I have an error when I enable CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS=y for fota.
[00:11:19.945,312] <dbg> aws_fota_netfeasa: job_update_accepted: Job document was updated with status IN_PROGRESS [00:11:19.945,465] <dbg> aws_iot_netfeasa: mqtt_evt_handler: MQTT_EVT_PUBACK: id = 15010 result = 0 [00:11:19.945,495] <dbg> aws_iot_integration: aws_iot_event_handler: AWS_IOT_EVT_PUBACK [00:11:19.945,739] <wrn> cbprintf_package: (unsigned) char * used for %p argument. It's recommended to cast it to void * because it may cause misbehavior in certain configurations. String:"%s: Receiving up to %d bytes at %p..." argument:2 [00:11:19.945,770] <dbg> download_client: download_thread: Receiving up to 2300 bytes at 0x2000c964... [00:11:20.391,998] <dbg> download_client: download_thread: Read 459 bytes from socket [00:11:20.392,089] <dbg> download_client: http_header_parse: GET header size: 459 [00:11:20.392,303] <dbg> download_client: http_header_parse: File size = 371099 [00:11:20.392,456] <wrn> cbprintf_package: (unsigned) char * used for %p argument. It's recommended to cast it to void * because it may cause misbehavior in certain configurations. String:"%s: Receiving up to %d bytes at %p..." argument:2 [00:11:20.392,486] <dbg> download_client: download_thread: Receiving up to 2300 bytes at 0x2000c964... [00:11:20.718,231] <dbg> download_client: download_thread: Read 708 bytes from socket [00:11:20.718,353] <wrn> cbprintf_package: (unsigned) char * used for %p argument. It's recommended to cast it to void * because it may cause misbehavior in certain configurations. String:"%s: Receiving up to %d bytes at %p..." argument:2 [00:11:20.718,383] <dbg> download_client: download_thread: Receiving up to 1592 bytes at 0x2000cc28... [00:11:20.826,507] <dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -75 [00:11:20.942,993] <dbg> download_client: download_thread: Read 316 bytes from socket [00:11:20.942,993] <inf> download_client: Downloaded 1024/371099 bytes (0%) [00:11:21.066,040] <inf> fota_download: Refuse fragment, restart with offset [00:11:21.066,070] <inf> download_client: Fragment refused, download stopped. [00:11:21.826,599] <dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -75 [00:11:22.941,894] <dbg> download_client: client_connect: Protocol not specified, defaulting to HTTP(S) [00:11:22.941,955] <dbg> download_client: client_connect: Port not specified, using default: 80 [00:11:22.941,955] <dbg> download_client: client_connect: family: 1, type: 1, proto: 6 [00:11:22.942,413] <inf> download_client: Connecting to nosensor.s3.eu-west-1.amazonaws.com [00:11:22.942,443] <dbg> download_client: client_connect: fd 1, addrlen 8, fam IPv4, port 80 [00:11:23.089,202] <inf> download_client: Downloading: app_update.bin [371099] [00:11:23.089,233] <inf> fota_download: Downloading from offset: 0x5a99b [00:11:23.089,477] <wrn> cbprintf_package: (unsigned) char * used for %p argument. It's recommended to cast it to void * because it may cause misbehavior in certain configurations. String:"%s: Receiving up to %d bytes at %p..." argument:2 [00:11:23.089,508] <dbg> download_client: download_thread: Receiving up to 2300 bytes at 0x2000c964... [00:11:27.049,163] <dbg> download_client: download_thread: Read 288 bytes from socket [00:11:27.049,255] <dbg> download_client: http_header_parse: GET header size: 288 [00:11:27.049,377] <err> download_client: Unexpected HTTP response: 416 requested range not satisfiable [00:11:27.049,957] <err> fota_download: Download client error [00:11:28.354,675] <inf> dfu_target_mcuboot: MCUBoot image upgrade aborted. [00:11:28.354,705] <err> aws_fota_netfeasa: FOTA_DOWNLOAD_EVT_ERROR [00:11:28.354,736] <dbg> aws_fota_netfeasa: save_validate_status: save_validate_status() - 89, 6, 5 [00:11:29.566,314] <dbg> aws_fota_netfeasa: update_job_execution: update_job_execution(),job_id: 89 status: 3, version_number: 124 [00:11:29.566,619] <dbg> aws_jobs_netfeasa: aws_jobs_netfeasa_update_job_execution: result2 1 [00:11:29.566,955] <dbg> aws_jobs_netfeasa: publish: Publish topic: $aws/things/352656106648283/jobs/89/update [00:11:29.567,016] <dbg> aws_jobs_netfeasa: publish: Publish payload {"status":"FAILED","expectedVersion":"89","clientToken":"","statusDetails":"Error during download"} [00:11:29.569,000] <dbg> aws_iot_netfeasa: aws_fota_cb_handler: 0000000 2 [00:11:29.569,030] <err> aws_iot_netfeasa: AWS_FOTA_EVT_ERROR
CONFIG_UART_INTERRUPT_DRIVEN=y # # Asset Tracker v2 # CONFIG_ASSET_TRACKER_V2_APP_VERSION="0.0.0-development" CONFIG_ASSET_TRACKER_V2_APP_VERSION_MAX_LEN=150 # CONFIG_MODULES_COMMON_LOG_LEVEL_OFF is not set # CONFIG_MODULES_COMMON_LOG_LEVEL_ERR is not set # CONFIG_MODULES_COMMON_LOG_LEVEL_WRN is not set CONFIG_MODULES_COMMON_LOG_LEVEL_INF=y # CONFIG_MODULES_COMMON_LOG_LEVEL_DBG is not set CONFIG_MODULES_COMMON_LOG_LEVEL=3 CONFIG_CLOUD_MODULE=y CONFIG_NRF_CLOUD_AGPS=y CONFIG_MQTT_CLEAN_SESSION=y CONFIG_CLOUD_THREAD_STACK_SIZE=2688 # CONFIG_CLOUD_CLIENT_ID_USE_CUSTOM is not set CONFIG_CLOUD_CONNECT_RETRIES=10 # CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_OFF is not set # CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_ERR is not set # CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_WRN is not set # CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_INF is not set CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_DBG=y CONFIG_CLOUD_INTEGRATION_LOG_LEVEL=4 # CONFIG_CLOUD_MODULE_LOG_LEVEL_OFF is not set # CONFIG_CLOUD_MODULE_LOG_LEVEL_ERR is not set # CONFIG_CLOUD_MODULE_LOG_LEVEL_WRN is not set CONFIG_CLOUD_MODULE_LOG_LEVEL_INF=y # CONFIG_CLOUD_MODULE_LOG_LEVEL_DBG is not set CONFIG_CLOUD_MODULE_LOG_LEVEL=3 CONFIG_DATA_MODULE=y # CONFIG_DATA_SEND_ALL_DEVICE_CONFIGURATIONS is not set CONFIG_DATA_THREAD_STACK_SIZE=5248 CONFIG_DATA_GNSS_BUFFER_COUNT=10 CONFIG_DATA_SENSOR_BUFFER_COUNT=10 CONFIG_DATA_MODEM_DYNAMIC_BUFFER_COUNT=3 CONFIG_DATA_UI_BUFFER_COUNT=3 CONFIG_DATA_IMPACT_BUFFER_COUNT=1 CONFIG_DATA_BATTERY_BUFFER_COUNT=3 CONFIG_DATA_GNSS_BUFFER_STORE=y CONFIG_DATA_SENSOR_BUFFER_STORE=y CONFIG_DATA_DYNAMIC_MODEM_BUFFER_STORE=y CONFIG_DATA_BATTERY_BUFFER_STORE=y CONFIG_DATA_UI_BUFFER_STORE=y CONFIG_DATA_DEVICE_MODE_ACTIVE=y # CONFIG_DATA_DEVICE_MODE_PASSIVE