Setting PSM/eDRX by AT commands
I have a problem with setting PSM (T3412+T3324) and eDRX timers using  AT commands. I use nRF9160-DK and follow "nRF9160 AT Commands Command Reference Guide v2.2" document for AT commands. According to it, to set PSM and eDRX commands +CPSMS and +CEDRXS should be used. Unfortunately in my case none of this commands works as expected.
As read commands works fine, set commands does not seem so. When sending +CPSMS=[<mode>[,<Requested_Periodic-RAU>,<Requested_GPRS-READY-timer>
,<Requested_Periodic-TAU>[,<Requested_Active-Time>]]] or +CEDRXS=[<mode>,[,<AcT-type>[,<Requested_eDRX_value>]]] command the modul returns ERROR (in attachment, an example AT pcap). Don't have any idea why. Confused
In effect I can use only default values for PSM/eDRX timers. In other words I can set eDRX value to 20,48s (default one), but do not know how to change it. The case is all the more odd that according to the AT document this commands should work in the form in which I set them - in the document there are even examples of identical commands, that work fine.
Do you have any idea, why I can not set +CPSMS and +CEDRXS commands? Maybe there is some additional requirement which has to be met to use this commands? Or something else like that?
Thank you in advance.
trace-2023-03-14T13-56-02.259Z.pcapng
