I am trying to use The GSM PPP sample with MQTT and TLS, I manage to get the NET_L4_CONNECTED event but I cant connect to the broker. I had tested the same broker with other platfroms and it works fine with TLS. My GSM modem is SIM800A connected over UART wit h NRF52840 and I tried both offloading and MBEDTLS, I get Similar results.
I managed to connect to the same broker in the past using the same setup but over insecure transport. It's RabbitMQ with the MQTT plugin if its somehow relevent.
Here is my conf file
Then The log output is:....GSM STARTUP LOGS .....Then:00> [00:00:35.313,446] <inf> sample_gsm_ppp: ###################################### Network connected ######################################
00> [00:00:35.314,666] <dbg> net_conn: conn_register_debug: (): [0x2000d818/6/1/0x3f] remote "The IP address of my server"/8883
00> [00:00:35.314,727] <dbg> net_conn: conn_register_debug: (): local 0.0.0.0/47228 cb 0x15bbd ud 0x2000d43c
00> [00:00:35.783,142] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:00:35.783,203] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:00:35.783,386] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:35.783,477] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 47228 family 1
00> [00:00:35.783,508] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:35.789,276] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:35.795,593] <inf> net_mqtt_publisher_sample: mqtt_connect -22
00> [00:00:35.884,948] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:00:35.885,009] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:00:35.885,192] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:35.885,284] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 47228 family 1
00> [00:00:35.885,314] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:35.885,437] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:36.203,491] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:00:36.203,582] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:00:36.203,735] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:36.203,826] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 47228 family 1
00> [00:00:36.203,857] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:36.209,655] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:36.382,629] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:00:36.382,720] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:00:36.382,873] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:36.382,965] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 47228 family 1
00> [00:00:36.382,995] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:36.383,117] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:37.883,178] <dbg> net_conn: net_conn_unregister: (tcp_work): Connection handler 0x2000d818 removed
00> [00:00:43.796,722] <dbg> net_conn: conn_register_debug: (): [0x2000d818/6/1/0x3f] remote "The IP address of my server"/8883
00> [00:00:43.796,783] <dbg> net_conn: conn_register_debug: (): local 0.0.0.0/44109 cb 0x15bbd ud 0x2000d43c
00> [00:00:44.484,222] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:00:44.484,313] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:00:44.484,466] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:44.484,558] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 44109 family 1
00> [00:00:44.484,588] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:44.490,234] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:44.496,032] <inf> net_mqtt_publisher_sample: mqtt_connect -22
00> [00:00:44.544,830] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:00:44.544,891] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:00:44.545,074] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:44.545,166] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 44109 family 1
00> [00:00:44.545,196] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:44.545,318] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:44.885,070] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:00:44.885,131] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:00:44.885,314] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:44.885,406] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 44109 family 1
00> [00:00:44.885,437] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:44.891,021] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:45.023,651] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:00:45.023,712] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:00:45.023,895] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:45.023,956] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 44109 family 1
00> [00:00:45.024,017] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:45.024,108] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:46.524,169] <dbg> net_conn: net_conn_unregister: (tcp_work): Connection handler 0x2000d818 removed
00> [00:00:52.497,161] <dbg> net_conn: conn_register_debug: (): [0x2000d818/6/1/0x3f] remote "The IP address of my server"/8883
00> [00:00:52.497,222] <dbg> net_conn: conn_register_debug: (): local 0.0.0.0/33755 cb 0x15bbd ud 0x2000d43c
00> [00:00:53.184,692] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:00:53.184,753] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:00:53.184,906] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:53.184,997] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 33755 family 1
00> [00:00:53.185,058] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:53.190,826] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:53.196,990] <inf> net_mqtt_publisher_sample: mqtt_connect -22
00> [00:00:53.244,934] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:00:53.245,025] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:00:53.245,208] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:53.245,269] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 33755 family 1
00> [00:00:53.245,330] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:53.245,422] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:53.603,912] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:00:53.603,973] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:00:53.604,156] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:53.604,217] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 33755 family 1
00> [00:00:53.604,278] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:53.610,137] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:53.784,271] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:00:53.784,332] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:00:53.784,515] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:00:53.784,606] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 33755 family 1
00> [00:00:53.784,637] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:00:53.784,759] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:00:55.284,790] <dbg> net_conn: net_conn_unregister: (tcp_work): Connection handler 0x2000d818 removed
00> [00:01:01.198,120] <dbg> net_conn: conn_register_debug: (): [0x2000d818/6/1/0x3f] remote "The IP address of my server"/8883
