NRF 52840 matter light bulb fail commissioning with Apple Home pod mini
I am trying to connect to nrf52840 light bulb example to apple home pod mini (support thread border router and matter) but it fails to connect and not able to commission.
I am able to scan QR code and finish all process but at last iphone shows "Unable to add accessory."
Below are versions I am using.
- IOS 16.3.1 , iPhone XS , Home Pod mini 16.3.2
- NRFconnect SDK 2.3.0 / matter/light bulb
will appreciate any help!
Thank you.
I am attaching log from nrf52840 and screen image from apple when it fails.
I: nRF5 802154 radio initialized
I: 4 Sectors of 4096 bytes
I: alloc wra: 1, df0
I: data wra: 1, 3c4
uart:~$ *** Booting Zephyr OS build v3.2.99-ncs2 ***
I: Init CHIP stack
I: 226 [DL]BLE address: E7:30:08:B0:80:A5
I: 237 [DL]OpenThread started: OK
I: 240 [DL]Setting OpenThread device type to ROUTER
I: 244 [SVR]Server initializing...
I: 248 [TS]Last Known Good Time: 2023-03-08T17:55:10
I: 254 [DMG]AccessControl: initializing
I: 257 [DMG]Examples::AccessControlDelegate::Init
I: 262 [DMG]AccessControl: setting
I: 265 [DMG]DefaultAclStorage: initializing
I: 269 [DMG]DefaultAclStorage: 0 entries loaded
D: 273 [IN]UDP::Init bind&listen port=5540
E: 277 [IN]SO_REUSEPORT failed: 109
D: 280 [IN]UDP::Init bound to port=5540
D: 284 [IN]BLEBase::Init - setting/overriding transport
D: 289 [IN]TransportMgr initialized
I: 299 [ZCL]Using ZAP configuration...
I: 306 [DMG]AccessControlCluster: initializing
I: 311 [ZCL]Initiating Admin Commissioning cluster.
I: 316 [ZCL]On/Off set value: 1 0
I: 319 [ZCL]On/off already set to new value
I: 324 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
D: 333 [IN]SecureSession[0x20003568]: Allocated Type:1 LSID:53955
I: 338 [DIS]Updating services using commissioning mode 1
I: 345 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
E: 354 [DIS]Failed to advertise commissionable node: 3
E: 359 [DIS]Failed to finalize service update: 1c
I: 363 [DIS]Updating services using commissioning mode 1
I: 369 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
E: 378 [DIS]Failed to advertise commissionable node: 3
E: 383 [DIS]Failed to finalize service update: 1c
I: 388 [DIS]Delaying proxy of operational discovery: missing delegate
I: 394 [IN]CASE Server enabling CASE session setups
D: 399 [IN]SecureSession[0x20003620]: Allocated Type:2 LSID:53956
I: 404 [SVR]Joining Multicast groups
I: 408 [SVR]Server Listening...
I: 411 [DL]Device Configuration:
I: 414 [DL]  Serial Number: 11223344556677889900
I: 419 [DL]  Vendor Id: 65521 (0xFFF1)
I: 422 [DL]  Product Id: 32773 (0x8005)
I: 426 [DL]  Hardware Version: 0
I: 430 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 436 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 443 [DL]  Manufacturing Date: (not set)
I: 447 [DL]  Device Type: 65535 (0xFFFF)
I: 452 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00]
I: 456 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 462 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00
I: 471 [SVR]Manual pairing code: [34970112332]
I: 477 [DL]CHIP task running
I: 481 [DL]CHIPoBLE advertising started
I: 486 [ZCL]Cluster OnOff: attribute OnOff set to 0
I: 491 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
I: 499 [DL]NFC Tag emulation started
I: 19264 [DL]BLE connection established (ConnId: 0x00)
I: 19269 [DL]Current number of connections: 1/1
I: 19273 [DL]CHIPoBLE advertising stopped
I: 19277 [DL]NFC Tag emulation stopped
W: Ignoring data for unknown channel ID 0x003a
I: 20235 [BLE]local and remote recv window sizes = 5
I: 20240 [BLE]selected BTP version 4
I: 20243 [BLE]using BTP fragment sizes rx 244 / tx 244.
