NRF 52850 Custom Board dosent work in Flash mode only works in debug,
My custom board gets stuck in reset when i flash it. It works fine with debug mode . When i toggle a gpio using examble buttton code, same thing happens.
I have also noticed that example code dosent work in the load mode with nrf52840dk board files, but works fine with my custom board files.
Attaching my .dts files and main file for reference
 * Copyright (c) 2017 Linaro Limited
/dts-v1/;
#include <nordic/nrf52840_qiaa.dtsi>
#include "nrf52840dk_nrf52840_Saans-pinctrl.dtsi"
	model = "SAANS_NBM";
	compatible = "nordic,nrf52840-dk-nrf52840";
	chosen {
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,bt-mon-uart = &uart0;
		zephyr,bt-c2h-uart = &uart0;
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
	leds {
		compatible = "gpio-leds";
		dacactivatepin: dacactivate_pin {
			gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
			label = "DACActivatePin";
		blowerenablepin: blowerenable_pin {
			gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>;
			label = "B";
		buzzerhighpin: buzzerhigh_pin {
			gpios = <&gpio0 9 GPIO_ACTIVE_HIGH>;
			label = "buzzerhighpin";
		buzzerlowpin: buzzerlow_pin {
			gpios = <&gpio1 10 GPIO_ACTIVE_HIGH>;
			label = "buzzerlowpin2";
		buzzermediumpin: buzzermedium_pin {
			gpios = <&gpio0 10 GPIO_ACTIVE_HIGH>;
			label = "buzzermediumpin";
		encoderdecrement: encoder_decrement {
			gpios = <&gpio0 22 GPIO_ACTIVE_HIGH>;
			label = "Push button switch 2";
		led3: led_3 {
			gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
			label = "Green LED 3";
	pwmleds {
		compatible = "pwm-leds";
		pwm_led0: pwm_led_0 {
			pwms = <&pwm0 0 PWM_NSEC(4000) PWM_POLARITY_NORMAL>;
	buttons {
		compatible = "gpio-keys";
		encoderincrement: encoder_increment {
			gpios = <&gpio0 24 GPIO_ACTIVE_HIGH>;
			label = "Push button switch 0";
		encoderpush: encoder_push {
			gpios = <&gpio0 21 GPIO_ACTIVE_LOW>;
			label = "Push button switch 1";
	arduino_header: connector {
		compatible = "arduino-header-r3";
		#gpio-cells = <2>;
		gpio-map-mask = <0xffffffff 0xffffffc0>;
		gpio-map-pass-thru = <0 0x3f>;
		gpio-map = <0 0 &gpio0 3 0>,	/* A0 */
			   <1 0 &gpio0 4 0>,	/* A1 */
			   <2 0 &gpio0 28 0>,	/* A2 */
			   <3 0 &gpio0 29 0>,	/* A3 */
			   <4 0 &gpio0 30 0>,	/* A4 */
			   <5 0 &gpio0 31 0>,	/* A5 */
			   <6 0 &gpio1 1 0>,	/* D0 */
			   <7 0 &gpio1 2 0>,	/* D1 */
			   <8 0 &gpio1 3 0>,	/* D2 */
			   <9 0 &gpio1 4 0>,	/* D3 */
			   <10 0 &gpio1 5 0>,	/* D4 */
			   <11 0 &gpio1 6 0>,	/* D5 */
			   <12 0 &gpio1 7 0>,	/* D6 */
			   <13 0 &gpio1 8 0>,	/* D7 */
			   <14 0 &gpio1 10 0>,	/* D8 */
			   <15 0 &gpio1 11 0>,	/* D9 */
			   <16 0 &gpio1 12 0>,	/* D10 */
			   <17 0 &gpio1 13 0>,	/* D11 */
			   <18 0 &gpio1 14 0>,	/* D12 */
			   <19 0 &gpio1 15 0>,	/* D13 */
			   <20 0 &gpio0 26 0>,	/* D14 */
			   <21 0 &gpio0 27 0>;	/* D15 */
	arduino_adc: analog-connector {
		compatible = "arduino,uno-adc";
		#io-channel-cells = <1>;
