TF-M partition alignment assert within SPU might fail for some partition-manager computed configs
v2.3.0 of the sdk-nrf included this commit that checks for the alignment of the TF-M Non Secure partition (which hosts the `app` one) with CONFIG_NRF_SPU_FLASH_REGION_SIZE .
#define IS_ALIGNED_POW2(value, align) (((value) & ((align) - 1)) == 0)
#if !(IS_ALIGNED_POW2(PM_TFM_NONSECURE_ADDRESS, CONFIG_NRF_SPU_FLASH_REGION_SIZE))
#error "TF-M non-secure address start is not aligned on SPU region size"
For stock/most cases (eg. hello_world code), the assertion holds and the project compiles.
The problem arouses when the partition_manager.py script outputs a layout solution in which the resulting PM_TFM_NONSECURE_ADDRESS becomes non-aligned. This has been my experience with the current project that I'm working on.
To temporarily mitigate this, I ended up taking out the alignment assertion check altogether.
Is this a safe thing to do or is there any other better solution to this?
Thank you,
V
  • Hi Håkon,
    Unfortunately, the pm_static.yml override doesn't seam to work. It looks like the kernel is faulting immediately after entering mcuboot so I don't quite know what's happening there and I don't have the proper time to investigate.
    For now, we'll just go with cloning the sdk-nrf repo and removing the PSU assert.c check via a commit + referencing our own, patched, sdk-nrf module when 'whest update'-ing. We'll plan on coming back to this, as time permits, and try to manually align it. If upstream won't do it first, that is.
    I have found another issue with the partition-manager when resolving the settings partition (in some scenario). I'll open another ticket for this.
    Thank you once again, Håkon!
    Best wishes,
    V
  • Is there already a bug ticket for this that I can track? I am also facing this issue and interested in a fix of the partition manager.
  • Where are these suppose to be opened? I see that the sdk-nrf github repo doesn't have issues enabled.
    V
    First I'd like to apologize for this issue and inconvenience.
    I have edit'ed my initial answer. The workaround is to adjust the partition layout via. pm_static.yml (ie. do not change CONFIG_FPROTECT).
    Here's an example of an NCS v2.2.0 layout (with this 0x200 offset, which we do not want for NCS v2.3.0):
    EMPTY_0:
      address: 0xf6000
      end_address: 0xf8000
      placement:
        after:
        - settings_storage
      region: flash_primary
    app:
      address: 0x4c200
      end_address: 0xf4000
    external_flash:
      address: 0x128000
      end_address: 0x800000
      region: external_flash
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
      placement:
        align:
          start: 0x4000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - mcuboot_pad
      - app
      - tfm
      span: *id001
    mcuboot_primary_1:
      address: 0x0
      device: nordic_ram_flash_controller
      end_address: 0x40000
      region: ram_flash
    mcuboot_primary_app:
      address: 0xc200
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x0
      device: DT_CHOSEN(nordic_pm_ext_flash)
      end_address: 0xe8000
      placement:
        align:
          start: 0x4
      share_size:
      - mcuboot_primary
    mcuboot_secondary_1:
      address: 0xe8000
      end_address: 0x128000
    nonsecure_storage:
      address: 0xf4000
      end_address: 0xf6000
      orig_span: &id003
      - settings_storage
      span: *id003
    otp:
      address: 0xff8100
      end_address: 0xff83fc
      region: otp
    pcd_sram:
      address: 0x20000000
      end_address: 0x20002000
      placement:
        before:
        - tfm_sram
      region: sram_primary
    ram_flash:
      address: 0x40000
      region: ram_flash
    rpmsg_nrf53_sram:
      address: 0x20070000
      end_address: 0x20080000
      placement:
        before:
        - end
    settings_storage:
      address: 0xf4000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x4000
        before:
        - tfm_storage
        - end
    sram_nonsecure:
      address: 0x20042000
      orig_span: &id004
      - sram_primary
      - rpmsg_nrf53_sram
      span: *id004
    sram_primary:
      address: 0x20042000
      end_address: 0x20070000
    sram_secure:
      address: 0x20000000
      end_address: 0x20042000
      orig_span: &id005
      - pcd_sram
      - tfm_sram
      span: *id005
    tfm:
