I am using:
nRF52840
NRF Connect SDK 1.9.1
Custom hardware
My project is based on the Coap Client example with mtd overlay added and is running in SED mode. I am using ot_coap_client_utils.c, so that I may send confirmable messages.
Using the PPK2, I am measuring a baseline current over 2 mA. I tried it also on the DK and got similar results. On the DK I used the PPK2 in Source mode and connected it to the Battery input. With my custom hardware I use it in Ampere mode, with a lab power supply.
This will be a battery operated product. How do I find what is drawing this current?
The small blip is a blinking LED, and the tall spike is a data request (every 3 seconds).
The external hardware is all very low current and are not accessed most of the time. The main() function initializes everything then calls k_sleep(K_FOREVER). I think I have disabled everything I'm not using. So why is there still 2 mA all the time?
dts file:
// Copyright (c) 2023 Nordic Semiconductor ASA
// SPDX-License-Identifier: Apache-2.0
/dts-v1/;
#include <nordic/nrf52840_qiaa.dtsi>
model = "My_Sensor";
compatible = "mycompany,my-sensor";
chosen {
zephyr,console = &uart0;
zephyr,shell-uart = &uart0;
zephyr,uart-mcumgr = &uart0;
zephyr,bt-mon-uart = &uart0;
zephyr,bt-c2h-uart = &uart0;
zephyr,sram = &sram0;
zephyr,flash = &flash0;
zephyr,code-partition = &slot0_partition;
zephyr,entropy = &rng;
/* From: https://github.com/simon-iversen/sdk-zephyr/blob/serial_dfu_ext_flash_hello_world/samples/hello_world/boards/nrf52840dk_nrf52840.overlay
* for using external flash for DFU */
nordic,pm-ext-flash = &mx25r64;
leds {
compatible = "gpio-leds";
led0: led_0 {
gpios = <&gpio0 31 GPIO_ACTIVE_LOW>;
label = "Red LED 0";
ledbootloader0: bootloader_led0 {
label = "Bootloader LED 0";
led1: led_1 {
gpios = <&gpio0 30 GPIO_ACTIVE_LOW>;
label = "Green LED 1";
led2: led_2 {
gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
label = "Blue LED 2";
buttons {
compatible = "gpio-keys";
button0: button_0 {
gpios = <&gpio0 11 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
label = "Push button switch 0";
button1: button_1 {
gpios = <&gpio1 11 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
label = "EXTERNALn";
gpioout {
speaker: gpioout_0 {
gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>;
label = "SPEAKER";
gpioin {
hdcint0: hdcint_0 {
gpios = <&gpio1 13 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
label = "INT0";
lisint1: lisint_1 {
gpios = <&gpio1 15 (GPIO_ACTIVE_LOW)>;
label = "INT1";
lisint2: lisint_2 {
gpios = <&gpio1 14 (GPIO_ACTIVE_LOW)>;
label = "INT2";
cfg0: cfg_0 {
gpios = <&gpio0 7 GPIO_ACTIVE_HIGH>;
label = "CFG0";
cfg1: cfg_1 {
gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>;
label = "CFG1";
cfg2: cfg_2 {
gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>;
label = "CFG2";
cfg3: cfg_3 {
gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>;
label = "CFG3";
cfg4: cfg_4 {
gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>;
label = "CFG4";
cfg5: cfg_5 {
gpios = <&gpio0 25 GPIO_ACTIVE_HIGH>;
label = "CFG5";
cfg6: cfg_6 {
gpios = <&gpio1 9 GPIO_ACTIVE_HIGH>;
label = "CFG6";
pwmleds {
compatible = "pwm-leds";
pwm_speaker0: pwm_speaker_0 {
pwms = <&pwm0 44>;
status = "okay";
/* These aliases are provided for compatibility with samples */
aliases {
led0 = &led0;
led1 = &led1;
led2 = &led2;
sw0 = &button0;
sw1 = &button1;
lis-int1 = &lisint1;
lis-int2 = &lisint2;
bootloader-led0 = &led0;
pwm-speaker0 = &pwm_speaker0;
&pwm0 {
status = "okay";
ch0-pin = <44>;
//ch0-inverted; // Don't invert, 0% duty cycle will be low
&adc {
status = "okay";
vbatt {
compatible = "voltage-divider";
io-channels = <&adc 0>;
output-ohms = <1000000>;
full-ohms = <(2000000 + 1000000)>;
&gpiote {
status = "disabled";
&gpio0 {
status = "okay";
&gpio1 {
status = "okay";
&uart0 {
//status = "okay";
current-speed = <115200>;
tx-pin = <34>; /* pins are swapped on schematic Rev 6 */
rx-pin = <40>;
rx-pull-up;
/* rts-pin = <5>; */
/* cts-pin = <7>; */
cts-pull-up;
&uart1 {
&i2c0 {