is not set CONFIG_DATA_ACTIVE_TIMEOUT_SECONDS=180 CONFIG_DATA_MOVEMENT_RESOLUTION_SECONDS=120 CONFIG_DATA_MOVEMENT_TIMEOUT_SECONDS=3600 CONFIG_DATA_ACCELEROMETER_ACT_THRESHOLD=4 CONFIG_DATA_ACCELEROMETER_INACT_THRESHOLD=4 CONFIG_DATA_ACCELEROMETER_INACT_TIMEOUT_SECONDS=60 CONFIG_DATA_LOCATION_TIMEOUT_SECONDS=300 CONFIG_DATA_SAMPLE_GNSS_DEFAULT=y CONFIG_DATA_SAMPLE_NEIGHBOR_CELLS_DEFAULT=y # CONFIG_DATA_GRANT_SEND_ON_CONNECTION_QUALITY is not set # CONFIG_DATA_MODULE_LOG_LEVEL_OFF is not set # CONFIG_DATA_MODULE_LOG_LEVEL_ERR is not set # CONFIG_DATA_MODULE_LOG_LEVEL_WRN is not set # CONFIG_DATA_MODULE_LOG_LEVEL_INF is not set CONFIG_DATA_MODULE_LOG_LEVEL_DBG=y CONFIG_DATA_MODULE_LOG_LEVEL=4 CONFIG_LOCATION_MODULE=y CONFIG_LOCATION_MODULE_NEIGHBOR_CELLS_DATA_CONVERT_RSRP_TO_DBM=y CONFIG_LOCATION_MODULE_NEIGHBOR_CELLS_DATA_CONVERT_RSRQ_TO_DB=y CONFIG_LOCATION_METHOD_GNSS_AGPS_EXTERNAL=y CONFIG_LOCATION_METHOD_CELLULAR_EXTERNAL=y # CONFIG_LOCATION_MODULE_LOG_LEVEL_OFF is not set # CONFIG_LOCATION_MODULE_LOG_LEVEL_ERR is not set # CONFIG_LOCATION_MODULE_LOG_LEVEL_WRN is not set # CONFIG_LOCATION_MODULE_LOG_LEVEL_INF is not set CONFIG_LOCATION_MODULE_LOG_LEVEL_DBG=y CONFIG_LOCATION_MODULE_LOG_LEVEL=4 CONFIG_MODEM_MODULE=y CONFIG_MODEM_SEND_ALL_SAMPLED_DATA=y CONFIG_MODEM_THREAD_STACK_SIZE=2048 CONFIG_MODEM_AUTO_REQUEST_POWER_SAVING_FEATURES=y CONFIG_MODEM_DYNAMIC_DATA_CONVERT_RSRP_TO_DBM=y CONFIG_MODEM_APN_LEN_MAX=30 # CONFIG_MODEM_MODULE_LOG_LEVEL_OFF is not set # CONFIG_MODEM_MODULE_LOG_LEVEL_ERR is not set # CONFIG_MODEM_MODULE_LOG_LEVEL_WRN is not set # CONFIG_MODEM_MODULE_LOG_LEVEL_INF is not set CONFIG_MODEM_MODULE_LOG_LEVEL_DBG=y CONFIG_MODEM_MODULE_LOG_LEVEL=4 CONFIG_SENSOR_MODULE=y CONFIG_SENSOR_THREAD_STACK_SIZE=4096 CONFIG_EXTERNAL_SENSORS=y # CONFIG_EXTERNAL_SENSORS_IMPACT_DETECTION is not set # CONFIG_EXTERNAL_SENSORS_BME680_BSEC is not set # CONFIG_EXTERNAL_SENSORS_HALLEFFECT is not set # CONFIG_EXTERNAL_SENSORS_OPTICAL_DETECT is not set # CONFIG_EXTERNAL_SENSORS_YIC_GNSS is not set CONFIG_EXTERNAL_SENSORS_DUMMY_DATA=y # CONFIG_EXTERNAL_64MBFLASH is not set # CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_OFF is not set # CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_ERR is not set # CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_WRN is not set CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_INF=y # CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_DBG is not set CONFIG_EXTERNAL_SENSORS_LOG_LEVEL=3 # CONFIG_SENSOR_MODULE_LOG_LEVEL_OFF is not set # CONFIG_SENSOR_MODULE_LOG_LEVEL_ERR is not set # CONFIG_SENSOR_MODULE_LOG_LEVEL_WRN is not set CONFIG_SENSOR_MODULE_LOG_LEVEL_INF=y # CONFIG_SENSOR_MODULE_LOG_LEVEL_DBG is not set CONFIG_SENSOR_MODULE_LOG_LEVEL=3 CONFIG_UI_MODULE=y CONFIG_UI_THREAD_STACK_SIZE=512 # CONFIG_UI_MODULE_LOG_LEVEL_OFF is not set # CONFIG_UI_MODULE_LOG_LEVEL_ERR is not set # CONFIG_UI_MODULE_LOG_LEVEL_WRN is not set CONFIG_UI_MODULE_LOG_LEVEL_INF=y # CONFIG_UI_MODULE_LOG_LEVEL_DBG is not set CONFIG_UI_MODULE_LOG_LEVEL=3 CONFIG_UTIL_MODULE=y CONFIG_REBOOT_TIMEOUT=30 # CONFIG_UTIL_MODULE_LOG_LEVEL_OFF is not set # CONFIG_UTIL_MODULE_LOG_LEVEL_ERR is not set # CONFIG_UTIL_MODULE_LOG_LEVEL_WRN is not set CONFIG_UTIL_MODULE_LOG_LEVEL_INF=y # CONFIG_UTIL_MODULE_LOG_LEVEL_DBG is not set CONFIG_UTIL_MODULE_LOG_LEVEL=3 CONFIG_LED_CONTROL=y CONFIG_LED_STATE_DEF_PATH="led_state_def.h" # CONFIG_LED_CONTROL_LOG_LEVEL_OFF is not set # CONFIG_LED_CONTROL_LOG_LEVEL_ERR is not set # CONFIG_LED_CONTROL_LOG_LEVEL_WRN is not set CONFIG_LED_CONTROL_LOG_LEVEL_INF=y # CONFIG_LED_CONTROL_LOG_LEVEL_DBG is not set CONFIG_LED_CONTROL_LOG_LEVEL=3 # CONFIG_DEBUG_MODULE is not set # CONFIG_DEBUG_MODULE_LOG_LEVEL_OFF is not set # CONFIG_DEBUG_MODULE_LOG_LEVEL_ERR is not set # CONFIG_DEBUG_MODULE_LOG_LEVEL_WRN is not set CONFIG_DEBUG_MODULE_LOG_LEVEL_INF=y # CONFIG_DEBUG_MODULE_LOG_LEVEL_DBG is not set CONFIG_DEBUG_MODULE_LOG_LEVEL=3 CONFIG_CLOUD_CODEC=y # CONFIG_CLOUD_CODEC_NRF_CLOUD is not set CONFIG_CLOUD_CODEC_AWS_IOT=y # CONFIG_CLOUD_CODEC_AZURE_IOT_HUB is not set # CONFIG_CLOUD_CODEC_LWM2M is not set # CONFIG_AWS_IOT_CORE_SETTINGS is not set CONFIG_CLOUD_CODEC_LWM2M_PATH_LIST_ENTRIES_MAX=1 CONFIG_CLOUD_CODEC_LWM2M_PATH_ENTRY_SIZE_MAX=1 CONFIG_CLOUD_CODEC_APN_LEN_MAX=30 CONFIG_AWS_FOTA=y CONFIG_AWS_FOTA_PAYLOAD_SIZE=1350 CONFIG_AWS_FOTA_HOSTNAME_MAX_LEN=255 CONFIG_AWS_FOTA_FILE_PATH_MAX_LEN=255 CONFIG_AWS_FOTA_JOB_TYPE_MAX_LEN=2 CONFIG_AWS_FOTA_DOWNLOAD_SECURITY_TAG=-1 CONFIG_AWS_CLOUD_FOTA_FULL_MODEM_UPDATE=y CONFIG_AWS_CLOUD_FOTA_FULL_MODEM_UPDATE_BUF_SIZE=4096 CONFIG_AWS_CLOUD_FOTA_PROGRESS_PCT_INCREMENT=10 CONFIG_AWS_CLOUD_SEC_TAG=12345 CONFIG_AWS_CLOUD_FOTA_DOWNLOAD_FRAGMENT_SIZE=1700 # CONFIG_AWS_FOTA_NETFEASA_LOG_LEVEL_OFF is not set # CONFIG_AWS_FOTA_NETFEASA_LOG_LEVEL_ERR is not set # CONFIG_AWS_FOTA_NETFEASA_LOG_LEVEL_WRN is not set # CONFIG_AWS_FOTA_NETFEASA_LOG_LEVEL_INF is not set CONFIG_AWS_FOTA_NETFEASA_LOG_LEVEL_DBG=y CONFIG_AWS_FOTA_NETFEASA_LOG_LEVEL=4 # CONFIG_CLOUD_CODEC_LOG_LEVEL_OFF is not set # CONFIG_CLOUD_CODEC_LOG_LEVEL_ERR is not set # CONFIG_CLOUD_CODEC_LOG_LEVEL_WRN is not set CONFIG_CLOUD_CODEC_LOG_LEVEL_INF=y # CONFIG_CLOUD_CODEC_LOG_LEVEL_DBG is not set CONFIG_CLOUD_CODEC_LOG_LEVEL=3 # CONFIG_WATCHDOG_APPLICATION is not set # CONFIG_WATCHDOG_LOG_LEVEL_OFF is not set # CONFIG_WATCHDOG_LOG_LEVEL_ERR is not set # CONFIG_WATCHDOG_LOG_LEVEL_WRN is not set CONFIG_WATCHDOG_LOG_LEVEL_INF=y # CONFIG_WATCHDOG_LOG_LEVEL_DBG is not set CONFIG_WATCHDOG_LOG_LEVEL=3 CONFIG_EVENTS=y CONFIG_APP_EVENTS_LOG=y CONFIG_MODEM_EVENTS_LOG=y CONFIG_CLOUD_EVENTS_LOG=y CONFIG_SENSOR_EVENTS_LOG=y CONFIG_UI_EVENTS_LOG=y CONFIG_UTIL_EVENTS_LOG=y CONFIG_LOCATION_EVENTS_LOG=y CONFIG_DATA_EVENTS_LOG=y CONFIG_DEBUG_EVENTS_LOG=y # end of Asset Tracker v2 # # Zephyr Kernel # CONFIG_GPIO=y # CONFIG_KSCAN is not set # CONFIG_WIFI is not set # CONFIG_NET_L2_ETHERNET is not set CONFIG_SPI=y CONFIG_GPIO_INIT_PRIORITY=40 # CONFIG_MODEM is not set CONFIG_NET_IPV6=y # CONFIG_NET_CONFIG_NEED_IPV6 is not set CONFIG_I2C=y CONFIG_SENSOR=y CONFIG_BOARD="nrf9160dk_nrf9160" CONFIG_BUILD_WITH_TFM=y CONFIG_TFM_FLASH_MERGED_BINARY=y CONFIG_FLASH_LOAD_SIZE=0x34000 CONFIG_FLASH_LOAD_OFFSET=0x54000 