matter with Seed XIAO nrf52840
I'm using Seeed XIAO nrf52840 and tried matter cluster as below.
I'm using master branch on Matter SDK.
https://github.com/project-chip/connectedhomeip/tree/master/examples/lighting-app/nrfconnect
I modified `boards/nrf52840dk_nrf52840.overlay` file as below.
	chosen {
		nordic,pm-ext-flash = &p25q16h_spi;
	* In some default configurations within the nRF Connect SDK,
	* e.g. on nRF52840, the chosen zephyr,entropy node is &cryptocell.
	* This devicetree overlay ensures that default is overridden wherever it
	* is set, as this application uses the RNG node for entropy exclusively.
/delete-property/ arduino_header;
/delete-property/ connector;
/delete-property/ arduino_adc;
/delete-property/ analog-connector;
/delete-property/ spi1;
/delete-property/ spi2;
/delete-property/ uart1;
/delete-property/ i2c0;
/delete-property/ arduino_serial;
/delete-property/ arduino_i2c;
/delete-node/ spi1;
/delete-node/ spi2;
/delete-node/ uart1;
/delete-node/ i2c0;
/delete-node/ arduino_serial;
/delete-node/ arduino_i2c;
	chosen {
		zephyr,entropy = &rng;
    leds {
            compatible = "gpio-leds";
            led0: led_0 {
                    gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
                    label = "Green LED 0";
            led1: led_1 {
                    gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
                    label = "Red LED 1";
            led2: led_2 {
                    gpios = <&gpio0 30 GPIO_ACTIVE_LOW>;
                    label = "Green LED 2";
            led3: led_3 {
                    gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
                    label = "Blue LED 3";
    buttons {
            compatible = "gpio-keys";
            button0: button_0 {
                    gpios = <&gpio1 15 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
                    label = "Push button switch 0";
            button1: button_1 {
                    gpios = <&gpio1 14 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
                    label = "Push button switch 1";
            button2: button_2 {
                    gpios = <&gpio0 2 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
                    label = "Push button switch 2";
            button3: button_3 {
                    gpios = <&gpio0 3 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
                    label = "Push button switch 3";
	* By default, PWM module is only configured for led0 (LED1 on the board).
	* The lighting-app, however, uses LED2 to show the state of the lighting,
	* including its brightness level.
	aliases {
		pwm-led1 = &pwm_led1;
	pwmleds {
		pwm_led1: pwm_led_1 {
			pwms = <&pwm0 1 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
&pwm0 {
	pinctrl-0 = <&pwm0_default_alt>;
	pinctrl-1 = <&pwm0_sleep_alt>;
&uart0{
	/delete-property/ rts-pin;
	/delete-property/ cts-pin;
	/delete-property/ hw-flow-control;
&pinctrl {
	pwm0_default_alt: pwm0_default_alt {
		group1 {
			psels = <NRF_PSEL(PWM_OUT1, 0, 26)>;
			nordic,invert;
	pwm0_sleep_alt: pwm0_sleep_alt {
		group1 {
			low-power-enable;
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 1, 11)>,
				<NRF_PSEL(UART_RX, 1, 12)>;
	uart0_sleep: uart0_sleep {
		group1 {
			low-power-enable;
    spi3_default: spi3_default {
            group1 {
                    psels = <NRF_PSEL(SPIM_SCK, 0, 21)>,
                            <NRF_PSEL(SPIM_MOSI, 0, 20)>,
                            <NRF_PSEL(SPIM_MISO, 0, 24)>;
    spi3_sleep: spi3_sleep {
            group1 {
                    low-power-enable;
    qspi_default: qspi_default {
            group1 {
                    psels = <NRF_PSEL(QSPI_SCK, 0, 21)>,
                            <NRF_PSEL(QSPI_IO0, 0, 20)>,
                            <NRF_PSEL(QSPI_IO1, 0, 24)>,
                            <NRF_PSEL(QSPI_IO2, 0, 22)>,
                            <NRF_PSEL(QSPI_IO3, 0, 23)>,
                            <NRF_PSEL(QSPI_CSN, 0, 25)>;
    qspi_sleep: qspi_sleep {
            group1 {
                    low-power-enable;
&spi3 {
        status = "okay";
        pinctrl-0 = <&spi3_default>;
        pinctrl-1 = <&spi3_sleep>;
        cs-gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
        p25q16h_spi: p25q16h@0 {
                compatible = "jedec,spi-nor";
                reg = <0>;
                wp-gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
                hold-gpios = <&gpio0 23 GPIO_ACTIVE_LOW>;
                spi-max-frequency = <104000000>;
                jedec-id = [85 60 15];
                sfdp-bfp = [
                        e5 20 f1 ff  ff ff ff 00  44 eb 08 6b  08 3b 80 bb
                        ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
                        10 d8 08 81
                size = <16777216>;
                has-dpd;
                t-enter-dpd = <3000>;
                t-exit-dpd = <8000>;
and I modified `configuration/nrf52840dk_nrf52840/pm_static_dfu.yml` as below.
