How to avoid data collision in a network of NRF devices where only 2 NRF want to communicate with each other and others dont get this data ?
We are using NRF24L01 as a transreceiver. We have a network of NRF devices operating individually and we want one NRF to communicate only with its respective NRF. However the data collision happens during this. The NRFs in the network also receives this data despite keeping the different frequency.
We cant have multiple frequencies for our every product.
So, is there any way to avoid data collision / interference so that only 2 desired NRF will communicate with each other and other NRF devices in the network wpn't get that data ??
Thanks and Regards ,
Harshal
  • Hello Mr. Hung,
    1. The receiving address is configured using the RX_ADDR_P1 register (since we use data pipe 1) and sending address is configured using the TX_ADDR register. Also, RX_ADDR_P0 is set equal to the sending address for the Auto Acknowledgment to work.
    2.  We haven't configured the SETUP_AW register for address width setting but the Tx as well as Rx address is unique with the address length as 5 Bytes.
    3. We haven't set up the receiver (the other NRF in the pair of 2) as the PRX (Primary Receiver). Both the NRFs in the pair are configured as PTX only.  So, do we need to set up the the other NRF in the pair as the PRX or its okay to keep it as PTX ?
    4. Our application does not require NRFs to be in MultiCeiver mode; only one to one communication is needed withing the pair of 2 NRF devices where multiple such pairs of different frequency channel are present in the network.
    5. To have unique address is to have unique sending and receiving address for every device ?
    Thanks and Regards !!
    Harshal
  • Hi Harshal,
    I'm not so sure if you setup both devices as PTX, how would they managed to receive data from the peer ?
    Also could you clarify that each pair has their own unique address ? And you don't use the same address on different pairs ?
    You can either have unique address for each device, or at least should have unique address for each pair.
    No, each pair doesn't have unique address. Actually, the same address is being used for all the NRF devices in every pair. Its because we intend to establish a bidirectional communication.
    So, we need to have :-
    1. One NRF configured as PTX and the other as PRX from the pair of two.
    2.  Unique addresses for all the NRF devices.
    Also, the way we have configured the addresses as I mentioned in the point 1 and 2 from the last message; is it appropriate ?
    Thanks and Regards,
    Harshal
  • Hi Harshal,
    Yes both are correct.
    Regarding your point 1 and 2:
    This is fine. I assume you set RX_ADDR_P0 on the PTX to the same as TX_ADDR. This is correct.
    On the PRX , I don't know why you want to use pipe 1 instead of pipe 0 , but that's also OK.
    Yes, I assume you leave it untouched and the value of SETUP_AW is 11 - 5 bytes.
  • Thanks Mr. Hung,
    In our application, the transmitters in every pair can be exchanged or shuffled with any other receiver to form a pair so how do we maintain the communication where no cross talk will happen and we will have the portability of any transmitter communicating only with its respective receiver.
1 2 3 4 5 »
