Support for TPMS in broadcast mode
Dear Team,
Currently we are using nrf2805 Nordic BLE IC. We are currently using only a small application code right now. But now we want to support some more features in our product like,
1. Capture TPMS(tire pressure monitor system) data which is running in broadcasting mode
2. FOTA functionality
3. Encryption / Security
4. multiple connections
Is it possible to integrate all of the above on our existing module? if not which module should we use as an upgrade?
Hitesh
  • Hi Hitesh,
    It is difficult to be specific without knowing the size of your application and which SDK you are using and which DFU transport you need, but generally DFU capabilities on the nRF52805 is limited by it's 192 kB flash.
    If I assume that you are using nRF5 SDK 17.1.0 and SoftDevice S112 and DFU over Bluetooth, the memory layout would look something like this you can see in  memory layout from the bootloader documentation, for nRF52810 (which has the same amount of flash). You may get one additional page for the application though, as you can skip the MBR params page and move the bootloader one page up (the MBR is only needed for bootloader and SoftDevice updates, but there is anyway not enough space to do a bootloader update. So with this configuration, you can fit an application of maximum  64 kB. I cannot say if it will be possible for you to implement your whole application in only 64 kB, though.
    Einar
