Zigbee support on the micro:bit v2
I'm using Zephyr 3.2.99 via the nRF Connect SDK 2.3.0.
When I select the micro:bit v2 board (bbc_microbit_v2) and my `prj.conf` contains only `CONFIG_ZIGBEE=y` I get the following Kconfig warning:
warning: IEEE802154_NRF5_FCS_IN_LENGTH (defined at drivers/ieee802154/Kconfig.nrf5:65) has direct dependencies IEEE802154_NRF5 && IEEE802154 with value n, but is currently being y-selected by the following symbols:
- NET_L2_ZIGBEE (defined at C:/ncs/v2.3.0/nrf\subsys\zigbee/Kconfig:29), with value y, direct dependencies NETWORKING && ZIGBEE (value: y), and select condition NETWORKING && ZIGBEE (value: y)
It works if I select the nRF52833 DK board, which has the same SOC.
I believe it boils down to CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED not being enabled for the micro:bit. It clearly has a suitable radio, but is this a limitation of the micro:bit board that makes the radio unusable, or is this a Kconfig bug?
(Zephyr claims not be responsible, see https://github.com/zephyrproject-rtos/zephyr/issues/55894)
