LTE Time Recovery
I'm interested in learning more about the nRF9160. I'm working on Precision Timing applications, and one idea we've had is recovering time from LTE / 3GPP sources as a fail-over when GPS is not available.
The idea would be to use the nRF9160 mainly as a GPS receiver that also listens to nearby LTE towers and tracks the timing of broadcast frames from those towers (I'm not fully versed in 3GPP standards so my technical terminology may not be fully complete). These broadcast frames at 10ms intervals (I believe) are supposed to be UTC aligned, and could be used for disciplining the 1PPS output of the nRF9160 when GPS is lost.
Is it possible to run the nRF9160 LTE modem in receiver only mode, with precision time stamping? And then use the LTE modem as for tracking tower broadcast frames as a secondary timing source?
If there's another chipset capable of this as well, that'd also be interesting.
Thank you!
    I don't think this is currently possible.
    What kind of accuracy do you need?
    While we do have some AT commands for getting the time from the network (assuming the time is broadcasted by the network in the first place), they aren't the most accurate. See e.g. https://infocenter.nordicsemi.com/topic/ref_at_commands/REF/at_commands/mob_termination_ctrl_status/cclk_nordic_read.html
    However, I don't think they are used by the 1PPS signal at all.
    I will forward your request to the modem team, and hear what they have to say.
    Didrik
  • Hi Didrik,
    Thanks for the reply! Degraded accuracy is to be expected, it would be more for improved holdover / frequency stability of the 1PPS signal.
    The absolute accuracy of the 1PPS will require GPS at some point to work, but if the frequency of a nearby base-station can be measured with respect to GPS while it's operational, it should be possible to track that base-station when GPS is not available and maintain some level of frequency disciplining.
    The time command looks like it's handling gross time, i.e. Time-Of-Day, which is important, but I'm mainly looking for the sub-second level timing, which is where 1PPS disciplining comes in.
    One other product that does this already is the SARA-R510M8S-01B module from U-blox. They call the feature CellTime, where they fall-back to recovering the time from LTE when GPS fails.
    Please let me know if I can provide anymore details.
    Thank you!
    -Julian