CONFIG_SOC="nRF9160_SICA" CONFIG_SOC_SERIES="nrf91" CONFIG_NUM_IRQS=65 CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768 CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30 CONFIG_FLASH_SIZE=1024 CONFIG_FLASH_BASE_ADDRESS=0x0 CONFIG_ICACHE_LINE_SIZE=32 CONFIG_DCACHE_LINE_SIZE=32 CONFIG_HEAP_MEM_POOL_SIZE=47250 CONFIG_ROM_START_OFFSET=0 CONFIG_PINCTRL=y # CONFIG_WATCHDOG is not set # CONFIG_RESET is not set CONFIG_CLOCK_CONTROL=y CONFIG_SOC_HAS_TIMING_FUNCTIONS=y CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y CONFIG_PM=y # CONFIG_PM_DEVICE is not set CONFIG_LOG_DOMAIN_NAME="" CONFIG_NRF_RTC_TIMER=y CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768 CONFIG_BUILD_OUTPUT_HEX=y CONFIG_SERIAL_INIT_PRIORITY=55 CONFIG_FPU=y # CONFIG_MBEDTLS is not set # CONFIG_CODE_DATA_RELOCATION is not set # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set # CONFIG_TINYCRYPT is not set # CONFIG_NET_L2_IEEE802154 is not set CONFIG_SERIAL=y CONFIG_MAIN_STACK_SIZE=2048 # CONFIG_SRAM_VECTOR_TABLE is not set CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS="" CONFIG_MP_MAX_NUM_CPUS=1 CONFIG_PLATFORM_SPECIFIC_INIT=y CONFIG_HAS_DTS=y # # Devicetree Info # CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y CONFIG_DT_HAS_BOSCH_BME680_ENABLED=y CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_CC310_SW_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF91_FLASH_CONTROLLER_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF9160DK_NRF52840_INTERFACE_ENABLED=y CONFIG_DT_HAS_PWM_LEDS_ENABLED=y CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y CONFIG_DT_HAS_TI_BQ274XX_ENABLED=y CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y # end of Devicetree Info # # Modules # # # Available modules. # # # nrf (C:/ncs/v2.2.0/nrf) # CONFIG_NEWLIB_LIBC_NANO=y CONFIG_NUM_METAIRQ_PRIORITIES=0 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192 CONFIG_LOG_BUFFER_SIZE=1024 # CONFIG_INIT_STACKS is not set CONFIG_NET_IPV6_NBR_CACHE=y CONFIG_NET_IPV6_MLD=y CONFIG_NET_PKT_RX_COUNT=4 CONFIG_NET_PKT_TX_COUNT=4 # CONFIG_MBEDTLS_CIPHER_MODE_CBC is not set # CONFIG_MBEDTLS_CIPHER_MODE_CTR is not set CONFIG_MBEDTLS_CIPHER_MODE_CFB=y CONFIG_MBEDTLS_CIPHER_MODE_OFB=y # CONFIG_MBEDTLS_CHACHA20_C is not set # CONFIG_MBEDTLS_POLY1305_C is not set # CONFIG_MBEDTLS_DHM_C is not set CONFIG_MBEDTLS_RSA_C=y CONFIG_MBEDTLS_SHA512_C=y # CONFIG_MBEDTLS_GCM_C is not set # CONFIG_MBEDTLS_CIPHER_MODE_XTS is not set CONFIG_MBEDTLS_HEAP_SIZE=4096 CONFIG_MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG=y # CONFIG_NET_PKT_TXTIME is not set # CONFIG_NET_PKT_TIMESTAMP is not set # # Nordic nRF Connect # CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y CONFIG_WARN_EXPERIMENTAL=y CONFIG_PRIVILEGED_STACK_SIZE=1024 CONFIG_ENTROPY_GENERATOR=y CONFIG_INIT_ARCH_HW_AT_BOOT=y CONFIG_LINKER_LAST_SECTION_ID=y CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 # CONFIG_NCS_SAMPLES_DEFAULTS is not set CONFIG_LOG_DEFAULT_LEVEL=3 # # Image build variants # # CONFIG_NCS_MCUBOOT_IN_BUILD is not set # end of Image build variants # # Bootloader # CONFIG_BUILD_S1_VARIANT=y CONFIG_S1_VARIANT_IMAGE_NAME="mcuboot" CONFIG_SECURE_BOOT=y # CONFIG_B0_BUILD_STRATEGY_USE_HEX_FILE is not set # CONFIG_B0_BUILD_STRATEGY_SKIP_BUILD is not set CONFIG_B0_BUILD_STRATEGY_FROM_SOURCE=y CONFIG_SB_PRIVATE_KEY_PROVIDED=y CONFIG_SB_SIGNING_PYTHON=y # CONFIG_SB_SIGNING_OPENSSL is not set # CONFIG_SB_SIGNING_CUSTOM is not set CONFIG_SB_SIGNING_KEY_FILE="" CONFIG_SB_SIGNING_COMMAND="" CONFIG_SB_SIGNING_PUBLIC_KEY="" CONFIG_SB_PUBLIC_KEY_FILES="" # CONFIG_SB_DEBUG_SIGNATURE_PUBLIC_KEY_LAST is not set CONFIG_SB_MONOTONIC_COUNTER=y CONFIG_SB_NUM_VER_COUNTER_SLOTS=240 CONFIG_PM_PARTITION_SIZE_PROVISION=0x280 # CONFIG_B0_MIN_PARTITION_SIZE is not set CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000 # CONFIG_SECURE_BOOT_CRYPTO is not set # # Secure Boot firmware validation # CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483 CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1 CONFIG_SB_VALIDATION_INFO_VERSION=2 CONFIG_SB_VALIDATION_METADATA_OFFSET=0 CONFIG_SB_VALIDATE_FW_SIGNATURE=y # end of Secure Boot firmware validation # end of Bootloader # # Bluetooth Low Energy # # # BLE over nRF RPC # # end of BLE over nRF RPC # end of Bluetooth Low Energy # # DFU # # CONFIG_DFU_MULTI_IMAGE is not set CONFIG_DFU_TARGET=y CONFIG_DFU_TARGET_MCUBOOT=y CONFIG_DFU_TARGET_STREAM=y # CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS=y CONFIG_DFU_TARGET_MODEM_DELTA=y CONFIG_DFU_TARGET_MODEM_TIMEOUT=60 CONFIG_DFU_TARGET_FULL_MODEM=y # CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set # CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set # CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set # CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set CONFIG_DFU_TARGET_LOG_LEVEL_DBG=y CONFIG_DFU_TARGET_LOG_LEVEL=4 CONFIG_FMFU_FDEV=y # CONFIG_FMFU_FDEV_SKIP_PREVALIDATION is not set # CONFIG_FMFU_FDEV_LOG_LEVEL_OFF is not set # CONFIG_FMFU_FDEV_LOG_LEVEL_ERR is not set # CONFIG_FMFU_FDEV_LOG_LEVEL_WRN is not set CONFIG_FMFU_FDEV_LOG_LEVEL_INF=y # CONFIG_FMFU_FDEV_LOG_LEVEL_DBG is not set CONFIG_FMFU_FDEV_LOG_LEVEL=3 # end of DFU # CONFIG_ESB is not set # CONFIG_EMDS is not set # # Peripheral CPU DFU (PCD) # # CONFIG_PCD is not set # CONFIG_PCD_APP is not set # CONFIG_PCD_NET is not set # end of Peripheral CPU DFU (PCD) # # Networking # # # Application protocols # CONFIG_CLOUD_SERVICE_MUTUAL_EXCLUSIVE=y # # nRF Cloud # # # Client ID (nRF Cloud Device ID) # CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=y # CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME is not set # CONFIG_NRF_CLOUD_CLIENT_ID_SRC_HW_ID is not set CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX="nrf-" # end of Client ID (nRF Cloud Device ID) # CONFIG_NRF_CLOUD_MQTT is not set # CONFIG_NRF_CLOUD_FOTA is not set # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set # CONFIG_NRF_CLOUD_AGPS_FILTERED is not set # CONFIG_NRF_CLOUD_PGPS is not set # CONFIG_NRF_CLOUD_REST is not set # CONFIG_NRF_CLOUD_GATEWAY is not set # CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_OFF is not set # CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_ERR