status = "okay";
sda-pin = <26>;
scl-pin = <27>;
clock-frequency = < I2C_BITRATE_FAST >;
&i2c1 {
/* Cannot be used together with spi1. */
&spi0 {
&spi1 {
&spi2 {
&spi3 {
&timer0 {
&timer1 {
&timer2 {
&timer3 {
&timer4 {
&temp {
&qspi {
status = "okay";
sck-pin = <16>;
io-pins = <24>, <22>, <23>, <21>;
csn-pins = <15>;
mx25r64: mx25r6435f@0 {
compatible = "nordic,qspi-nor";
reg = <0>;
/* MX25R64 supports only pp and pp4io */
writeoc = "pp4io";
/* MX25R64 supports all readoc options */
readoc = "read4io";
sck-frequency = <8000000>;
label = "MX25R64";
jedec-id = [c2 28 17];
sfdp-bfp = [
e5 20 f1 ff ff ff ff 03 44 eb 08 6b 08 3b 04 bb
ee ff ff ff ff ff 00 ff ff ff 00 ff 0c 20 0f 52
10 d8 00 ff 23 72 f5 00 82 ed 04 cc 44 83 68 44
30 b0 30 b0 f7 c4 d5 5c 00 be 29 ff f0 d0 ff ff
size = <67108864>;
has-dpd;
t-enter-dpd = <10000>;
t-exit-dpd = <35000>;
&flash0 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x0 0x10000>;
slot0_partition: partition@10000 {
label = "image-0";
reg = <0x10000 0xE8000>;
// slot1_partition: partition@7e000 {
// label = "image-1";
// reg = <0x7e000 0x72000>;
// scratch_partition: partition@f0000 {
// label = "image-scratch";
// reg = <0xf0000 0xa000>;
//cert_partition: partition@F5000 {
// label = "dev-certs";
// reg = <0x000F5000 0x00003000>;
storage_partition: partition@f8000 {
label = "storage";
reg = <0xf8000 0x8000>;
&mx25r64 {
partitions {
#size-cells = <1>;
slot1_partition: partition@0 {
label = "image-1";
reg = <0x00000000 0x0000E8000>;
scratch_partition: partition@e8000 {
reg = <0x0000E8000 0x0000E8000>;
download_partition: partition@1d0000 {
label = "image-download";
reg = <0x001D0000 0x00010000>;
prj.conf
# # Copyright (c) 2020 Nordic Semiconductor # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # # nRF board library CONFIG_DK_LIBRARY=y # Enable CoAP utils and CoAP protocol #CONFIG_COAP_UTILS=y # Enable OpenThread CoAP support API CONFIG_OPENTHREAD_COAP=y CONFIG_OPENTHREAD_COAP_OBSERVE=y # Configure sample logging setting #CONFIG_LOG=y #CONFIG_COAP_CLIENT_LOG_LEVEL_DBG=y #CONFIG_COAP_CLIENT_UTILS_LOG_LEVEL_DBG=y #CONFIG_COAP_UTILS_LOG_LEVEL_DBG=y #CONFIG_OPENTHREAD_LOG_LEVEL_NOTE=y #CONFIG_OPENTHREAD_DEBUG=y # Adjust log strdup settings CONFIG_LOG_STRDUP_MAX_STRING=128 # Generic networking options CONFIG_NETWORKING=y # L2 OpenThread enabling CONFIG_NET_L2_OPENTHREAD=y # Network shell #CONFIG_SHELL=y #CONFIG_OPENTHREAD_SHELL=y #CONFIG_SHELL_ARGC_MAX=26 #CONFIG_SHELL_CMD_BUFF_SIZE=416 # Enable OpenThread features set CONFIG_OPENTHREAD_NORDIC_LIBRARY_MASTER=y # Network sockets CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_NET_SOCKETS_POLL_MAX=4 # Thread Joiner CONFIG_OPENTHREAD_JOINER=y CONFIG_OPENTHREAD_JOINER_AUTOSTART=y CONFIG_OPENTHREAD_JOINER_PSKD="M00N6BANANA" CONFIG_OPENTHREAD_MANUAL_START=n # Same network Master Key for client and server #CONFIG_OPENTHREAD_NETWORKKEY="00:11:22:33:44:55:66:77:88:99:aa:bb:cc:dd:ee:ff" CONFIG_ASSERT=y CONFIG_ASSERT_NO_COND_INFO=y CONFIG_MBEDTLS_SHA1_C=n CONFIG_FPU=y # QSPI Flash CONFIG_SPI=y CONFIG_NORDIC_QSPI_NOR=y CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16 CONFIG_FLASH=y CONFIG_MAIN_STACK_SIZE=8192 # PWM for speaker CONFIG_PWM=y CONFIG_PWM_LOG_LEVEL_DBG=n # Sensors CONFIG_I2C=y CONFIG_GPIO=y #CONFIG_SENSOR=y #CONFIG_TI_HDC=y CONFIG_ADC=y
overlay_mtd.conf
# # Copyright (c) 2020 Nordic Semiconductor # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # # Enable MTD Sleepy End Device CONFIG_OPENTHREAD_MTD=y CONFIG_OPENTHREAD_MTD_SED=y CONFIG_OPENTHREAD_POLL_PERIOD=3000 CONFIG_RAM_POWER_DOWN_LIBRARY=y CONFIG_PM_DEVICE=y # This variant requires increased system workqueue stack size #CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1536 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=3072 # Low Power, turn off uarts CONFIG_SERIAL=n CONFIG_LOG=n CONFIG_CONSOLE=n CONFIG_UART_CONSOLE=n CONFIG_RTT_CONSOLE=n CONFIG_USE_SEGGER_RTT=n CONFIG_PRINTK=n
I checked .config and confirmed that CONFIG_SERIAL is not set, nor is CONFIG_LOG.
Any help is appreciated.
Mary