		io-channel-map = <0 &adc 1>,	/* A0 = P0.3 = AIN1 */
				 <1 &adc 2>,	/* A1 = P0.4 = AIN2 */
				 <2 &adc 4>,	/* A2 = P0.28 = AIN4 */
				 <3 &adc 5>,	/* A3 = P0.29 = AIN5 */
				 <4 &adc 6>,	/* A4 = P0.30 = AIN6 */
				 <5 &adc 7>;	/* A5 = P0.31 = AIN7 */
	/* These aliases are provided for compatibility with samples */
	aliases {
		dacactivatepin = &dacactivatepin;
		blowerenablepin = &blowerenablepin;
		buzzerhighpin	= &buzzerhighpin;
		buzzerlowpin	= &buzzerlowpin;
		buzzermediumpin = &buzzermediumpin;
		led3 = &led3;
		pwmled0 = &pwm_led0;
		adcctrl=&adc;
		// blower = &blower;
		// sw0 = &button0;
		// sw1 = &button1;
		// sw2 = &button2;
		encoderincrement=&encoderincrement;
		encoderdecrement=&encoderdecrement;
		encoderpush=&encoderpush;
		// sw3 = &button3;
		//bootloader-led0 = &led0;
	zephyr,user {
		io-channels = <&adc 2>;
&timer1{
    status = "okay";
&adc {
	status = "okay";
	// io-channels = <&adc 3>;
	// io-channel-map = <0 &adc 1>;	/* A0 = P0.3 = AIN1 */
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&gpio1 {
	status = "okay";
&uart0 {
	status = "okay";
	current-speed = <250000>;
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
arduino_serial: &uart1 {
	status = "okay";
	pinctrl-0 = <&uart1_default>;
	pinctrl-1 = <&uart1_sleep>;
arduino_i2c: &i2c0 {
	compatible = "nordic,nrf-twi";
	status = "okay";
	pinctrl-0 = <&i2c0_default>;
	pinctrl-1 = <&i2c0_sleep>;
&i2c1 {
	/* Cannot be used together with spi1. */
	/* status = "okay"; */
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
&pwm0 {
	status = "okay";
	pinctrl-0 = <&pwm0_default>;
	pinctrl-1 = <&pwm0_sleep>;
&spi0 {
	compatible = "nordic,nrf-spi";
	/* Cannot be used together with i2c0. */
	pinctrl-0 = <&spi0_default>;
	pinctrl-1 = <&spi0_sleep>;
&spi1 {
	status = "disabled";
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
&spi2 {
	pinctrl-0 = <&spi2_default>;
	pinctrl-1 = <&spi2_sleep>;
&qspi {
	pinctrl-0 = <&qspi_default>;
	pinctrl-1 = <&qspi_sleep>;
	mx25r64: mx25r6435f@0 {
		compatible = "nordic,qspi-nor";
		reg = <0>;
		/* MX25R64 supports only pp and pp4io */
		writeoc = "pp4io";
		/* MX25R64 supports all readoc options */
		readoc = "read4io";
		sck-frequency = <8000000>;
		label = "MX25R64";
		jedec-id = [c2 28 17];
		sfdp-bfp = [
			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
		size = <67108864>;
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
arduino_spi: &spi3 {
	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>; /* D10 */
	pinctrl-0 = <&spi3_default>;
	pinctrl-1 = <&spi3_sleep>;
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x000000000 0x0000C000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x00067000>;
		slot1_partition: partition@73000 {
			label = "image-1";
			reg = <0x00073000 0x00067000>;
		scratch_partition: partition@da000 {
			label = "image-scratch";
			reg = <0x000da000 0x0001e000>;
		 * The flash starting at 0x000f8000 and ending at
		 * 0x000fffff is reserved for use by the application.
