how to perform direct test mode
Is there an explanation of how to perform a direct test mode?
I see it is partially explained here and here.
but it is unclear how to connect everything when and how to use the DTM in the NRF connect desktop app
do I need 2 NRF devices or is one enough?
in case of 2 NRF devices are required, do both of them need to run the same code nRF5_SDK_12.3.0_d7731ad\examples\ble_central_and_peripheral\ble_connectivity\pca10040\ser_s132_uart\iar\ble_connectivity_s132_uart_pca10040.ewp ?
are both of them need to be wired to a UART dongle (to the computer) or to each other?
I'm using NRF52832 board, and SDK nRF5_SDK_12.3.0_d7731ad
    If you want to test the transfer and receiver, then you would need two DKs.
    You should use <InstallFolder>\examples\dtm\direct_test_mode.
    Connect to PC.
    Are you using the custom board or nRF52DK?
    I would suggest the latest version of nRF5 SDK v17.1.0 or DTM of nRFConnect for Desktop (for nRF52DK).
    Amanda H.
  • thanks for the answer.
    I downloaded the new SDK and downloaded to the board the direct_test_mode_pca10040 project from:
    nRF5_SDK_17.1.0_ddde560\nRF5_SDK_17.1.0_ddde560\examples\dtm\direct_test_mode\pca10040\blank\iar\direct_test_mode_pca10040.ewp
    I'm using a modified version, I checked that the UART pins that I'm using which are
    #define UART1_MDMRX_BLETX_PIN               6   // Input  pin #22, p0.6, UART Tx
    #define UART1_MDMTX_BLERX_PIN               8   // Input  pin #24, p0.8, UART Rx
    and from what I have seen this is what the example code is using (correct me if I am wrong)
    is there anything else I need to check before performing the test?
    I connected the 2 devices to UART dongles both RX & TX. I previously checked that the UART works with another code and Tera Term.
    I followed the gif from the DTM repo
    opened 2 DTM windows, and select each DTM window with a different board.
    set 1 as a transmitter, channel mode=sweep, transmit os channel 37 to 26 (the rest are the default values)
    the other one is set as a receiver, channel mode=sweep, transmit os channel 37 to 39 (the rest are the default values)
    As I press start test I immediately get:
    starting test
    End test failed: Could not start transmission.
    ending test
    starting test
    End test failed: Could not start receiver.
    ending test
    what more should I check before starting the test?
    Are you using nRF52DK or a custom board?
    When using the nRF Connect Direct Test Mode app, please program the pre-compiled image for DK as the tool requests.
    -Amanda H.
