I have two project configurations one for debug and one for release. Dependent on configuration I want to select pm_static_board.yml or use default flash layout.
For this I created Kconfig file and added new config:
source "Kconfig.zephyr" config BUILD_CONFIGURATION_PRODUCT_DEBUG bool "Select MCU Flash Layout for Debug / Release"
In CMakeLists.tx added the following:
if(NOT CONFIG_BUILD_CONFIGURATION_PRODUCT_DEBUG)
set(PM_STATIC_YML_FILE
${CMAKE_CURRENT_SOURCE_DIR}/boards/pm_static_${BOARD}.yml
endif()
And in corresponding prj.conf I set or reset CONFIG_BUILD_CONFIGURATION_PRODUCT_DEBUG.
However seems that pm_static is added independent on config. If I comment out changes in CMakeLists.txt then pm_static is not added.