D: 20415 [IN]BLE EndPoint 0x200124d8 Connection Complete
I: 20420 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
I: 20522 [EM]>>> [E:23196r M:372653] (U) Msg RX from 0:CF4070660F722737 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
I: 20535 [EM]<<< [E:23196r M:233392356] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
I: 20546 [IN](U) Sending msg 233392356 to IP address 'BLE'
I: 20702 [EM]>>> [E:23196r M:372654] (U) Msg RX from 0:CF4070660F722737 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
I: 22589 [EM]<<< [E:23196r M:233392357] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
I: 22600 [IN](U) Sending msg 233392357 to IP address 'BLE'
E: 22606 [DL]Long dispatch time: 1904 ms, for event type 16388
I: 22742 [EM]>>> [E:23196r M:372655] (U) Msg RX from 0:CF4070660F722737 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
I: 22753 [EM]<<< [E:23196r M:233392358] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 22764 [IN](U) Sending msg 233392358 to IP address 'BLE'
I: 22771 [SC]SecureSession[0x20003568]: Moving from state 'kEstablishing' --> 'kActive'
D: 22779 [IN]SecureSession[0x20003568]: Activated - Type:1 LSID:53955
D: 22785 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:53955 PSID:61964!
I: 22794 [SVR]Commissioning completed session establishment step
I: 22800 [DIS]Updating services using commissioning mode 0
I: 22807 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
E: 22816 [DIS]Failed to advertise extended commissionable node: 3
D: 22822 [DIS]Scheduling extended discovery timeout in 900s
E: 22827 [DIS]Failed to finalize service update: 1c
I: 22832 [SVR]Device completed Rendezvous process
I: 22863 [EM]>>> [E:23197r M:30365919] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 22873 [IM]Received Read request
I: 22878 [EM]<<< [E:23197r M:169276862] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 22888 [IN](S) Sending msg 169276862 on secure session with LSID: 53955
I: 22983 [EM]>>> [E:23198r M:30365920] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 22993 [IM]Received Read request
I: 23000 [EM]<<< [E:23198r M:169276863] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 23010 [IN](S) Sending msg 169276863 on secure session with LSID: 53955
I: 23223 [EM]>>> [E:23199r M:30365921] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 23233 [IM]Received Read request
I: 23238 [EM]<<< [E:23199r M:169276864] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 23248 [IN](S) Sending msg 169276864 on secure session with LSID: 53955
I: 23343 [EM]>>> [E:23200r M:30365922] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 23353 [IM]Received Read request
I: 23358 [EM]<<< [E:23200r M:169276865] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 23368 [IN](S) Sending msg 169276865 on secure session with LSID: 53955
I: 23463 [EM]>>> [E:23201r M:30365923] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 23473 [IM]Received Read request
I: 23480 [EM]<<< [E:23201r M:169276866] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 23490 [IN](S) Sending msg 169276866 on secure session with LSID: 53955
I: 23703 [EM]>>> [E:23202r M:30365924] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 23713 [IM]Received Read request
I: 23718 [EM]<<< [E:23202r M:169276867] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 23728 [IN](S) Sending msg 169276867 on secure session with LSID: 53955
I: 23823 [EM]>>> [E:23203r M:30365925] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 23833 [IM]Received Read request
I: 23843 [EM]<<< [E:23203r M:169276868] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 23853 [IN](S) Sending msg 169276868 on secure session with LSID: 53955
I: 24063 [EM]>>> [E:23204r M:30365926] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 24074 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 24081 [EM]<<< [E:23204r M:169276869] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 24092 [IN](S) Sending msg 169276869 on secure session with LSID: 53955
I: 24183 [EM]>>> [E:23205r M:30365927] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 24197 [EM]<<< [E:23205r M:169276870] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 24208 [IN](S) Sending msg 169276870 on secure session with LSID: 53955
I: 24303 [EM]>>> [E:23206r M:30365928] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 24314 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 24323 [EM]<<< [E:23206r M:169276871] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 24334 [IN](S) Sending msg 169276871 on secure session with LSID: 53955
I: 24663 [EM]>>> [E:23207r M:30365929] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 24674 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 24683 [EM]<<< [E:23207r M:169276872] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 24694 [IN](S) Sending msg 169276872 on secure session with LSID: 53955
I: 25023 [EM]>>> [E:23208r M:30365930] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 25034 [ZCL]OpCreds: Received an AttestationRequest command
I: 25070 [ZCL]OpCreds: AttestationRequest successful.
