Partition Manager for External Memory doesn't create correctly the partitions.
   I created the regions.yml and pm_static.yml. If I enable this flag the compiler works well
but doesn't create the correct partitions I wrote on pm_static.
##CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL=y
  If I uncomment, these errors appears:
-- Found partition manager static configuration: C:/Nordic/peripheral_uart/pm_static.yml
Dropping partition 'nonsecure_storage' since it is empty.
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 1978, in <module>
    main()
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 1028, in main
    solution.update(solve_region(pm_config, region, region_config,
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 971, in solve_region
    get_region_config(partitions, region_config, static_partitions, system_reqs=pm_config)
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 742, in get_region_config
    solve_simple_region(pm_config, start, size, placement_strategy, region_name, device,
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 790, in solve_simple_region
    address += pm_config[partition_name]['size']
KeyError: 'size'
CMake Error at C:/ncs/v2.3.0-rc1/nrf/cmake/partition_manager.cmake:304 (message):
  Partition Manager failed, aborting.
   Could you help me?
Flavio.
file app.overlay
    chosen {
        nordic,nus-uart = &uart0;
        nordic,pm-ext-flash = &mx25r64;
        nordic,nrf-adc  = &adc;
    aliases {
        adc = &adc;
        dg0 = &dig0;
        dg1 = &dig1;
        dg2 = &dig2;
        dg3 = &dig3;
        dg4 = &dig4;
file prj.conf
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=1024
CONFIG_SETTINGS_NVS=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
CONFIG_PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL=y
file regions.yml
external_flash:
  base_address: 0x0
  default_driver_kconfig: CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER
  device: DT_CHOSEN(nordic_pm_ext_flash)
  dynamic_partition: null
  placement_strategy: start_to_end
file pm_static.yml
partition_1:
  address: 0x0
  end_address: 0x7FFFFF
  region: external_flash
Created by build:
file regions.yml
external_flash:
  base_address: 0x0
flash_primary:
  base_address: 0x0
  default_driver_kconfig: CONFIG_SOC_FLASH_NRF
  device: flash_controller
  placement_strategy: complex
file partitions.yml
app:
  address: 0x8000
  end_address: 0xfc000
  region: flash_primary
external_flash:
  address: 0x0
  end_address: 0x800000
nonsecure_storage:
  address: 0xfc000
  end_address: 0xfe000
  orig_span: &id001
  - settings_storage
  span: *id001
