Partition Manager for External Memory doesn't create correctly the partitions.
   I created the regions.yml and pm_static.yml. If I enable this flag the compiler works well
but doesn't create the correct partitions I wrote on pm_static.
##CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL=y
  If I uncomment, these errors appears:
-- Found partition manager static configuration: C:/Nordic/peripheral_uart/pm_static.yml
Dropping partition 'nonsecure_storage' since it is empty.
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 1978, in <module>
    main()
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 1028, in main
    solution.update(solve_region(pm_config, region, region_config,
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 971, in solve_region
    get_region_config(partitions, region_config, static_partitions, system_reqs=pm_config)
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 742, in get_region_config
    solve_simple_region(pm_config, start, size, placement_strategy, region_name, device,
  File "C:/ncs/v2.3.0-rc1/nrf/scripts/partition_manager.py", line 790, in solve_simple_region
    address += pm_config[partition_name]['size']
KeyError: 'size'
CMake Error at C:/ncs/v2.3.0-rc1/nrf/cmake/partition_manager.cmake:304 (message):
  Partition Manager failed, aborting.
   Could you help me?
Flavio.
file app.overlay
    chosen {
        nordic,nus-uart = &uart0;
        nordic,pm-ext-flash = &mx25r64;
        nordic,nrf-adc  = &adc;
    aliases {
        adc = &adc;
        dg0 = &dig0;
        dg1 = &dig1;
        dg2 = &dig2;
        dg3 = &dig3;
        dg4 = &dig4;
file prj.conf
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=1024
CONFIG_SETTINGS_NVS=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
CONFIG_PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL=y
file regions.yml
external_flash:
  base_address: 0x0
  default_driver_kconfig: CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER
  device: DT_CHOSEN(nordic_pm_ext_flash)
  dynamic_partition: null
  placement_strategy: start_to_end
file pm_static.yml
partition_1:
  address: 0x0
  end_address: 0x7FFFFF
  region: external_flash
Created by build:
file regions.yml
external_flash:
  base_address: 0x0
flash_primary:
  base_address: 0x0
  default_driver_kconfig: CONFIG_SOC_FLASH_NRF
  device: flash_controller
  placement_strategy: complex
file partitions.yml
app:
  address: 0x8000
  end_address: 0xfc000
  region: flash_primary
external_flash:
  address: 0x0
  end_address: 0x800000
nonsecure_storage:
  address: 0xfc000
  end_address: 0xfe000
  orig_span: &id001
  - settings_storage
  span: *id001
  • Hi 3Nigma,
       Worked very well with your suggestion on makefile.
       On the file partitions , it's ok with two partitions created (partition_0 and partition_1). One thing I didn't understand is why was created automacatily a partition external_partition with negative size. Do you know if it's possible don't create this external_partition?
    Flavio.
    EMPTY_0:
      address: 0xfe000
      end_address: 0x100000
      placement:
        after:
        - littlefs_storage
    app:
      address: 0x8000
      end_address: 0xf8000
    external_flash:
      address: 0x802000
    littlefs_storage:
      address: 0xf8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x4000
        before:
        - end
    nonsecure_storage:
      address: 0xf8000
      orig_span: &id001
      - littlefs_storage
      span: *id001
    otp:
      address: 0xff8100
      end_address: 0xff83fc
      region: otp
    partition_0:
      address: 0x0
      end_address: 0x400000
    partition_1:
      address: 0x400000
    rpmsg_nrf53_sram:
      address: 0x20070000
      end_address: 0x20080000
      placement:
        before:
        - end
      region: sram_primary
    settings_storage:
      address: 0x800000
      end_address: 0x802000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x4000
        before:
        - tfm_storage
        - end
    sram_nonsecure:
      address: 0x20008000
      orig_span: &id002
      - sram_primary
      - rpmsg_nrf53_sram
      span: *id002
    sram_primary:
      address: 0x20008000
      end_address: 0x20070000
    sram_secure:
      address: 0x20000000
      end_address: 0x20008000
      orig_span: &id003
      - tfm_sram
      span: *id003
    tfm:
      address: 0x0
      end_address: 0x8000
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x8000
      orig_span: &id004
      - app
      span: *id004
    tfm_secure:
      address: 0x0
      end_address: 0x8000
      orig_span: &id005
      - tfm
      span: *id005
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
  • Hey Flavio,
    I think this code explains why an external_flash region is being generated: if you have a chosennordic,pm-ext-flash value, then an external_region is provided to you.
    So if you do a
    	chosen {
    		/delete-property/ nordic,pm-ext-flash;
    it should, in theory, work. But you will need to change your main.c code a bit (saw that you are using
    DEVICE_DT_GET(DT_CHOSEN(nordic_pm_ext_flash)) there).
    One thing to mention here is that, if you remove the nordic,pm-ext-flash chosen value,
    CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL also becomes unavailable due to the way it's Kconfig is defined. This leads, in your case, to no external_flash partitions being generated.
    V
  • Hello 3Nigma,
    I edited the partition_manager.cmake and added manualy the region. Removed nordic,pm-ext-flash from chosen.
    Now it's creating the partitions.yml correctly and the regions.yml too.
    And don't have the size negative on partition external_flash.
    Do you know if there is another way to create this region without edit the partition_manager.cmake?
    Flavio.
    dt_chosen(ext_flash_dev PROPERTY nordic,pm-ext-flash)
    if (DEFINED ext_flash_dev)
      dt_prop(num_bits PATH ${ext_flash_dev} PROPERTY size)
      math(EXPR num_bytes "${num_bits} / 8")
      set(external_flash_driver_kconfig CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER)
      add_region(
        NAME external_flash
        SIZE ${num_bytes}
        BASE ${CONFIG_PM_EXTERNAL_FLASH_BASE}
        PLACEMENT start_to_end
        DEVICE "DT_CHOSEN(nordic_pm_ext_flash)"
        DEFAULT_DRIVER_KCONFIG ${external_flash_driver_kconfig}
    endif()
    add_region(
      NAME external_flash
      SIZE 0X800000
      BASE 0
      DEVICE "DT_ALIAS(external-mx25)"
      DEFAULT_DRIVER_KCONFIG CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER
  • Hey Flavio,
    Why do you want to keep the external_flash region around if you don't want to put any partition in it?
    By the way, I would not edit the partition_manager.cmake directly since, unlike the previous discussion (eg. with the pm.yml.settings file), the partition_manager.cmake code behaves correctly (it is not a bug).
    Depending on what you are trying to achieve, I think there are other solutions that would help instead of forcing a region to be defined.
    Best wishes,
    V
  • Hi Flavio,
    Have you achieved progress on your initial issue? Could you provide an update on the current status?
    Dejan