I: 25079 [EM]<<< [E:23208r M:169276873] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 25090 [IN](S) Sending msg 169276873 on secure session with LSID: 53955
I: 25443 [EM]>>> [E:23209r M:30365931] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 25454 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 25461 [EM]<<< [E:23209r M:169276874] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 25472 [IN](S) Sending msg 169276874 on secure session with LSID: 53955
I: 27423 [EM]>>> [E:23210r M:30365932] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 27434 [ZCL]OpCreds: Received a CSRRequest command
I: 27625 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 27661 [ZCL]OpCreds: CSRRequest successful.
I: 27668 [EM]<<< [E:23210r M:169276875] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 27679 [IN](S) Sending msg 169276875 on secure session with LSID: 53955
E: 27686 [DL]Long dispatch time: 265 ms, for event type 16388
I: 28024 [EM]>>> [E:23211r M:30365933] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 28035 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 28098 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 28104 [EM]<<< [E:23211r M:169276876] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 28115 [IN](S) Sending msg 169276876 on secure session with LSID: 53955
I: 28324 [EM]>>> [E:23212r M:30365934] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 28335 [ZCL]OpCreds: Received an AddNOC command
I: 28343 [FP]Validating NOC chain
I: 28404 [FP]NOC chain validation successful
I: 28408 [FP]Added new fabric at index: 0x1
I: 28412 [FP]Assigned compressed fabric ID: 0x64363021EF548DF2, node ID: 0x0000000063423C67
I: 28420 [TS]Last Known Good Time: 2023-03-08T17:55:10
I: 28425 [TS]New proposed Last Known Good Time: 2023-03-17T00:50:44
I: 28431 [TS]Updating pending Last Known Good Time to 2023-03-17T00:50:44
I: 28456 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x19BC2F7F10C4B1E6
I: 28465 [DIS]Advertise operational node 64363021EF548DF2-0000000063423C67
I: 28471 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
I: 28479 [EM]<<< [E:23212r M:169276877] (S) Msg TX to 1:FFFFFFFB00000000 [8DF2] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 28490 [IN](S) Sending msg 169276877 on secure session with LSID: 53955
E: 28497 [DL]Long dispatch time: 175 ms, for event type 16388
I: 28563 [EM]>>> [E:23213r M:30365935] (S) Msg RX from 1:FFFFFFFB00000000 [8DF2] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 28580 [EM]<<< [E:23213r M:169276878] (S) Msg TX to 1:FFFFFFFB00000000 [8DF2] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 28591 [IN](S) Sending msg 169276878 on secure session with LSID: 53955
I: 28683 [EM]>>> [E:23214r M:30365936] (S) Msg RX from 1:FFFFFFFB00000000 [8DF2] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 34664 [DL]SRP Client was started, detected server: fd34:bb1a:d920:0000:3c04:149e:dafc:011e
I: 34677 [EM]<<< [E:23214r M:169276879] (S) Msg TX to 1:FFFFFFFB00000000 [8DF2] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 34688 [IN](S) Sending msg 169276879 on secure session with LSID: 53955
I: 34695 [DIS]Advertise operational node 64363021EF548DF2-0000000063423C67
I: 34702 [SVR]Operational advertising enabled
I: 35128 [DIS]Setting operational delegate post init
I: 35136 [SWU]Stopping the watchdog timer
I: 35140 [SWU]Starting the periodic query timer, timeout: 86400 seconds
I: 35146 [DIS]Updating services using commissioning mode 0
I: 35152 [DIS]Advertise operational node 64363021EF548DF2-0000000063423C67
I: 35159 [DL]advertising srp service: 64363021EF548DF2-0000000063423C67._matter._tcp
I: 35168 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
I: 35177 [DL]advertising srp service: DD77A0E0FEDB0694._matterc._udp
