I mean what kind of header information and stuff besides the data. I could only find this for advertising packets.
A graphic or list like this would be nice:
byte 0-1 // byte 2-30 // byte 31
sendername // data // crc
and a citable source :)
Well citable source is easy: BT SIG specification 4.0 or higher;) If you mean "Handle Value Notification ATT method" it is standard PDU, isn't it? I'll leave these few drawings here but I believe you'd like to to get access to this presentation: original presentation by BT SIG from 2010 during official introduction of LE as part of BT 4.0 (member login required but registration is for free).
Cheers Jan
"Opcode" for "Handle Value Notification" ATT method is 0x1B. "Attribute Parameters" consists of 16-bit ATT handle number and actual data.
Thank you very much!
I was told that when using UART the payload is maximum 20 bytes per transmission. According to this graphic (m.eet.com/.../bluefig2.gif) it appears that the payload is up to 37 bytes large. If i substract the 6 bytes for payload length, L2CAP Length, 0x0004 (ATT) and Attribute Opcode I would expect to be left with roughly 31 bytes. Where do the missing 11 bytes per transmission in the UART app go?
Hi John, 20 bytes is available payload on top of GATT layer in case you are using default MTU size (ATT_MTU = 23 bytes, 3 bytes are GATT protocol overhead). I'm not sure how exactly NUS (Nordic's UART Service) works but with latest SoftDevice (Nordic BLE stack implementation) S132 V3.0.0 you can support larger ATT_MTU size. The topic discussed in my answer is living on lower (Link) layer and there PDU has always 37 bytes (just upper layers such as ATT can fragment and transport larger messages on top of them). The infographic in you hyperlink corresponds to first slide linked by me above. Have you seen the whole presentation I've suggested above? Do you have understanding how whole BT Smart stack works?
Cheers Jan
Unfortunately I was unable to see the presentation as it requires a membership, which is not available to individuals. Also, I indeed do not understand the BT smart stack in detail. My goal was document my work by drawing a graphic of the BT LE packet to visualize how much space my 8 bytes of data take up in the PDU and where they are located. To complete the graphic I wanted to also show the space available for further data. However, I am lacking the information what else is filling up the PDU. I will start reading into BT smart in more detail, which I was hoping I could avoid initially, but now seems to make sense. And thanks for your answer!
