NRF5340 LE AUDIO “Stream not associated with an ep”
I have two nRF5340 Audio DK.gateway+headset.
sometimes I get this error with headset:
Connected via Serial Port with settings COM16 115200 8n1 rtscts:off
*** Booting Zephyr OS build v3.2.99-ncs1 ***
HL [00:00:00.260,284] <dbg> fs_nvs: nvs_recover_last_ate: Recovering last ate from sector 0
HL [00:00:00.263,458] <inf> fs_nvs: 2 Sectors of 4096 bytes
HL [00:00:00.263,458] <inf> fs_nvs: alloc wra: 0, fd0
HL [00:00:00.263,488] <inf> fs_nvs: data wra: 0, 120
HL [00:00:00.263,763] <inf> fw_info:
         nRF5340 Audio nRF5340 Audio DK cpuapp
         NCS base version: 2.2.0
         Cmake run : Tue Mar 14 17:22:50 2023
HL [00:00:00.263,793] <inf> fw_info: ------- DEBUG BUILD -------
HL [00:00:00.263,793] <inf> fw_info: HEADSET left device
HL [00:00:00.275,573] <wrn> bt_hci_core: Controller to host flow control not supported
HL [00:00:00.404,357] <inf> ble: MAC: DC:0D:30:00:00:00 (random)
HL [00:00:00.404,571] <inf> ble: Controller version: 3310
HL [00:00:00.471,343] <inf> bis_headset: Scanning for broadcast sources
HL [00:00:00.751,159] <inf> bis_headset: Broadcast source FSC-BT631D found
HL [00:00:03.203,521] <inf> bis_headset: Codec config for LC3:
HL [00:00:03.203,552] <inf> bis_headset:        Frequency: 48000 Hz
HL [00:00:03.203,552] <inf> bis_headset:        Frame Duration: 10000 us
HL [00:00:03.203,552] <inf> bis_headset:        Octets per frame: 120 (96000 kbps)
HL [00:00:03.203,552] <inf> bis_headset:        Frames per SDU: 1
HL [00:00:03.203,582] <inf> bis_headset:        Channel allocation: 0x1
HL [00:00:03.203,582] <inf> bis_headset: Codec config for LC3:
HL [00:00:03.203,582] <inf> bis_headset:        Frequency: 48000 Hz
HL [00:00:03.203,613] <inf> bis_headset:        Frame Duration: 10000 us
HL [00:00:03.203,613] <inf> bis_headset:        Octets per frame: 120 (96000 kbps)
HL [00:00:03.203,613] <inf> bis_headset:        Frames per SDU: 1
HL [00:00:03.203,643] <inf> bis_headset:        Channel allocation: 0x1
HL [00:00:03.203,704] <inf> bis_headset: Syncing to broadcast stream index 0
HL [00:00:04.404,205] <inf> bis_headset: Stream index 0 started
HL [00:01:59.366,973] <inf> bis_headset: Restarting scanning for broadcast sources
HL [00:01:59.368,621] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.377,624] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.389,617] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.397,613] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.407,623] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.418,975] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.427,612] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.443,817] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.447,601] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.459,625] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.469,635] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.478,271] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.487,609] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.497,619] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.508,941] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.518,280] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.527,618] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.537,628] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.547,607] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.563,842] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.567,626] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.583,801] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.587,615] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.600,311] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.608,978] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.617,614] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.627,624] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.637,634] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.647,644] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.657,653] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.667,633] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.677,642] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.688,293] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.698,303] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.707,641] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.717,651] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.727,630] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.737,640] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.747,650] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.757,629] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.767,639] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.777,679] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.787,658] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.797,637] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.813,812] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.817,657] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.827,636] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.837,677] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.847,656] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.857,635] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.867,675] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.877,655] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.887,664] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.897,674] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.907,653] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.917,663] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.927,673] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.938,995] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.947,662] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.957,702] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.967,651] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.977,661] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.987,670] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:01:59.997,680] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.007,659] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.017,700] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.027,679] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.037,658] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.047,698] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.057,678] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.067,687] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.077,697] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.087,677] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.097,686] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.107,696] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.117,675] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.129,028] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.138,366] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.147,674] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.157,684] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.167,694] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.177,703] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.187,683] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.199,035] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.207,702] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.218,383] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.227,722] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.237,701] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.247,711] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.257,720] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.267,730] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.277,709] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.287,750] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.297,729] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.307,708] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.317,749] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.328,369] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.337,707] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.347,717] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.357,696] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.367,706] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.379,730] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.387,695] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.397,705] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.407,745] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.414,520] <inf> bis_headset: Broadcast source FSC-BT631D found
HL [00:02:00.417,724] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.427,703] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.437,713] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.447,723] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.457,702] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.467,742] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.477,722] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.487,731] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.497,741] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.507,720] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.517,730] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.527,740] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.537,719] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.547,729] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.557,739] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.567,718] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.577,728] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.587,738] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.597,747] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.608,398] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.617,736] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.627,746] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.637,725] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.648,406] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.657,745] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.668,426] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.677,734] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.687,744] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.698,425] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.707,733] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.717,742] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.727,752] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.737,762] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.748,413] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.757,751] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.768,432] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.777,740] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.787,780] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.797,760] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.807,769] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.817,779] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.827,758] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.837,768] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.847,778] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.857,757] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.868,438] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.877,777] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.887,756] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.897,766] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.907,806] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.919,097] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