Retrieve the Zigbee NWK key from a device on a network
In nRF Connect Zigbee SDK, I would like to read the network key from my Zigbee 3.0 device when it has joinded a network (or created one when being a coordinator). Is it possible to do so either with an API cmd or Shell/Cli ?
I've found out that it is actually possible to write a predefined NWK key before starting a network with this command zb_secur_setup_nwk_key() which is not intended to be used in prod., but can't manage to find the equivalent cmd to just read it.
Also, when the product is a TC, is there any way to retrieve programmatically the entries in the TCLK table? (I find only an "add", "set" and "remove" command)
Thank you in advance for your support!
