Questions about testing the coap_client and coap_server demo while using openthread network
        I Use the nRF52840DK and nRF21540DK to test the coap_client and coap_server demo ,SDK is ncs-2.2.0 ,IDE is VS Code .
        1. I want to extend the communication distance, so I use the nRF21540DK ,when compile the program ,the board which I selected is nrf21540dk_nrf52840 ,when finished compile ,I check the .config file in build/zephyr folder. and the config item was all add ,so I think my operation is OK.
# CONFIG_MPSL_FEM_ONLY is not set
CONFIG_MPSL_FEM_ANY_SUPPORT=y
CONFIG_MPSL_FEM_NRF21540_GPIO_SUPPORT=y
CONFIG_MPSL_FEM_NRF21540_GPIO_SPI_SUPPORT=y
CONFIG_MPSL_FEM_NCS_SUPPORTED_FEM_USED=y
CONFIG_MPSL_FEM_API_AVAILABLE=y
CONFIG_MPSL_FEM=y
CONFIG_MPSL_FEM_NRF21540_GPIO=y
# CONFIG_MPSL_FEM_NRF21540_GPIO_SPI is not set
CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB=10
CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB_POUTA=20
CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB_POUTB=10
CONFIG_MPSL_FEM_NRF21540_RX_GAIN_DB=13
# CONFIG_MPSL_FEM_NRF21540_RUNTIME_PA_GAIN_CONTROL is not set
# CONFIG_MPSL_FEM_POWER_MODEL is not set
CONFIG_MPSL_FEM_DEVICE_CONFIG_254=y
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
CONFIG_MPSL_FEM_LOG_LEVEL_DBG=y
CONFIG_MPSL_FEM_LOG_LEVEL=4
CONFIG_MPSL_THREAD_COOP_PRIO=0
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_LOG_LEVEL_INF is not set
CONFIG_MPSL_LOG_LEVEL_DBG=y
CONFIG_MPSL_LOG_LEVEL=4
        To see the difference in transmission power ,I Use the nrf802154_sniffer and Wireshark to capture the packets of nRF52840DK and nRF21540DK ,I found the RSS display on Wireshark no difference ,the captured RSS are all -18dbm.
        I tried to modify the tx power in conf as below ,but the captured RSS as the same .
CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB=20
        My question is that why captured RSS is the same ?
        I found thers is no log in nRF21540 module , What should I do to verify that nRF21540 really works ?
        2、When I captured the CoAP packets ,I found unique send Only send packet once ,but mesh multicast send will send packet four times , Wireshark show that three times are Retransmission ,in the four times transmission ,some transmission's RSS is -18dbm ,and some is -65dbm .as below .
        My question is that the feature of four transmissions while multicast ,Does this feature belong to the coap protocol or the thread protocol or developed in user application ?
        Why the RSS of four transmission is not the same ?
        Best Regards,
        Hyman
