I am using a BL653dvk (nrf52833 based) for my application development.
I need to have a timer module, which is at the least accurate to 1ms in time regulation, once I set the time.
But my observation is that, once I set the time, it varies with a difference of +/-43 secs in an hour.
So my question is,
1. Is this expected..?
2. If this can be improved upon, how do I improve on this..?
Please find my code as in below as I am using RTC:
bool overFlowEventHappened = false;
bool isOverflowEnabled = false;
bool debugOverflowReadback = false;
volatile uint64_t RTC2SystClock = 0;
uint64_t debugRTC2ClockCounter = 0;
void rtc_nrf_isr(const void *arg)
ARG_UNUSED(arg);
overFlowEventHappened= (bool)RTC->EVENTS_COMPARE[0];//(bool)*(volatile uint32_t *)((uint8_t *)RTC + (uint32_t)NRF_RTC_EVENT_OVERFLOW);
isOverflowEnabled = RTC->INTENSET & NRF_RTC_INT_OVERFLOW_MASK;
RTC2SystClock =CYC_PER_TICK;
static uint8_t secondCounter = 0;
RTC->EVENTS_OVRFLW=0;
debugOverflowReadback = RTC->EVENTS_OVRFLW;
secondCounter++;
if(secondCounter >=2)
#ifdef RTCGPIOTOGGLE
gpio_pin_toggle( dev_gpio0, PIN_LED);
debugHKSec++;
secondCounter = 0;
overflow_cnt += NUM_SEC_TO_OVERFLOW;
debugRTC2ClockCounter++;
RTC->EVENTS_COMPARE[0] = 0;
int sys_clock_driver_init()
static const enum nrf_lfclk_start_mode mode =
IS_ENABLED(CONFIG_SYSTEM_CLOCK_NO_WAIT) ?
CLOCK_CONTROL_NRF_LF_START_NOWAIT :
(IS_ENABLED(CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY) ?
CLOCK_CONTROL_NRF_LF_START_AVAILABLE :
CLOCK_CONTROL_NRF_LF_START_STABLE);
RTC->PRESCALER = 0;
for (int32_t chan = 0; chan < CHAN_COUNT; chan++)
cc_data[chan].target_time = TARGET_TIME_INVALID;
RTC->INTENSET = RTC_CHANNEL_INT_MASK(chan);
RTC->INTENSET = NRF_RTC_INT_OVERFLOW_MASK;
enableRTCIRQ();
TriggerRTCTask();
int_mask = BIT_MASK(CHAN_COUNT);
if (CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT)
alloc_mask = BIT_MASK(EXT_CHAN_COUNT) << 1;
uint32_t initial_timeout = IS_ENABLED(CONFIG_TICKLESS_KERNEL) ?
(COUNTER_HALF_SPAN - 1) :
(counter() + CYC_PER_TICK);
RTC->CC[0]= 16384*NUM_SEC_TO_OVERFLOW;
z_nrf_clock_control_lf_on(mode);
return 0;
void enableRTCIRQ()
NVIC_ClearPendingIRQ(RTC_IRQn);
IRQ_CONNECT(RTC_IRQn,4, rtc_nrf_isr, 0, 0);
irq_enable(RTC_IRQn);
void TriggerRTCTask()
nrf_rtc_task_trigger(RTC, NRF_RTC_TASK_CLEAR);
nrf_rtc_task_trigger(RTC, NRF_RTC_TASK_START);
}Thanks
