I want to communicate with MAX30003 ECG chip with my nRF52840 board.
I am able to read MAX30003 register values but I cannot write new values to the registers.
Not some specific register but all of them. So I must have done something wrong here...
For example when try to read the INFO register (address 0x0F) of the MAX30003 I get the correct value (chip ID) as I expect which is 0x5131C0 .
Then when I try to enable the ECG_EN bit of the CNFG_GEN register (with address 0x10), I send through SPI the following value:
0x080004( where 08 corresponds to the bit ECG_EN that I want to enable).
When I read back the value of this register I get the initial value (0x00000004) , before I changed it.
This happens with all registers...
here is what I get in the debugger
Here is my code for the spi
void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context)
switch(p_event->type){
case NRF_DRV_SPI_EVENT_DONE:
spi_xfer_done = true;
NULL;
// SPI Initialization
void spi_init(void){
nrf_delay_ms(100);
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = SPI_CS_PN; // NRF_DRV_SPI_PIN_NOT_USED;
spi_config.miso_pin = SPI_MISO_PN;
spi_config.mosi_pin = SPI_MOSI_PN;
spi_config.sck_pin = SPI_SCK_PN;
spi_config.frequency = NRF_SPI_FREQ_250K;
spi_config.bit_order = NRF_SPI_BIT_ORDER_MSB_FIRST;
//spi_config.orc = 0xEE;
spi_config.mode = NRF_SPI_MODE_0;
APP_ERROR_CHECK(nrf_drv_spi_init(&m_spi, &spi_config, spi_event_handler, NULL));
here are the pin settings
//------SPI------ #define SPI_MOSI_PN NRF_GPIO_PIN_MAP(0,20) #define SPI_SCK_PN NRF_GPIO_PIN_MAP(0,13) #define SPI_CS_PN NRF_GPIO_PIN_MAP(0,24) #define SPI_MISO_PN NRF_GPIO_PIN_MAP(0,22)
here are the functions for writing/reading to/from the MAX30003
// SPI read data. Function returns a register's value in uint32_t form. It also saves the value in ECG_arrayRCV[]
uint32_t ECG_RD_reg(uint8_t reg){
uint32_t reg_data = 0;
uint8_t array_len = 4;
spi_xfer_done = false;
ECG_arrayTRF[0] = ((reg << 1) | SPI_RREG ); // prepare data for reception (register to be read + read bit)
ECG_arrayTRF[1] = 0;
ECG_arrayTRF[2] = 0;
ECG_arrayTRF[3] = 0;
NRF_LOG_INFO( "Send register Address + Read: 0x%02X%02X%02X%02X", ECG_arrayTRF[0], ECG_arrayTRF[1] ,ECG_arrayTRF[2] ,ECG_arrayTRF[3]);
//err_code = nrf_drv_spi_transfer(&m_spi, array_tr, array_len, array_rcv, array_len);
err_code = nrf_drv_spi_transfer(&m_spi, ECG_arrayTRF, array_len, ECG_arrayRCV, array_len);
while(spi_xfer_done == false);
NRF_LOG_INFO( "Register Returns: 0x%02X%02X%02X%02X", ECG_arrayRCV[0], ECG_arrayRCV[1] ,ECG_arrayRCV[2] ,ECG_arrayRCV[3]);
reg_data |= (uint32_t) (ECG_arrayRCV[0] << 24); // build a uint32_t from the arrayRCV
reg_data |= (uint32_t) (ECG_arrayRCV[1] << 16); // ByteH is here, since MSB comes out first from the MAX30003 FIFO
reg_data |= (uint32_t) (ECG_arrayRCV[2] << 8); // ByteM
reg_data |= (uint32_t) (ECG_arrayRCV[3] << 0); // ByteL
return reg_data;
// SPI send data
void ECG_WR_reg(uint8_t reg, uint32_t data){
uint8_t array_dum[4] = {0};
ECG_arrayTRF[0] = ((reg << 1) & SPI_WREG); // register to be written + write bit
ECG_arrayTRF[1] = (uint8_t)((data & 0x00FF0000) >> 16);
ECG_arrayTRF[2] = (uint8_t)((data & 0x0000FF00) >> 8);
ECG_arrayTRF[3] = (uint8_t)((data & 0x000000FF) >> 0);
NRF_LOG_INFO( "Send reg address + Write: 0x%02X%02X%02X%02X", ECG_arrayTRF[0], ECG_arrayTRF[1] ,ECG_arrayTRF[2] ,ECG_arrayTRF[3]);
err_code = nrf_drv_spi_transfer(&m_spi, ECG_arrayTRF, 4, ECG_arrayRCV, 4);
and here is my main()
uint32_t res = 0;
NRF_LOG_INFO("HELLO");
spi_init(); // Initialize SPI
NRF_LOG_INFO("ECG_INFO: 0x%08X", ECG_RD_reg(ECG_INFO));
res = 0x080004;
ECG_WR_reg(ECG_CNFG_GEN, res); // Enable [ECG channel, DC Lead-Off Detect, Resistive Bias on Pos/Neg EI], R_bias = 100MU
nrf_delay_ms(100);
NRF_LOG_INFO("ECG_CNFG_GEN --> What I get: 0x%06X --- What I want: 0x%06X", ECG_RD_reg(ECG_CNFG_GEN), res);
Any ideas what I am doing wrong?
Thank you!
