NVS_PARTITION_OFFSET	FIXED_PARTITION_OFFSET(NVS_PARTITION)
static struct nvs_fs fs;
void flash_manager_init()
    int rc=0;
	struct flash_pages_info info;
	/* define the nvs file system by settings with:
	 *	sector_size equal to the pagesize,
	 *	3 sectors
	 *	starting at NVS_PARTITION_OFFSET
	fs.flash_device = NVS_PARTITION_DEVICE;
	if (!device_is_ready(fs.flash_device)) {
		printk("Flash device %s is not ready\n", fs.flash_device->name);
		return;
	fs.offset = NVS_PARTITION_OFFSET;
	rc = flash_get_page_info_by_offs(fs.flash_device, fs.offset, &info);
	if (rc) {
		printk("Unable to get page info\n");
		return;
	fs.sector_size = info.size;
	fs.sector_count = 4U;
	rc = nvs_mount(&fs);
	if (rc) {
		printk("Flash Init failed\n");
		return;
Our new pm_static.yml file is:
app:
  address: 0x9200
  end_address: 0x40000
  region: flash_primary
mcuboot:
  address: 0x0
  end_address: 0x9000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x9000
  end_address: 0x9200
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x9000
  orig_span: &id001
  - mcuboot_pad
  - app
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x9200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x40000
  end_address: 0x77000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
settings_partition:
  address: 0x77000
  end_address: 0x79000
  placement:
    align:
      start: 0x1000
storage_partition:
  address: 0x79000
  end_address: 0x80000
  placement:
    align:
      start: 0x1000
sram_primary:
  address: 0x20000000
  end_address: 0x20020000
  region: sram_primary
I have tried to change the number of sectors to 7 to match the 7 sectors for storage_partition in the pm_static.yml, to no avail (same -45 error).
My questions are as follows:
  • How do I go about replacing the "zephyr,settings-partition = &settings_partition;" once I remove the flash0 override from our overlay file?
  • How do I go about pointing from my code (like the existing NVS_PARTITION define) to the PM partitions for nvs init, if possible?
  • If not possible - how do I go about initing and using nvs?
Thanks!
Roi
  • I tried setting the partion name to custom_nvs_storage in pm_static.yml in my project but still cant access the custom_nvs_storage variable in c++ code. Trying out IvanV solution now by getting address and device variables from build\zephyr\include\generated\pm_config.h this looks promising
    I think this should be able to work.
    I suggest that you create a new ticket asking for help with this. (And referencing this ticket in there).
    If that works for you, you are of course free to do so as well.
  • yeah i think ill go with IvanVs  solution cause creating the ticket would take too much of my time atm because i would have to create a small project where there is only mcuboot and nvs stuff just to make sure anything in my big project isnt causing the issue.
  • turns out IvanVs thing didnt work for me either. What worked for my project was to add  #include <pm_config.h> to code. thats the file hwere all those generated defines are. and u dont need to name it custom_nvs_storage, u can name it anything u want. before i came to this solution i had created a sample project out of nordic academys intermediate course lesson8 exercise2 - just only added pm_static.yml to the project and chosen block to overlays i think - in that project i didnt need to add that include. i wasnt getting the build error though so i suppose something in the conf already made build include that header file at the right time but i wasnt able to figure out what. that what was missing from my big project.
  • Hi p1ng,
    It is too bad that did not work.
    If you want help getting this fixed, I recommend that you create a new ticket.
