GPIOTE internal pull-up does not work on GPIO1.x
Hello.
I tried to implement GPIOTE on GPIO1.x, but it seems to not work.
How to reproduce at below.
At first, I generate nrfx sample project.
Just be sure, I compile it and confirm that a callback is called when button 1 is pressed.
static void button_handler(nrfx_gpiote_pin_t pin,
			   nrfx_gpiote_trigger_t trigger,
			   void *context)
	LOG_INF("GPIO input event callback");
Then, I make a new file as 'app.overlay' with below contents.
	buttons {
		button0: button_0 {
			gpios = <&gpio1 14 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch 0";
This changes the config of button1 to GPIO1.14.
I compile again and short GPIO1.14. but no callback occurs. When I check GPIO 1.14 on the tester, the pull-up is not enabled.
For reference, GPIO0.x pull-ups work fine. (I just confirmed this with a sample project.)
I think this is a bug.