is not set # CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_WRN is not set CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_INF=y # CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_DBG is not set CONFIG_NRF_CLOUD_GPS_LOG_LEVEL=3 # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set CONFIG_NRF_CLOUD_LOG_LEVEL_DBG=y CONFIG_NRF_CLOUD_LOG_LEVEL=4 # end of nRF Cloud # CONFIG_REST_CLIENT is not set CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2300 CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE=1024 # CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_2048 is not set CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y # CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_512 is not set # CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_256 is not set # # Thread and stack buffers # CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 CONFIG_DOWNLOAD_CLIENT_MAX_HOSTNAME_SIZE=128 CONFIG_DOWNLOAD_CLIENT_MAX_FILENAME_SIZE=192 CONFIG_DOWNLOAD_CLIENT_TCP_SOCK_TIMEO_MS=30000 CONFIG_DOWNLOAD_CLIENT_COAP_MAX_RETRANSMIT_REQUEST_COUNT=4 CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS=y # CONFIG_DOWNLOAD_CLIENT_IPV6 is not set # CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_OFF is not set # CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_ERR is not set # CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_WRN is not set # CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_INF is not set CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG=y CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL=4 # CONFIG_DOWNLOAD_CLIENT_LOG_HEADERS is not set CONFIG_FOTA_DOWNLOAD=y CONFIG_FOTA_SOCKET_RETRIES=2 CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y CONFIG_FOTA_CLIENT_AUTOSCHEDULE_UPDATE=y CONFIG_FOTA_DOWNLOAD_MCUBOOT_FLASH_BUF_SZ=512 # CONFIG_FOTA_DOWNLOAD_NATIVE_TLS is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_OFF is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_ERR is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_WRN is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_INF is not set CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DBG=y CONFIG_FOTA_DOWNLOAD_LOG_LEVEL=4 CONFIG_AWS_IOT=y CONFIG_AWS_IOT_CHOICE=y CONFIG_AWS_IOT_SEND_TIMEOUT=y CONFIG_AWS_IOT_SEND_TIMEOUT_SEC=60 # CONFIG_AWS_IOT_STATIC_IPV4 is not set CONFIG_AWS_IOT_SEC_TAG=12345 CONFIG_AWS_IOT_BROKER_HOST_NAME="54.170.181.188" CONFIG_AWS_IOT_PORT=8883 CONFIG_AWS_IOT_MQTT_RX_TX_BUFFER_LEN=2048 CONFIG_AWS_IOT_MQTT_PAYLOAD_BUFFER_LEN=2304 # CONFIG_AWS_IOT_IPV6 is not set CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT=5 CONFIG_AWS_IOT_CLIENT_ID_MAX_LEN=30 # CONFIG_AWS_IOT_PROVISION_CERTIFICATES is not set CONFIG_AWS_IOT_CLIENT_ID_STATIC="my-thing" CONFIG_AWS_IOT_CLIENT_ID_APP=y CONFIG_AWS_IOT_AUTO_DEVICE_SHADOW_REQUEST=y # CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE is not set CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y # CONFIG_AWS_IOT_TOPIC_UPDATE_ACCEPTED_SUBSCRIBE is not set # CONFIG_AWS_IOT_TOPIC_UPDATE_REJECTED_SUBSCRIBE is not set CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y # CONFIG_AWS_IOT_TOPIC_DELETE_ACCEPTED_SUBSCRIBE is not set # CONFIG_AWS_IOT_TOPIC_DELETE_REJECTED_SUBSCRIBE is not set # CONFIG_AWS_IOT_LAST_WILL is not set CONFIG_AWS_IOT_CONNECTION_POLL_THREAD=y # CONFIG_AWS_IOT_LOG_LEVEL_OFF is not set # CONFIG_AWS_IOT_LOG_LEVEL_ERR is not set # CONFIG_AWS_IOT_LOG_LEVEL_WRN is not set # CONFIG_AWS_IOT_LOG_LEVEL_INF is not set CONFIG_AWS_IOT_LOG_LEVEL_DBG=y CONFIG_AWS_IOT_LOG_LEVEL=4 CONFIG_AWS_JOBS=y CONFIG_CLIENT_ID_MAX_LEN=64 CONFIG_UPDATE_JOB_PAYLOAD_LEN=1350 # CONFIG_AWS_JOBS_LOG_LEVEL_OFF is not set # CONFIG_AWS_JOBS_LOG_LEVEL_ERR is not set # CONFIG_AWS_JOBS_LOG_LEVEL_WRN is not set # CONFIG_AWS_JOBS_LOG_LEVEL_INF is not set CONFIG_AWS_JOBS_LOG_LEVEL_DBG=y CONFIG_AWS_JOBS_LOG_LEVEL=4 # CONFIG_AWS_FOTA_LOG_LEVEL_OFF is not set # CONFIG_AWS_FOTA_LOG_LEVEL_ERR is not set # CONFIG_AWS_FOTA_LOG_LEVEL_WRN is not set # CONFIG_AWS_FOTA_LOG_LEVEL_INF is not set CONFIG_AWS_FOTA_LOG_LEVEL_DBG=y CONFIG_AWS_FOTA_LOG_LEVEL=4 # CONFIG_AZURE_FOTA is not set # CONFIG_AZURE_IOT_HUB is not set # # Self-Registration (Zi ZHu Ce) # # CONFIG_ZZHC is not set # end of Self-Registration (Zi ZHu Ce) # CONFIG_ICAL_PARSER is not set # CONFIG_FTP_CLIENT is not set # CONFIG_COAP_UTILS is not set # CONFIG_LWM2M_CLIENT_UTILS is not set # CONFIG_WIFI_CREDENTIALS is not set # end of Application protocols # end of Networking # # NFC # # CONFIG_NFC_NDEF is not set # CONFIG_NFC_NDEF_PARSER is not set # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set # CONFIG_NFC_T2T_PARSER is not set # CONFIG_NFC_T4T_NDEF_FILE is not set # CONFIG_NFC_T4T_ISODEP is not set # CONFIG_NFC_T4T_APDU is not set # CONFIG_NFC_T4T_CC_FILE is not set # CONFIG_NFC_T4T_HL_PROCEDURE is not set # CONFIG_NFC_PLATFORM is not set # CONFIG_NFC_TNEP_TAG is not set # CONFIG_NFC_TNEP_POLLER is not set # CONFIG_NFC_TNEP_CH is not set # end of NFC CONFIG_APP_EVENT_MANAGER=y CONFIG_APP_EVENT_MANAGER_SHOW_EVENTS=y # CONFIG_APP_EVENT_MANAGER_SHOW_EVENT_HANDLERS is not set # CONFIG_APP_EVENT_MANAGER_TRACE_EVENT_DATA is not set # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_OFF is not set # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_ERR is not set # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_WRN is not set CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_INF=y # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DBG is not set CONFIG_APP_EVENT_MANAGER_LOG_LEVEL=3 # CONFIG_APP_EVENT_MANAGER_USE_DEPRECATED_LOG_FUN is not set # CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE is not set CONFIG_APP_EVENT_MANAGER_MAX_EVENT_CNT=32 # CONFIG_APP_EVENT_MANAGER_PROVIDE_EVENT_SIZE is not set # CONFIG_APP_EVENT_MANAGER_POSTINIT_HOOK is not set # CONFIG_APP_EVENT_MANAGER_SUBMIT_HOOKS is not set # CONFIG_APP_EVENT_MANAGER_PREPROCESS_HOOKS is not set # CONFIG_APP_EVENT_MANAGER_POSTPROCESS_HOOKS is not set # # Trusted Execution Non-Secure # # # TF-M UART pins # # CONFIG_TFM_SECURE_UART1 is not set CONFIG_TFM_UART0_TXD_PIN=29 CONFIG_TFM_UART0_RXD_PIN=28 CONFIG_TFM_UART0_RTS_PIN=27 CONFIG_TFM_UART0_CTS_PIN=26 # end of TF-M UART pins # # Peripheral Secure mapping # # CONFIG_NRF_FPU_SECURE is not set # CONFIG_NRF_REGULATORS_SECURE is not set # CONFIG_NRF_CLOCK_SECURE is not set # CONFIG_NRF_POWER_SECURE is not set # CONFIG_NRF_SPIM0_SECURE is not set # CONFIG_NRF_TWIM0_SECURE is not set # CONFIG_NRF_UARTE0_SECURE is not set # CONFIG_NRF_SPIM1_SECURE is not set # CONFIG_NRF_TWIM1_SECURE is not set # CONFIG_NRF_UARTE1_SECURE is not set # CONFIG_NRF_SPIM2_SECURE is not set # CONFIG_NRF_TWIM2_SECURE is not set # CONFIG_NRF_UARTE2_SECURE is not set # CONFIG_NRF_SPIM3_SECURE is not set # CONFIG_NRF_TWIM3_SECURE is not set # CONFIG_NRF_UARTE3_SECURE is not set # CONFIG_NRF_SAADC_SECURE is not set # CONFIG_NRF_TIMER0_SECURE is not set # CONFIG_NRF_TIMER1_SECURE is not set # CONFIG_NRF_TIMER2_SECURE is not set # CONFIG_NRF_RTC0_SECURE is not set # CONFIG_NRF_RTC1_SECURE is not set # CONFIG_NRF_DPPI_SECURE is not set # CONFIG_NRF_WDT0_SECURE is not set # CONFIG_NRF_EGU0_SECURE is not set # CONFIG_NRF_EGU1_SECURE is not set # CONFIG_NRF_EGU2_SECURE is not set # CONFIG_NRF_EGU3_SECURE is not set # CONFIG_NRF_EGU4_SECURE is not set # CONFIG_NRF_EGU5_SECURE is not set # CONFIG_NRF_PWM0_SECURE is not set # CONFIG_NRF_PWM1_SECURE is not set # CONFIG_NRF_PWM2_SECURE is not set # CONFIG_NRF_PWM3_SECURE is not set # CONFIG_NRF_PDM_SECURE is not set # CONFIG_NRF_I2S_SECURE is not set # CONFIG_NRF_IPC_SECURE is not set # CONFIG_NRF_NVMC_SECURE is not set # CONFIG_NRF_GPIO0_SECURE is not set # CONFIG_NRF_VMC_SECURE is not set # CONFIG_NRF_GPIOTE0_SECURE is not set CONFIG_NRF_GPIO0_PIN_MASK_SECURE=0x00000000 CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE=0x00000000 # end of Peripheral Secure mapping # end of Trusted Execution Non-Secure # CONFIG_APP_EVENT_MANAGER_PROFILER_TRACER is not set # CONFIG_NRF_PROFILER is not set # # SPM # # CONFIG_IS_SPM is not set # end of SPM CONFIG_FW_INFO=y CONFIG_FW_INFO_OFFSET=0x200 CONFIG_FW_INFO_FIRMWARE_VERSION=1 CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea CONFIG_FW_INFO_HARDWARE_ID=91 CONFIG_FW_INFO_VERSION=2 CONFIG_FW_INFO_CRYPTO_ID=0 CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0 CONFIG_FW_INFO_MAGIC_LEN=12 CONFIG_FW_INFO_VALID_VAL=0x9102FFFF CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y # CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set # CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set # CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set # CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set # # Debug # # CONFIG_PPI_TRACE is not set # CONFIG_CPU_LOAD is not set # end of Debug # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set CONFIG_MPSL_FEM_LOG_LEVEL_INF=y # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set CONFIG_MPSL_FEM_LOG_LEVEL=3 CONFIG_MPSL_THREAD_COOP_PRIO=8 CONFIG_MPSL_WORK_STACK_SIZE=1024 CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0 # CONFIG_MPSL_ASSERT_HANDLER is not set # CONFIG_MPSL_LOG_LEVEL_OFF is not set # CONFIG_MPSL_LOG_LEVEL_ERR is not set # CONFIG_MPSL_LOG_LEVEL_WRN is not set CONFIG_MPSL_LOG_LEVEL_INF=y # CONFIG_MPSL_LOG_LEVEL_DBG is not set CONFIG_MPSL_LOG_LEVEL=3 # # Partition Manager # CONFIG_PARTITION_MANAGER_ENABLED=y CONFIG_FLASH_MAP_CUSTOM=y CONFIG_SRAM_SIZE=128 CONFIG_SRAM_BASE_ADDRESS=0x20020000 # # Zephyr subsystem configurations # CONFIG_PM_PARTITION_SIZE_LITTLEFS=0x20000 CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x20000 CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL=y CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x8000 CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x6000 CONFIG_PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL=y # end of Zephyr subsystem configurations # # NCS subsystem configurations # CONFIG_PM_SINGLE_IMAGE=y CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y CONFIG_PM_EXTERNAL_FLASH_BASE=0 CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y CONFIG_PM_SRAM_BASE=0x20000000 CONFIG_PM_SRAM_SIZE=0x40000 # end of Partition Manager # # nRF RPC (Remote Procedure Call) library # # end of nRF RPC (Remote Procedure Call) library # # Full Modem Firmware Update Management(FMFU) # # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set CONFIG_MGMT_FMFU_LOG_LEVEL=3 # end of Full Modem Firmware Update Management(FMFU) CONFIG_CAF=y # # Event options # # CONFIG_CAF_PM_EVENTS is not set # CONFIG_CAF_BLE_COMMON_EVENTS is not set # CONFIG_CAF_BLE_SMP_TRANSFER_EVENTS is not set # CONFIG_CAF_BUTTON_EVENTS is not set # CONFIG_CAF_CLICK_EVENTS is not set CONFIG_CAF_LED_EVENTS=y # CONFIG_CAF_INIT_LOG_LED_EVENTS is not set # CONFIG_CAF_INIT_LOG_LED_READY_EVENTS is not set # CONFIG_CAF_SENSOR_EVENTS is not set # CONFIG_CAF_NET_STATE_EVENTS is not set # CONFIG_CAF_FACTORY_RESET_EVENTS is not set # CONFIG_CAF_FORCE_POWER_DOWN_EVENTS is not set # CONFIG_CAF_KEEP_ALIVE_EVENTS is not set CONFIG_CAF_MODULE_STATE_EVENTS=y # CONFIG_CAF_INIT_LOG_MODULE_STATE_EVENTS is not set CONFIG_CAF_MODULES_FLAGS_COUNT=32 # CONFIG_CAF_POWER_MANAGER_EVENTS is not set # end of Event options # CONFIG_CAF_BUTTONS is not set # # Factory reset request # # CONFIG_CAF_FACTORY_RESET_REQUEST is not set # end of Factory reset request CONFIG_CAF_LEDS=y CONFIG_CAF_LEDS_GPIO=y # CONFIG_CAF_LEDS_LOG_LEVEL_OFF is not set # CONFIG_CAF_LEDS_LOG_LEVEL_ERR is not set # CONFIG_CAF_LEDS_LOG_LEVEL_WRN is not set CONFIG_CAF_LEDS_LOG_LEVEL_INF=y # CONFIG_CAF_LEDS_LOG_LEVEL_DBG is not set CONFIG_CAF_LEDS_LOG_LEVEL=3 # CONFIG_CAF_NET_STATE is not set # # Power manager # # end of Power manager # CONFIG_CAF_SENSOR_DATA_AGGREGATOR_EVENTS is not set # CONFIG_CAF_SENSOR_MANAGER is not set # CONFIG_CAF_SETTINGS_LOADER is not set # # Nordic IEEE 802.15.4 # # end of Nordic IEEE 802.15.4 # CONFIG_DM_MODULE is not set CONFIG_TFM_BOARD="C:/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/nrf9160" # # Libraries # # # Binary libraries # # end of Binary libraries CONFIG_NRF_MODEM_LIB=y # CONFIG_NRF_MODEM_LIB_SYS_INIT is not set # CONFIG_NRF_MODEM_LIB_TRACE is not set # # Interrupt priorities # # CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO_OVERRIDE is not set CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO=1 # end of Interrupt priorities # CONFIG_NRF_MODEM_LIB_ON_FAULT_DO_NOTHING