		 * Storage partition will be used by FCB/LittleFS/NVS
		 * if enabled.
		storage_partition: partition@f8000 {
			label = "storage";
			reg = <0x000f8000 0x00008000>;
zephyr_udc0: &usbd {
	compatible = "nordic,nrf-usbd";
	status = "okay";
/* -------------------- TODO: check battery during bootup ------------------- */
/* ---- TODO:CALL FUNCTIONS, UPDATELCD, READ SENSORS , START THERAPY ETC ---- */
/* -------------- TODO:call bootup seuence for hardware checks -------------- */
/* ------------------ TODO: CALL Alarm_SetCase in main loop ----------------- */
#include "config.h"
// #define ENABLED_MODE_HFNC_BUBBLECPAP
// #undef ENABLED_MODE_RESUSCITATION_CPAP_HFNC_BUBBLECPAP
bool bBooting=true;
void main(void)
	// k_msleep(1000);
		// SystemInit_InitializeAll();
	gpio_pin_configure_dt(&BuzzerMediumPin, GPIO_OUTPUT);
	while(1)
    	gpio_pin_set_dt(&BuzzerHighPin, 1);
		k_msleep(1000);
    	gpio_pin_set_dt(&BuzzerHighPin, 0);
		k_msleep(1000);
	LCD_UpdateVersionText();
	while (ui8MasterTimerSeconds <= 5)
		ADC_ReadBatteryPercentage_boot();
		bootup_SendCalibrationScreen();
		//TODO:Move to syst init
	bBooting=false;
	k_msleep(1000);
	// TODO: Add calibrating blinks
	int bootup_loop_counter = 0;
	while (!bootup_MainRoutine())
		bootup_loop_counter++;
		if (bootup_loop_counter == 5)
			Alarms_CheckForAlarmsinLoop();
		k_msleep(500);
	while (!(bBootupCheckPassed_Battery || bBatteryChargingFlag))
		ADC_CheckForACPlug();
	LCD_JumpPage(HOME_PAGE);
	LCD_UpdateHomePage();
	while (1)
		if (ActiveMode != ResuscitationMode)
			I2C_ReadAllSensors();
		if (bTherapyStarted && !bTherapyPaused)
			Control_FLOWDACPRESSURE();
		else if (!bTherapyPaused)
			Blower_SetBlowerSpeedToZero();
		LCD_UpdateScreen(ActiveScreen);
	while (1)
		// EnableBlower();
		k_msleep(1000);
		// if(ui32MasterTimerSeconds==5)
		// 	LCD_JumpPageTRIAL(HOME_PAGE);
		// //k_msleep(1000);
		// if(ui32MasterTimerSeconds==10)
		// 	LCD_JumpPageTRIAL(CPAP_PAGE);
		// for(int i=0;i<=95;i++)
		// Blower_UpdatePWMDutyCycle(20);
		// k_msleep(5000);
		// adc_read(dev_adc, &battery_adc_sequence);
		// ADC_ReadVoltage(BATTERY_ADC);
		// ADC_ReadVoltage(AC_ADC);
		//  DisableBlower();
	// while (1)
	// 	// LCD_UpdateScreen(ActiveScreen);
    I suggest to run through DevAcademy if you haven't already:
    https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/
    For instance DevAcademy show how you should be able to turn on logging to get some information here using CONFIG_LOG=y.
    I suspect you have an assert somewhere during init, so possible also add:
    # Add asserts
    CONFIG_ASSERT=y
    CONFIG_ASSERT_VERBOSE=y
    CONFIG_ASSERT_NO_COND_INFO=n
    CONFIG_ASSERT_NO_MSG_INFO=n
    CONFIG_RESET_ON_FATAL_ERROR=n
    CONFIG_THREAD_NAME=y
    If you alredy have logging for instance with RTT, you may try with:
    CONFIG_LOG_BACKEND_RTT_MODE_DROP=y
    If you are unable to make this work, then zip the project folder and send it to me (I assume this can run on an nRF52840-DK for test).
    Kenneth