.927,764] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.937,805] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.947,784] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.957,763] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.967,803] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.977,783] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.987,792] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:00.997,802] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.007,781] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.017,791] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.027,770] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.037,780] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.047,790] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.059,783] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.067,779] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.077,789] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.088,470] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.097,778] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.107,788] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.117,797] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.127,777] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.137,817] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.147,827] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.157,806] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.167,816] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.177,856] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.187,805] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.198,486] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.207,824] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.217,834] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.227,813] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.237,823] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.247,802] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.257,812] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.268,463] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.278,472] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.287,811] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.298,492] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.307,800] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.317,810] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.327,819] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.337,829] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.347,808] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.357,818] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.367,828] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.377,807] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.387,817] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.397,827] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.407,836] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.417,846] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.427,825] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.437,835] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.447,845] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.457,824] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.469,177] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.479,187] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.490,509] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.498,504] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.507,843] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.518,524] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.529,846] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.537,872] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.549,194] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.559,844] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.570,526] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.577,850] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.587,829] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.604,064] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.608,520] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.618,499] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.628,509] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.637,847] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.647,857] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.657,836] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.667,846] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.677,856] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.687,866] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.697,875] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.707,855] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.717,864] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.727,844] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.737,884] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.747,863] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.757,873] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.767,883] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.777,862] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.787,872] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.797,882] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.807,861] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.817,871] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.827,880] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.837,860] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.847,869] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.857,910] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.867,889] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.878,540] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.887,878] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.897,888] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.907,897] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.917,877] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.927,886] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.937,896] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.947,906] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.957,885] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.967,895] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.977,905] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.987,884] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:01.997,894] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.007,934] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.018,585] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.027,923] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.037,902] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.047,912] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.057,922] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.067,932] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.077,911] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.088,592] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.097,930] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.107,910] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.117,889] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.127,899] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.137,908] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.147,918] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.158,569] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.167,907] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.178,588] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.187,896] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.197,906] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.207,916] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.217,926] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.227,905] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.237,915] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.247,924] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.257,934] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.267,913] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.277,923] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.288,604] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.297,943] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.307,922] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.317,932] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.327,941] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.337,921] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.347,930] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.359,283] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.367,950] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.377,929] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.387,939] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.397,949] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.407,928] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.417,968] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.427,947] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.437,927] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.447,967] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.457,946] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.467,956] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.477,966] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.487,945] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.497,955] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.507,965] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.518,615] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.528,625] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.537,963] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.547,943] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.557,952] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.567,993] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.578,613] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.587,951] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.597,991] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.608,642] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.617,950] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.627,990] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.637,969] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.647,949] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.657,989] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.667,968] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.677,978] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.687,988] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.698,638] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.707,977] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.717,987] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.727,966] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.737,976] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.747,985] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.757,965] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.767,974] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.778,015] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.787,994] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.797,973] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.807,983] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.817,993] <err> bt_audio_broadcast_sink: Stream not associated with an ep
HL [00:02:02.827,972] <err> bt_audio_broadcast_sink: Stream not associated with an ep
Disconnected
I cant't get recover untill reset.Any advise to fix this?