is not set # CONFIG_NRF_MODEM_LIB_ON_FAULT_RESET_MODEM is not set CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC=y # # Heap and buffers # CONFIG_NRF_MODEM_LIB_HEAP_SIZE=1024 CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE=0x4e8 CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE=8192 CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE=8192 CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE=0 CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=128 # CONFIG_NRF_MODEM_LIB_MEM_DIAG is not set # # Logging # # CONFIG_NRF_MODEM_LIB_LOG_FW_VERSION_UUID is not set # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_OFF is not set # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_ERR is not set # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_WRN is not set CONFIG_NRF_MODEM_LIB_LOG_LEVEL_INF=y # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG is not set CONFIG_NRF_MODEM_LIB_LOG_LEVEL=3 # # Deprecated # # CONFIG_NRF_MODEM_LIB_TRACE_ENABLED is not set # CONFIG_ADP536X is not set CONFIG_AT_MONITOR=y CONFIG_AT_MONITOR_HEAP_SIZE=1024 # CONFIG_AT_MONITOR_LOG_LEVEL_OFF is not set # CONFIG_AT_MONITOR_LOG_LEVEL_ERR is not set # CONFIG_AT_MONITOR_LOG_LEVEL_WRN is not set CONFIG_AT_MONITOR_LOG_LEVEL_INF=y # CONFIG_AT_MONITOR_LOG_LEVEL_DBG is not set CONFIG_AT_MONITOR_LOG_LEVEL=3 CONFIG_LTE_LINK_CONTROL=y # CONFIG_LTE_AUTO_INIT_AND_CONNECT is not set # CONFIG_LTE_LOCK_BANDS is not set # CONFIG_LTE_LOCK_PLMN is not set # CONFIG_LTE_UNLOCK_PLMN is not set CONFIG_LTE_PSM_REQ_RPTAU="11000001" CONFIG_LTE_PSM_REQ_RAT="00001010" # CONFIG_LTE_EDRX_REQ is not set CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="1001" CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="1001" CONFIG_LTE_PTW_VALUE_LTE_M="" CONFIG_LTE_PTW_VALUE_NBIOT="" # CONFIG_LTE_NETWORK_DEFAULT is not set # CONFIG_LTE_NETWORK_MODE_LTE_M is not set # CONFIG_LTE_NETWORK_MODE_LTE_M_GPS is not set CONFIG_LTE_NETWORK_MODE_NBIOT=y # CONFIG_LTE_NETWORK_MODE_NBIOT_GPS is not set # CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT is not set # CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS is not set CONFIG_LTE_MODE_PREFERENCE_AUTO=y # CONFIG_LTE_MODE_PREFERENCE_NBIOT is not set # CONFIG_LTE_MODE_PREFERENCE_NBIOT_PLMN_PRIO is not set CONFIG_LTE_MODE_PREFERENCE=0 CONFIG_LTE_RAI_REQ_VALUE="0" CONFIG_LTE_NETWORK_USE_FALLBACK=y CONFIG_LTE_NETWORK_TIMEOUT=600 # CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS is not set CONFIG_LTE_LC_TAU_PRE_WARNING_TIME_MS=5000 CONFIG_LTE_LC_TAU_PRE_WARNING_THRESHOLD_MS=1200000 CONFIG_LTE_NEIGHBOR_CELLS_MAX=10 # CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS is not set CONFIG_LTE_LC_MODEM_SLEEP_PRE_WARNING_TIME_MS=5000 CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS_THRESHOLD_MS=1200000 # CONFIG_LTE_LC_TRACE is not set # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF is not set # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR is not set # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN is not set CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF=y # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG is not set CONFIG_LTE_LINK_CONTROL_LOG_LEVEL=3 CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000 CONFIG_FPROTECT_BLOCK_SIZE=0x8000 # CONFIG_FPROTECT is not set # CONFIG_AT_CUSTOM_CMD is not set CONFIG_DK_LIBRARY=y CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL=10 CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y # CONFIG_DK_LIBRARY_LOG_LEVEL_OFF is not set # CONFIG_DK_LIBRARY_LOG_LEVEL_ERR is not set # CONFIG_DK_LIBRARY_LOG_LEVEL_WRN is not set CONFIG_DK_LIBRARY_LOG_LEVEL_INF=y # CONFIG_DK_LIBRARY_LOG_LEVEL_DBG is not set CONFIG_DK_LIBRARY_LOG_LEVEL=3 CONFIG_AT_CMD_PARSER=y CONFIG_MODEM_INFO=y CONFIG_MODEM_INFO_MAX_AT_PARAMS_RSP=10 CONFIG_MODEM_INFO_BUFFER_SIZE=128 CONFIG_MODEM_INFO_ADD_NETWORK=y CONFIG_MODEM_INFO_ADD_DATE_TIME=y CONFIG_MODEM_INFO_ADD_SIM=y CONFIG_MODEM_INFO_ADD_SIM_ICCID=y CONFIG_MODEM_INFO_ADD_SIM_IMSI=y CONFIG_MODEM_INFO_ADD_DEVICE=y CONFIG_PDN=y # CONFIG_PDN_LEGACY_PCO is not set CONFIG_PDN_ESM_TIMEOUT=1000 CONFIG_PDN_INIT_PRIORITY=90 # CONFIG_PDN_DEFAULTS_OVERRIDE is not set CONFIG_PDN_ESM_STRERROR=y # CONFIG_PDN_LOG_LEVEL_OFF is not set # CONFIG_PDN_LOG_LEVEL_ERR is not set # CONFIG_PDN_LOG_LEVEL_WRN is not set CONFIG_PDN_LOG_LEVEL_INF=y # CONFIG_PDN_LOG_LEVEL_DBG is not set CONFIG_PDN_LOG_LEVEL=3 CONFIG_RESET_ON_FATAL_ERROR=y # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set # CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set CONFIG_FATAL_ERROR_LOG_LEVEL_DBG=y CONFIG_FATAL_ERROR_LOG_LEVEL=4 # CONFIG_SMS is not set # CONFIG_GCF_SMS is not set # CONFIG_MODEM_KEY_MGMT is not set # CONFIG_SUPL_CLIENT_LIB is not set CONFIG_DATE_TIME=y CONFIG_DATE_TIME_AUTO_UPDATE=y CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=14400 CONFIG_DATE_TIME_TOO_OLD_SECONDS=3600 CONFIG_DATE_TIME_MODEM=y CONFIG_DATE_TIME_NTP=y CONFIG_DATE_TIME_THREAD_STACK_SIZE=1280 CONFIG_DATE_TIME_NTP_QUERY_TIME_SECONDS=5 # CONFIG_DATE_TIME_LOG_LEVEL_OFF is not set # CONFIG_DATE_TIME_LOG_LEVEL_ERR is not set # CONFIG_DATE_TIME_LOG_LEVEL_WRN is not set CONFIG_DATE_TIME_LOG_LEVEL_INF=y # CONFIG_DATE_TIME_LOG_LEVEL_DBG is not set CONFIG_DATE_TIME_LOG_LEVEL=3 CONFIG_HW_ID_LIBRARY=y CONFIG_HW_ID_LIBRARY_SOURCE_IMEI=y # CONFIG_HW_ID_LIBRARY_SOURCE_NET_MAC is not set # CONFIG_HW_ID_LIBRARY_SOURCE_DEVICE_ID is not set # CONFIG_WAVE_GEN_LIB is not set CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0 # CONFIG_MODEM_JWT is not set # CONFIG_MODEM_ATTEST_TOKEN is not set # CONFIG_MULTICELL_LOCATION is not set CONFIG_LOCATION=y CONFIG_LOCATION_METHOD_GNSS=y CONFIG_LOCATION_METHOD_CELLULAR=y CONFIG_LOCATION_METHODS_LIST_SIZE=3 CONFIG_LOCATION_DATA_DETAILS=y CONFIG_LOCATION_WORKQUEUE_STACK_SIZE=4096 CONFIG_LOCATION_METHOD_GNSS_VISIBILITY_DETECTION_EXEC_TIME=3000 CONFIG_LOCATION_METHOD_GNSS_VISIBILITY_DETECTION_SAT_LIMIT=3 # CONFIG_LOCATION_LOG_LEVEL_OFF is not set # CONFIG_LOCATION_LOG_LEVEL_ERR is not set CONFIG_LOCATION_LOG_LEVEL_WRN=y # CONFIG_LOCATION_LOG_LEVEL_INF is not set # CONFIG_LOCATION_LOG_LEVEL_DBG is not set CONFIG_LOCATION_LOG_LEVEL=2 CONFIG_MODEM_ANTENNA=y CONFIG_MODEM_ANTENNA_GNSS_ONBOARD=y # CONFIG_MODEM_ANTENNA_GNSS_EXTERNAL is not set CONFIG_MODEM_ANTENNA_AT_MAGPIO="AT%XMAGPIO=1,0,0,1,1,1574,1577" CONFIG_MODEM_ANTENNA_AT_COEX0="AT%XCOEX0=1,1,1565,1586" # CONFIG_MODEM_ANTENNA_LOG_LEVEL_OFF is not set # CONFIG_MODEM_ANTENNA_LOG_LEVEL_ERR is not set # CONFIG_MODEM_ANTENNA_LOG_LEVEL_WRN is not set CONFIG_MODEM_ANTENNA_LOG_LEVEL_INF=y # CONFIG_MODEM_ANTENNA_LOG_LEVEL_DBG is not set CONFIG_MODEM_ANTENNA_LOG_LEVEL=3 CONFIG_QOS=y CONFIG_QOS_PENDING_MESSAGES_MAX=10 CONFIG_QOS_MESSAGE_NOTIFIED_COUNT_MAX=3 CONFIG_QOS_MESSAGE_NOTIFY_TIMEOUT_SECONDS=16 # CONFIG_QOS_LOG_LEVEL_OFF is not set # CONFIG_QOS_LOG_LEVEL_ERR is not set # CONFIG_QOS_LOG_LEVEL_WRN is not set CONFIG_QOS_LOG_LEVEL_INF=y # CONFIG_QOS_LOG_LEVEL_DBG is not set CONFIG_QOS_LOG_LEVEL=3 # CONFIG_SFLOAT is not set # end of Libraries # # Device Drivers # # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set CONFIG_ENTROPY_CC3XX=y # CONFIG_ETH_RTT is not set # CONFIG_BH1749 is not set # CONFIG_SENSOR_SIM is not set # CONFIG_SENSOR_STUB is not set # CONFIG_PMW3360 is not set # CONFIG_PAW3212 is not set # CONFIG_NRF_SW_LPUART is not set CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1 # end of Device Drivers # # External libraries # # end of External libraries # # Test # CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y # CONFIG_UNITY is not set # # Mocks # # CONFIG_MOCK_NRF_MODEM_AT is not set # end of Mocks # end of Test # end of Nordic nRF Connect CONFIG_ZEPHYR_NRF_MODULE=y # end of nrf (C:/ncs/v2.2.0/nrf) # # hostap (C:/ncs/v2.2.0/modules/lib/hostap) # # CONFIG_WPA_SUPP is not set CONFIG_ZEPHYR_HOSTAP_MODULE=y # end of hostap (C:/ncs/v2.2.0/modules/lib/hostap) # # mcuboot (C:/ncs/v2.2.0/bootloader/mcuboot) # # # MCUboot # CONFIG_SIGN_IMAGES=y # CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set # CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set # CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y CONFIG_MCUBOOT_IMAGE_VERSION="0.0.0+0" CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4 CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4 # CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y # end of MCUboot CONFIG_ZEPHYR_MCUBOOT_MODULE=y # end of mcuboot (C:/ncs/v2.2.0/bootloader/mcuboot) # # mbedtls (C:/ncs/v2.2.0/modules/crypto/mbedtls) # CONFIG_ZEPHYR_MBEDTLS_MODULE=y # CONFIG_MBEDTLS_BUILTIN is not set # CONFIG_MBEDTLS_LIBRARY is not set CONFIG_MBEDTLS_CFG_FILE="nrf-config.h" # CONFIG_MBEDTLS_TLS_VERSION_1_2 is not set # CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set # CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set # CONFIG_MBEDTLS_ECP_C is not set # CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set # CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set # CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set # CONFIG_MBEDTLS_MAC_SHA256_ENABLED is not set # CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set # CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set # CONFIG_MBEDTLS_CIPHER is not set # CONFIG_MBEDTLS_MD is not set # CONFIG_MBEDTLS_GENPRIME_ENABLED is not set # CONFIG_MBEDTLS_ENTROPY_ENABLED is not set CONFIG_MBEDTLS_USER_CONFIG_FILE="nrf-config-user.h" # CONFIG_MBEDTLS_PK_WRITE_C is not set CONFIG_MBEDTLS_PKCS5_C=y CONFIG_MBEDTLS_PSA_CRYPTO_C=y # CONFIG_MBEDTLS_ENABLE_HEAP is not set # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set CONFIG_PSA_WANT_ALG_HMAC_DRBG=y # CONFIG_PSA_WANT_ALG_CCM is not set # CONFIG_PSA_WANT_ALG_GCM is not set # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set # CONFIG_PSA_WANT_ALG_CMAC is not set # CONFIG_PSA_WANT_ALG_HMAC is not set # CONFIG_PSA_WANT_ALG_SHA_1 is not set # CONFIG_PSA_WANT_ALG_SHA_224 is not set # CONFIG_PSA_WANT_ALG_SHA_256 is not set # CONFIG_PSA_WANT_ALG_SHA_384 is not set # CONFIG_PSA_WANT_ALG_SHA_512 is not set # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set # CONFIG_PSA_WANT_ALG_MD5 is not set # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set # CONFIG_PSA_WANT_ALG_CFB is not set # CONFIG_PSA_WANT_ALG_CTR is not set # CONFIG_PSA_WANT_ALG_OFB is not set CONFIG_PSA_HAS_KEY_DERIVATION=y # CONFIG_PSA_WANT_ALG_TLS12_PRF is not set CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS=y # CONFIG_PSA_WANT_ALG_ECDH is not set # CONFIG_PSA_WANT_ALG_ECDSA is not set # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set # CONFIG_PSA_WANT_ALG_RSA_PSS is not set # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set # end of mbedtls (C:/ncs/v2.2.0/modules/crypto/mbedtls) # # trusted-firmware-m (C:/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m) # CONFIG_TFM_ISOLATION_LEVEL=1 # CONFIG_TFM_BL2 is not set # CONFIG_TFM_REGRESSION_NS is not set CONFIG_TFM_PROFILE_TYPE_MINIMAL=y CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE=1 CONFIG_TFM_CRYPTO_CONC_OPER_NUM=1 CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=1024 CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x800 # CONFIG_TFM_ITS_ENCRYPTED is not set CONFIG_TFM_HW_INIT_RESET_ON_BOOT=y CONFIG_TFM_HW_INIT_NRF_PERIPHERALS=y # CONFIG_TFM_HALT_ON_CORE_PANIC is not set CONFIG_TFM_ALLOW_NON_SECURE_RESET=y CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y CONFIG_TFM_KEY_FILE_S="C:/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072.pem" CONFIG_TFM_KEY_FILE_NS="C:/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072_1.pem" # CONFIG_TFM_PROFILE_TYPE_NOT_SET is not set # CONFIG_TFM_PROFILE_TYPE_SMALL is not set # CONFIG_TFM_PROFILE_TYPE_MEDIUM is not set # CONFIG_TFM_PROFILE_TYPE_LARGE is not set # CONFIG_TFM_CMAKE_BUILD_TYPE_RELEASE is not set # CONFIG_TFM_CMAKE_BUILD_TYPE_RELWITHDEBINFO is not set CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y # CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG is not set # CONFIG_TFM_ITS_NUM_ASSETS_OVERRIDE is not set # CONFIG_TFM_ITS_MAX_ASSET_SIZE_OVERRIDE is not set CONFIG_TFM_PARTITION_PLATFORM_CUSTOM_REBOOT=y CONFIG_TFM_IMAGE_VERSION_S="0.0.0+0" CONFIG_TFM_IMAGE_VERSION_NS="0.0.0+0" # CONFIG_TFM_BUILD_NS is not set CONFIG_TFM_MCUBOOT_IMAGE_NUMBER=1 # CONFIG_TFM_LIBRARY is not set CONFIG_TFM_IPC=y # CONFIG_TFM_SFN is not set # CONFIG_TFM_REGRESSION_S is not set # CONFIG_TFM_PSA_TEST_PROTECTED_STORAGE