      address: 0xc200
      end_address: 0x4c200
      inside:
      placement:
        before:
        - app
    tfm_its:
      address: 0xf8000
      end_address: 0xfa000
      inside:
      - tfm_storage
      placement:
        before:
        - tfm_otp_nv_counters
    tfm_nonsecure:
      address: 0x4c200
      orig_span: &id006
      - app
      span: *id006
    tfm_otp_nv_counters:
      address: 0xfa000
      end_address: 0xfc000
      inside:
      - tfm_storage
      placement:
        before:
        - tfm_ps
    tfm_ps:
      address: 0xfc000
      end_address: 0x100000
      inside:
      - tfm_storage
      placement:
        align:
          start: 0x4000
        before:
        - end
    tfm_secure:
      address: 0xc000
      orig_span: &id007
      - mcuboot_pad
      - tfm
      span: *id007
    tfm_sram:
      address: 0x20002000
      inside:
      - sram_secure
      placement:
        after:
        - start
    tfm_storage:
      address: 0xf8000
      orig_span: &id008
      - tfm_ps
      - tfm_its
      span: *id008
    And here is the fixed partition layout, ie. one from ncs v2.3.0:
    EMPTY_0:
      address: 0xf6000
      placement:
        after:
        - settings_storage
    app:
      address: 0x4c000
    external_flash:
      address: 0x128000
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
      placement:
        align:
          start: 0x4000
        before:
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - app
      - mcuboot_pad
      - tfm
      span: *id001
    mcuboot_primary_1:
      address: 0x0
      region: ram_flash
      address: 0xc200
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x0
      placement:
        align:
          start: 0x4
      share_size:
      - mcuboot_primary
      address: 0xe8000
    mcuboot_sram:
      address: 0x20000000
      orig_span: &id003
      - pcd_sram
      - tfm_sram
      span: *id003
    nonsecure_storage:
      address: 0xf4000
      orig_span: &id004
      - settings_storage
      span: *id004
    otp:
      address: 0xff8100
      region: otp
    pcd_sram:
      address: 0x20000000
      placement:
        before:
        - tfm_sram
    ram_flash:
      address: 0x40000
      region: ram_flash
    rpmsg_nrf53_sram:
      address: 0x20070000
      placement:
        before:
        - end
    settings_storage:
      address: 0xf4000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x4000
        before:
        - tfm_storage
        - end
    sram_nonsecure:
      address: 0x20042000
      orig_span: &id005
      - sram_primary
      - rpmsg_nrf53_sram
      span: *id005
    sram_primary:
      address: 0x20042000
    sram_secure:
      address: 0x20000000
      orig_span: &id006
      - pcd_sram
      - tfm_sram
      span: *id006
    tfm:
      address: 0xc200
      end_address: 0x4c000
      inside:
      placement:
        before:
        - app
    tfm_its:
      address: 0xf8000
      inside:
      - tfm_storage
      placement:
        before:
    tfm_nonsecure:
      address: 0x4c000
      orig_span: &id007
      - app
      span: *id007
      address: 0xfa000
      inside:
      - tfm_storage
      placement:
        before:
        - tfm_ps
    tfm_ps:
      address: 0xfc000
      inside:
      - tfm_storage
      placement:
        align:
          start: 0x4000
        before:
        - end
    tfm_secure:
      address: 0xc000
      orig_span: &id008
      - mcuboot_pad
      - tfm
      span: *id008
    tfm_sram:
      address: 0x20002000
      inside:
      - sram_secure
      placement:
        after:
        - start
    tfm_storage:
      address: 0xf8000
      orig_span: &id009
      - tfm_ps
      - tfm_its
      span: *id009
    There are some id's and others that are different here, but the major difference are these:
    On the left hand side, all the 0x200 byte offsets are adjusted and rounded down to the correct base address.
    At this moment, I do not have any other fix than to manually adjust these. This can be done by adjusting your already present pm_static.yml, or generating a new build with NCS v2.3.0, and comparing this with your "old pm_static.yml" and adjusting accordingly.
    I have reported this issue internally and made the team aware of this migration issue.
    Håkon
  •  , can you please put a link to the PR here once this issue is fixed. I want to backport it immediately into my project. Thx
