The release notes from Connect SDK says that the bt_disable() can by used and my team is interested in that feature.
I see that host driver do not have any pointer on close field. Could you give me any information how to implement that? Should ipc instance be closed after disabling?
Is multiprotocol radio firmware compatible with that? How it will behave in that situation?
When I tried to add the close function with just deregisteing endpoint I was not able to register it second time. On the other side the same implementation works on vanilla Zephyr with opensource radion FW.
Thanks in advance