mcuboot:
    address: 0x0
    region: flash_primary
mcuboot_pad:
    address: 0x7000
app:
    address: 0x7200
mcuboot_primary:
    orig_span: &id001
        - mcuboot_pad
        - app
    span: *id001
    address: 0x7000
mcuboot_primary_app:
    orig_span: &id002
        - app
    span: *id002
    address: 0x7200
factory_data:
    address: 0xfb000
settings_storage:
    address: 0xfc000
mcuboot_secondary:
    address: 0x0
    device: p25q16h_spi
    region: external_flash
external_flash:
    address: 0xf4000
    device: p25q16h_spi
I built with command `west build -b nrf52840dk_nrf52840`.
Then, below error occurred.
/home/muto/gcc-arm/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.bfd: modules/nrf/subsys/dfu/dfu_target/lib..__nrf__subsys__dfu__dfu_target.a(dfu_target_mcuboot.c.obj): in function `dfu_target_mcuboot_init':
/home/muto/ncs/nrf/subsys/dfu/dfu_target/src/dfu_target_mcuboot.c:153: undefined reference to `__device_dts_ord_137'
/home/muto/gcc-arm/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/libzephyr.a(flash_map_partition_manager.c.obj):(.rodata.default_flash_map+0x1c): undefined reference to `__device_dts_ord_137'
/home/muto/gcc-arm/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/libzephyr.a(flash_map_partition_manager.c.obj):(.rodata.default_flash_map+0x6c): undefined reference to `__device_dts_ord_137'
collect2: error: ld returned 1 exit status
how do I resolve it?
  • YES, I'm using Seeed XIAO BLE board.
    As my understanding, Seeed XIAO BLE and nRF52840DK are using nRF52840.
    I understand pin assign and QSPI memory are different.
    However, I believe those differences can be absorbed in the overlay file.
    Because, I could build below command with above "boards/nrf52840dk_nrf52840.overlay" file.
    LEDs and buttons are specified by this overlay file. there are working.
    $ west build -b nrf52840dk_nrf52840 -- -DCONF_FILE=prj_no_dfu.conf
    https://github.com/project-chip/connectedhomeip/tree/master/examples/lighting-app/nrfconnect#building-with-device-firmware-upgrade-support
    Therefore, I would like to re-assign QSPI memroy.
    Good.
    Take a look at this example
    -Amanda H.
    I tied it, but I cannot build it.
    I think "boards/nrf52840dk_nrf52840.overlay" file is OK.
    but, "child_image/mcuboot/boards/nrf52840dk_nrf52840.overlay" may have problem.
