Im programming the Openthread coprocessor NCP Zephyr example on a nrf52840 and I am using nrf connect sdk 2.2.0. I just added logs to the sample, so it is really basic:
void main(void)
otInstance *ot;
otError error;
uint16_t panid;
uint8_t networkkey[16];
uint8_t channel;
otExtAddress *extAddr;
otExtendedPanId *extPanId;
otNetworkKey *networkKey;
otOperationalDataset *dataset;
const char *networkName;
// LOG_INF("Running...");
for (;;) {
k_sleep(K_MSEC(1000));
// Inicializar la instancia de OpenThread
ot = otInstanceInitSingle();
error = otDatasetGetActive(ot, dataset);
// Obtener el PAN ID actual
panid = otLinkGetPanId(ot);
LOG_INF("PANID: %04X",panid);
// Obtener el canal actual
channel = otLinkGetChannel(ot);
LOG_INF("Channel: %0d",channel);
//Obtener el networkname
// LOG_INF("Network Name: %c%c%c%c",
// dataset->mNetworkName.m8[0], dataset->mNetworkName.m8[1], dataset->mNetworkName.m8[2], dataset->mNetworkName.m8[3]);
// Obtener la extended addr
extAddr = otLinkGetExtendedAddress(ot);
LOG_INF("MAC Addrs: %02X%02X%02X%02X%02X%02X%02X%02X",
extAddr->m8[0], extAddr->m8[1], extAddr->m8[2], extAddr->m8[3],
extAddr->m8[4], extAddr->m8[5], extAddr->m8[6], extAddr->m8[7]);
// Obtener el extended PAN ID
extPanId = otThreadGetExtendedPanId(ot);
LOG_INF("ExtPANID: %02X%02X%02X%02X%02X%02X%02X%02X",
extPanId->m8[0], extPanId->m8[1], extPanId->m8[2], extPanId->m8[3],
extPanId->m8[4], extPanId->m8[5], extPanId->m8[6], extPanId->m8[7]);
// Obtener el network key
otThreadGetNetworkKey(ot, networkKey);
LOG_INF("Networkkey: %02X:%02X:%02X:%02X:%02X:%02X:%02X:%02X:%02X:%02X:%02X:%02X:%02X:%02X:%02X:%02X",
networkKey->m8[0], networkKey->m8[1], networkKey->m8[2], networkKey->m8[3],
networkKey->m8[4], networkKey->m8[5], networkKey->m8[6], networkKey->m8[7],
networkKey->m8[8], networkKey->m8[9], networkKey->m8[10], networkKey->m8[11],
networkKey->m8[12], networkKey->m8[13], networkKey->m8[14], networkKey->m8[15]);
// Obtener la network name
networkName = otThreadGetNetworkName(ot);
LOG_INF("Network Name: %s\n\n", networkName);
When I flash the radio co processor and the host its works nicely. But if I scan the openthread network i get the next output:
I have 3 nodes and that one marked is the one I am talking. The node with CLI mode is the one I am scanning from. We can observe that network name is not appearing and the extended PANid is not correct cause if I look at the logs I can see this:
(ignore the MAC addrs, this screen is from an old try)
So I have tried to change it from prj.conf:
CONFIG_OPENTHREAD_NETWORKKEY="00:11:22:33:44:55:66:77:88:99:aa:bb:cc:dd:ee:ff"
And when I build it, I check it in .config and it has been set correctly, but If I log it, the result is the same that I shared in the pictures above.
So my question is:
1º) Why is not appearing the network name when I scan from another node?
2º) Why in the logs I can see the correct extended panid but it is "0000000000000000" when I scan it?
3º) Why the networkkey is not the correct when I log it?
