WDT & Bootloader: Multiple definitions of `WDT_IRQHandler'
So I'm trying top add a bootloader+DFU to allow f/w updates via UART on my custom  board.
I'm already successfully using WDT in my app. Now I'm looking down the rabbithole of trying to integrate code from docs and/or examples into my own...
Using the example secure_bootloader_uart as my template for DFU, I've added the nRF-Bootloader files & updated the user include directories. But it seems that the bootloader WDT is duplicating driver WDT
nrf_bootloader_wdt.o: In function `WDT_IRQHandler':
nrf_bootloader_wdt.c:73: multiple definition of `WDT_IRQHandler'
\modules\nrfx\drivers\src/nrfx_wdt.c:61: first defined here
I'm not even sure if I need WDT support? Because my custom board has no buttons or LEDs I'll be using sd_power_gpregret_set() followed by a NVIC_SystemReset() - won't that clear the WDT anyway?
  • Hi Hung
    I think we've got out of sync in this thread Slight smile
    So, let me just reset...
    My main application is built using S112. It's working, and I do not want to change it.
    The example bootloaders provided for 10040 are only written for S132. so I need to change the bootloader not the application (as per your suggestion earlier when I was using 10040e example) to use with my application/softdevice.
    I've rebuilt the secure bootloader changing the softdevice prefix, include folders etc according to your advice, it boots fine and the DFU actually transfers now, but the system crashes afterwards. So obviously the new image is being loaded incorrectly.
    So I'm still at the stage where I need to tweak the bootloader to work with the application+S112 which I assume is defining flash addresses.
    Hope this makes sense!
    Regards
    Nick
  • Hi Nick,
    Sorry it's my mistake. I was thinking about the application address that you don't need to modify on the bootloader. The only thing you need to modify is to change from using S132 header to S112 header. In particular you need to change these to s112:
    And change this to S112:
    I noticed that you set the FLASH_START address to 0x19000. It's not correct, keep all of them as they are:
    If you still have issue, please give us more info on how it crashed and have you checked if it crashed in the bootloader or in the application.
  • Hi Hung
    Happy to say it works now! I can perform DFU over BLE on both NRF52DK and my custom board. All I need to do now is add UART transport but I'm hoping that should be a relatively simple task now I have a working platform...
    Thanks for your help and patience - I admit this one has dragged on a bit!
    Nick
  • Hi Nick,
    I'm glad that it's working now. It should be straight forward to add UART transport. As far as I remember it's suggested to initialize UART before BLE . You can have a look at this case.