    Error message:
    [169/179] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/muto/matter/matter-master-20230315/examples/lighting-app/nrfconnect/build/mcuboot/zephyr/zephyr_pre0.map
    : && ccache /home/muto/gcc-arm/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/muto/matter/matter-master-20230315/examples/lighting-app/nrfconnect/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/timer/libdrivers__timer.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/muto/gcc-arm/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/thumb/v7e-m+fp/hard"  -L/home/muto/matter/matter-master-20230315/examples/lighting-app/nrfconnect/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -no-pie  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -mfloat-abi=hard  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  /home/muto/ncs/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.16.a  /home/muto/ncs/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /home/muto/matter/matter-master-20230315/examples/lighting-app/nrfconnect/build/mcuboot/zephyr && /usr/bin/cmake -E echo
    /home/muto/gcc-arm/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/libzephyr.a(flash_map_partition_manager.c.obj):(.rodata.default_flash_map+0x1c): undefined reference to `__device_dts_ord_131'
    /home/muto/gcc-arm/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/libzephyr.a(flash_map_partition_manager.c.obj):(.rodata.default_flash_map+0x6c): undefined reference to `__device_dts_ord_131'
    	chosen {
    /delete-node/ spi1;
    /delete-node/ spi2;
    /delete-node/ i2c0;
    	chosen {
            leds {
                    led0: led_0 {
                    led1: led_1 {
                    led2: led_2 {
                    led3: led_3 {
            buttons {
                    button0: button_0 {
                    button1: button_1 {
                    button2: button_2 {
                    button3: button_3 {
    	aliases {
    	pwmleds {
    /delete-node/ &i2c0;
    /delete-node/ &spi1;
    /delete-node/ &spi2;
    /delete-node/ &uart1;
    &pwm0 {
    &uart0{
    &pinctrl {
    		group1 {
    			nordic,invert;
    		group1 {
    			low-power-enable;
    		group1 {
                    group1 {
                            low-power-enable;
            i2c1_default: i2c1_default {
                    group1 {
                            psels = <NRF_PSEL(TWIM_SDA, 0, 4)>,
                                    <NRF_PSEL(TWIM_SCL, 0, 5)>;
            i2c1_sleep: i2c1_sleep {
                    group1 {
                            low-power-enable;
            spi0_default: spi0_default {
                    group1 {
                            psels = <NRF_PSEL(SPIM_SCK, 1, 13)>,
                                    <NRF_PSEL(SPIM_MOSI, 1, 15)>,
                                    <NRF_PSEL(SPIM_MISO, 1, 14)>;
            spi0_sleep: spi0_sleep {
                    group1 {
                            low-power-enable;
                    group1 {
                    group1 {
                            low-power-enable;
                    group1 {
                    group1 {
                            low-power-enable;
    &spi3 {
            status = "okay";
                    reg = <0>;
                    sfdp-bfp = [
                            10 d8 08 81
                    size = <16777216>;
                    has-dpd;
    	chosen {
    &pinctrl {
                    group1 {
                    group1 {
                            low-power-enable;
                    group1 {
                    group1 {
                            low-power-enable;
    &spi3 {
            status = "okay";
                    reg = <0>;
                    sfdp-bfp = [
                            10 d8 08 81
                    size = <16777216>;
                    has-dpd;
    To work with matter, the p25q16h should be used as the QSPI memory.
    Try this "boards/nrf52840dk_nrf52840.overlay"
    /delete-node/ &mx25r64;
    	chosen {
    	/* These aliases are provided for compatibility with samples */
    	aliases {
    		spi-flash0 = &p25q16h_spi;
    /delete-node/ spi1;
    /delete-node/ spi2;
    /delete-node/ i2c0;
    	chosen {
            leds {
                    led0: led_0 {
                    led1: led_1 {
                    led2: led_2 {
                    led3: led_3 {
            buttons {
                    button0: button_0 {
                    button1: button_1 {
                    button2: button_2 {
                    button3: button_3 {
    	aliases {
    	pwmleds {
    &pwm0 {
    &uart0{
    &pinctrl {
    		group1 {
    			nordic,invert;
    		group1 {
    			low-power-enable;
    		group1 {
                    group1 {
                            low-power-enable;
                    group1 {
                    group1 {
                            low-power-enable;
                    group1 {
                    group1 {
                            low-power-enable;
                    group1 {
                    group1 {
                            low-power-enable;
                    group1 {
                    group1 {
                            low-power-enable;
    &qspi {
            status = "okay";
            pinctrl-0 = <&qspi_default>;
            pinctrl-1 = <&qspi_sleep>;
                    compatible = "nordic,qspi-nor";
                    reg = <0>;
                    sck-frequency = <2000000>;
                    sfdp-bfp = [
                            10 d8 08 81
                    size = <16777216>;
                    has-dpd;
    	chosen {
    	aliases {
    &pinctrl {
                    group1 {
                    group1 {
                            low-power-enable;
    &qspi {
            status = "okay";
                    reg = <0>;
                    sfdp-bfp = [
                            10 d8 08 81
                    size = <16777216>;
                    has-dpd;
    Also add child_image/mcuboot/boards/nrf52840dk_nrf52840.conf with this config
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    Hope this can help.
    -Amanda H.
