how can i get the number BLE TX re transmissions
hello Nordic
i am working with nrf52832 and nrf52840 socs, with ncs v2.1.0
i would like to know how many of the BLE packets i am sending has to be resent (and if it is possible to know the reason of resent, in case there is another reason beside packet missed some bytes/bits on the OTA way, that would be great as well )
any idea how can i get that info ?
also another question, if i move (with BLE 4.2 and above) to extended length packets, to increase throughput, should there be more resent packets since the risk of loosing data in a larger packet is greater ?
hope to read you soon
best regards
Ziv
  • ok, if i am correct then the issue is this config  ' CONFIG_BT_LL_SW_SPLIT '
    which according to https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/connectivity/bluetooth/bluetooth-arch.html#bluetooth-build-types
    means i am working with the zephyr BLE stack and not with the nrf connect SDK's softdevice.
    please correct me if i am wrong
    and if i understand correct then zephyr BLE LL des not support the connection event report, again, correct me if i am wrong
    so..
    1. is there an API to get BLE re transmissions count, while using zephyr BLE LL
    2. is there a build that enables work with both, if it is even possible to have 2 ble stacks work together, or is ti just enabling use of nordic libraries ?
    3. if not, how complex should it be to migrate to work with the Nordic softdevice, is there some guide on the topic ?
    p.s. regarding low latency, according to the table of Proprietary feature support in here https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfxlib/softdevice_controller/README.html#softdevice-controller
     is it not dependent on the other side of the BLE connection, central/peripheral's ability to support that ?
    best regards
    Ziv
    Correct. The QoS Connection Event Report is a feature of the SoftDevice/MPSL stack.
    I'm not aware of any API for this for the Zephyr Controller.
    You can only have 1 stack enabled.
    Set CONFIG_BT_LL_SW_SPLIT=n
    To use the Low Latency Packet mode, you need to use nRF52 with LLPM support on both sides of the link.
    this much i know,  but the the whole API used on our BLE comm module will have to change now
    and my question is is there some API correlation doc to switch to softdevice controller from zephyr controller ?
    - what modules are used in softdevice that correlate and if i try to deep dive into my current zephyr controller APIs until i get to an NCS ones, could i just use them directly ? (not sure you can answer that but i am trying Slight smile )
     - where can i find some comparison between the 2 BLE stacks cause changing the BLE stacks may change much more things in the connection and throughput etc.
    also i need to know if by moving to softdevice controller i am loosing some zephyr's controller features ?
    and lastly is it actually preferable to move to softdevice controller from currently implemented zephyr controller assuming we are going to keep on working with nrf52832 and nrf52840 for a list few more years ? what are the pros and cons of that transition ?
    best regards
    Ziv
    I don't see why, Both the SoftDevice Controller and the Zephyr Controller, uses the Zephyr Bluetooth Host, and the Zephyr Bluetooth Host API can be used by both controllers.
    I'm not aware of any features you might lose. Is there anything you have in mind ?
    The SoftDevice Controller is the recommended controller. It's what we test and qualify.
  • I don't see why, Both the SoftDevice Controller and the Zephyr Controller, uses the Zephyr Bluetooth Host, and the Zephyr Bluetooth Host API can be used by both controllers.
    if i change to =n (only that change) then i get:
    ASSERTION FAIL [((((prio)) == 10 && z_is_idle_thread_entry((entry))) || (((10 - 1) >= ((-5))) && ((prio)) >= ((-5)) && ((prio)) <= (10 - 1)))] @ WEST_TOPDIR/zephyr/kernel/thread.c:536
    00>
    00>   invalid priority (10); allowed range: 9 to -5
    00>
    00> [00000001] <err> os: ***** USAGE FAULT *****
    00> [00000001] <err> os:   Attempt to execute undefined instruction
    00> [00000001] <err> os: r0/a1:  0x00008001  r1/a2:  0x20022b40  r2/a3:  0x0004ae97
    00> [00000001] <err> os: r3/a4:  0x20026c30 r12/ip:  0x00000000 r14/lr:  0x0003ed4b
    00> [00000001] <err> os:  xpsr:  0x61000000
    00> [00000001] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    00> [00000001] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    00> [00000001] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    00> [00000001] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
    00> [00000001] <err> os: fpscr:  0x00000000
    00> [00000001] <err> os: r4/v1:  0x200055c8  r5/v2:  0x00000388  r6/v3:  0x00000000
    00> [00000001] <err> os: r7/v4:  0x20022b50  r8/v5:  0x0003ca55  r9/v6:  0x0000000a
    00> [00000001] <err> os: r10/v7: 0x00000000  r11/v8: 0x00000000    psp:  0x20022ad8
    00> [00000001] <err> os: EXC_RETURN: 0xffffffed
    00> [00000001] <err> os: Faulting instruction address (r15/pc): 0x0003ed4a
    00> *** Booting Zephyr OS build v3.1.99-ncs1  ***
    00> I: Reset Reason, RESETREAS=0x4
    00> I: Reset Causes:
    00> I:  Software
    00> I: GNU Build ID: 80e5e918576521287483c25ad58831d4437782b8
    in my init flow
    any idea why this is ?
    maybe it has something to do with me working with pm_static and maybe the softdevice needs to be given some defined specific place ?
    best regards
    Ziv