00> [00:01:01.198,181] <dbg> net_conn: conn_register_debug: (): local 0.0.0.0/49579 cb 0x15bbd ud 0x2000d43c
00> [00:01:01.908,294] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:01:01.908,355] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:01:01.908,538] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:01.908,630] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 49579 family 1
00> [00:01:01.908,660] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:01.914,184] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:01.919,921] <inf> net_mqtt_publisher_sample: mqtt_connect -22
00> [00:01:01.944,854] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:01:01.944,915] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:01:01.945,098] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:01.945,190] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 49579 family 1
00> [00:01:01.945,220] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:01.945,312] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:02.304,260] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:01:02.304,321] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:01:02.304,504] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:02.304,595] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 49579 family 1
00> [00:01:02.304,626] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:02.310,119] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:02.484,466] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:01:02.484,527] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:01:02.484,710] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:02.484,802] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 49579 family 1
00> [00:01:02.484,832] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:02.484,985] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:03.985,015] <dbg> net_conn: net_conn_unregister: (tcp_work): Connection handler 0x2000d818 removed
00> [00:01:09.921,051] <dbg> net_conn: conn_register_debug: (): [0x2000d818/6/1/0x3f] remote "The IP address of my server"/8883
00> [00:01:09.921,112] <dbg> net_conn: conn_register_debug: (): local 0.0.0.0/52204 cb 0x15bbd ud 0x2000d43c
00> [00:01:10.626,678] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:01:10.626,739] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:01:10.626,922] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:10.626,983] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 52204 family 1
00> [00:01:10.627,044] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:10.632,629] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:10.638,458] <inf> net_mqtt_publisher_sample: mqtt_connect -22
00> [00:01:10.669,036] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:01:10.669,097] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:01:10.669,281] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:10.669,372] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 52204 family 1
00> [00:01:10.669,403] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:10.669,525] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:11.006,652] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:01:11.006,713] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:01:11.006,896] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:11.006,988] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 52204 family 1
00> [00:01:11.007,019] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:11.007,141] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:11.046,539] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:01:11.046,600] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:01:11.046,783] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:11.046,844] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 52204 family 1
00> [00:01:11.046,905] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:11.052,490] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:11.184,814] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:01:11.184,875] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:01:11.185,058] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:11.185,119] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 52204 family 1
00> [00:01:11.185,180] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:11.185,272] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:12.685,333] <dbg> net_conn: net_conn_unregister: (tcp_work): Connection handler 0x2000d818 removed
00> [00:01:18.639,617] <dbg> net_conn: conn_register_debug: (): [0x2000d818/6/1/0x3f] remote "The IP address of my server"/8883
00> [00:01:18.639,648] <dbg> net_conn: conn_register_debug: (): local 0.0.0.0/53708 cb 0x15bbd ud 0x2000d43c
00> [00:01:19.346,069] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:01:19.346,160] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:01:19.346,313] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:19.346,405] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 53708 family 1
00> [00:01:19.346,435] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:19.352,050] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:19.357,940] <inf> net_mqtt_publisher_sample: mqtt_connect -22
00> [00:01:19.406,127] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 46
00> [00:01:19.406,188] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 46
00> [00:01:19.406,372] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:19.406,463] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 53708 family 1
00> [00:01:19.406,494] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:19.406,616] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:19.706,207] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:01:19.706,268] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:01:19.706,451] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:19.706,542] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 53708 family 1
00> [00:01:19.706,573] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:19.712,188] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:19.987,030] <dbg> net_core: net_recv_data: (ppp_workq): prio 0 iface 0x20000cd8 pkt 0x2002d810 len 42
00> [00:01:19.987,121] <dbg> net_core: net_rx: (rx_q[0]): Received pkt 0x2002d810 len 42
00> [00:01:19.987,274] <dbg> net_ipv4: net_ipv4_input: (rx_q[0]): IPv4 packet received from "The IP address of my server" to 100.118.237.221
00> [00:01:19.987,365] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002d810 src port 8883 dst port 53708 family 1
00> [00:01:19.987,396] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x2000d818] match found cb 0x15bbd ud 0x2000d43c rank 0x3f
00> [00:01:19.987,518] <dbg> net_core: processing_data: (rx_q[0]): Dropping pkt 0x2002d810
00> [00:01:21.487,579] <dbg> net_conn: net_conn_unregister: (tcp_work): Connection handler 0x2000d818 removedI am down to give the support in NRF a temp account on my server to verify it works with other platforms.I include the CA cert like this :
and
I get Success when I call tls_init
my Client start is :
Any support on this is appricated.