is not set # CONFIG_TFM_PSA_TEST_INTERNAL_TRUSTED_STORAGE is not set # CONFIG_TFM_PSA_TEST_STORAGE is not set CONFIG_TFM_PSA_TEST_NONE=y CONFIG_TFM_LOG_LEVEL_SILENCE=y # CONFIG_TFM_EXCEPTION_INFO_DUMP is not set # CONFIG_MBEDTLS_SHA1_C is not set CONFIG_TFM_PARTITION_CRYPTO=y CONFIG_TFM_PARTITION_PLATFORM=y CONFIG_TFM_CRYPTO_RNG_MODULE_ENABLED=y # CONFIG_MBEDTLS_TLS_LIBRARY is not set # CONFIG_MBEDTLS_X509_LIBRARY is not set # CONFIG_MBEDTLS_CTR_DRBG_C is not set # CONFIG_MBEDTLS_CMAC_C is not set # CONFIG_MBEDTLS_CCM_C is not set CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x8000 CONFIG_PM_PARTITION_SIZE_BL2=0 CONFIG_PM_PARTITION_SIZE_TFM=0x8000 CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE=0 CONFIG_PM_PARTITION_SIZE_TFM_INTERNAL_TRUSTED_STORAGE=0 CONFIG_PM_PARTITION_SIZE_TFM_OTP_NV_COUNTERS=0 # end of trusted-firmware-m (C:/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m) # # cjson (C:/ncs/v2.2.0/modules/lib/cjson) # CONFIG_CJSON_LIB=y CONFIG_ZEPHYR_CJSON_MODULE=y # end of cjson (C:/ncs/v2.2.0/modules/lib/cjson) # # azure-sdk-for-c (C:/ncs/v2.2.0/modules/lib/azure-sdk-for-c) # # CONFIG_AZURE_SDK is not set CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y # end of azure-sdk-for-c (C:/ncs/v2.2.0/modules/lib/azure-sdk-for-c) # # memfault-firmware-sdk (C:/ncs/v2.2.0/modules/lib/memfault-firmware-sdk) # # CONFIG_MEMFAULT is not set CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y # end of memfault-firmware-sdk (C:/ncs/v2.2.0/modules/lib/memfault-firmware-sdk) # # cirrus-logic (C:/ncs/v2.2.0/modules/hal/cirrus-logic) # # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y # end of cirrus-logic (C:/ncs/v2.2.0/modules/hal/cirrus-logic) # # openthread (C:/ncs/v2.2.0/modules/lib/openthread) # # CONFIG_OPENTHREAD is not set CONFIG_ZEPHYR_OPENTHREAD_MODULE=y # end of openthread (C:/ncs/v2.2.0/modules/lib/openthread) # # canopennode (C:/ncs/v2.2.0/modules/lib/canopennode) # CONFIG_ZEPHYR_CANOPENNODE_MODULE=y # end of canopennode (C:/ncs/v2.2.0/modules/lib/canopennode) # # chre (C:/ncs/v2.2.0/modules/lib/chre) # CONFIG_ZEPHYR_CHRE_MODULE=y # CONFIG_CHRE is not set # end of chre (C:/ncs/v2.2.0/modules/lib/chre) # # hal_nordic (C:/ncs/v2.2.0/modules/hal/nordic) # CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set CONFIG_HAS_NRFX=y # # nrfx drivers # CONFIG_NRFX_CLOCK=y CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y CONFIG_NRFX_DPPI=y # CONFIG_NRFX_EGU0 is not set # CONFIG_NRFX_EGU1 is not set # CONFIG_NRFX_EGU2 is not set # CONFIG_NRFX_EGU3 is not set # CONFIG_NRFX_EGU4 is not set # CONFIG_NRFX_EGU5 is not set CONFIG_NRFX_GPIOTE=y # CONFIG_NRFX_I2S is not set CONFIG_NRFX_IPC=y CONFIG_NRFX_NVMC=y # CONFIG_NRFX_PDM is not set # CONFIG_NRFX_POWER is not set # CONFIG_NRFX_PWM0 is not set # CONFIG_NRFX_PWM1 is not set # CONFIG_NRFX_PWM2 is not set # CONFIG_NRFX_PWM3 is not set # CONFIG_NRFX_RTC0 is not set # CONFIG_NRFX_RTC1 is not set # CONFIG_NRFX_SAADC is not set CONFIG_NRFX_SPIM=y # CONFIG_NRFX_SPIM0 is not set # CONFIG_NRFX_SPIM1 is not set # CONFIG_NRFX_SPIM2 is not set CONFIG_NRFX_SPIM3=y # CONFIG_NRFX_SYSTICK is not set # CONFIG_NRFX_TIMER0 is not set # CONFIG_NRFX_TIMER1 is not set # CONFIG_NRFX_TIMER2 is not set CONFIG_NRFX_TWIM=y # CONFIG_NRFX_TWIM0 is not set # CONFIG_NRFX_TWIM1 is not set CONFIG_NRFX_TWIM2=y # CONFIG_NRFX_TWIM3 is not set # CONFIG_NRFX_UARTE0 is not set # CONFIG_NRFX_UARTE1 is not set # CONFIG_NRFX_UARTE2 is not set # CONFIG_NRFX_UARTE3 is not set # CONFIG_NRFX_WDT0 is not set # # Peripheral Resource Sharing module # # CONFIG_NRFX_PRS_BOX_0 is not set # CONFIG_NRFX_PRS_BOX_1 is not set # CONFIG_NRFX_PRS_BOX_2 is not set # CONFIG_NRFX_PRS_BOX_3 is not set # CONFIG_NRFX_PRS_BOX_4 is not set # end of Peripheral Resource Sharing module # end of nrfx drivers # end of hal_nordic (C:/ncs/v2.2.0/modules/hal/nordic) # # liblc3 (C:/ncs/v2.2.0/modules/lib/liblc3) # # CONFIG_LIBLC3 is not set CONFIG_ZEPHYR_LIBLC3_MODULE=y # end of liblc3 (C:/ncs/v2.2.0/modules/lib/liblc3) # # littlefs (C:/ncs/v2.2.0/modules/fs/littlefs) # CONFIG_ZEPHYR_LITTLEFS_MODULE=y # end of littlefs (C:/ncs/v2.2.0/modules/fs/littlefs) # # loramac-node (C:/ncs/v2.2.0/modules/lib/loramac-node) # CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set # end of loramac-node (C:/ncs/v2.2.0/modules/lib/loramac-node) # # lvgl (C:/ncs/v2.2.0/modules/lib/gui/lvgl) # CONFIG_ZEPHYR_LVGL_MODULE=y # end of lvgl (C:/ncs/v2.2.0/modules/lib/gui/lvgl) # # lz4 (C:/ncs/v2.2.0/modules/lib/lz4) # CONFIG_ZEPHYR_LZ4_MODULE=y # CONFIG_LZ4 is not set # end of lz4 (C:/ncs/v2.2.0/modules/lib/lz4) # # nanopb (C:/ncs/v2.2.0/modules/lib/nanopb) # CONFIG_ZEPHYR_NANOPB_MODULE=y # CONFIG_NANOPB is not set # end of nanopb (C:/ncs/v2.2.0/modules/lib/nanopb) # # picolibc (C:/ncs/v2.2.0/modules/lib/picolibc) # # CONFIG_PICOLIBC_MODULE is not set CONFIG_ZEPHYR_PICOLIBC_MODULE=y # end of picolibc (C:/ncs/v2.2.0/modules/lib/picolibc) # # TraceRecorder (C:/ncs/v2.2.0/modules/debug/TraceRecorder) # CONFIG_ZEPHYR_TRACERECORDER_MODULE=y # end of TraceRecorder (C:/ncs/v2.2.0/modules/debug/TraceRecorder) # # uoscore-uedhoc (C:/ncs/v2.2.0/modules/lib/uoscore-uedhoc) # CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y # end of uoscore-uedhoc (C:/ncs/v2.2.0/modules/lib/uoscore-uedhoc) # # zcbor (C:/ncs/v2.2.0/modules/lib/zcbor) # CONFIG_ZEPHYR_ZCBOR_MODULE=y CONFIG_ZCBOR=y # CONFIG_ZCBOR_CANONICAL is not set # CONFIG_ZCBOR_STOP_ON_ERROR is not set # CONFIG_ZCBOR_VERBOSE is not set CONFIG_ZCBOR_ASSERT=y # end of zcbor (C:/ncs/v2.2.0/modules/lib/zcbor) # # zscilib (C:/ncs/v2.2.0/modules/lib/zscilib) # # CONFIG_ZSL is not set CONFIG_ZEPHYR_ZSCILIB_MODULE=y # end of zscilib (C:/ncs/v2.2.0/modules/lib/zscilib) # # nrfxlib (C:/ncs/v2.2.0/nrfxlib) # # # Nordic nrfxlib # CONFIG_NRF_MODEM=y # # nrf_modem (Modem library) # CONFIG_NRF_MODEM_LINK_BINARY=y # CONFIG_NRF_MODEM_LOG is not set # end of nrf_modem (Modem library) CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8 # CONFIG_NFC_T2T_NRFXLIB is not set # CONFIG_NFC_T4T_NRFXLIB is not set # # Crypto libraries for nRF5x SOCs. # CONFIG_CRYPTOCELL_CC310_USABLE=y CONFIG_CRYPTOCELL_USABLE=y CONFIG_NRF_OBERON=y # end of Crypto libraries for nRF5x SOCs. # # nrf_security module # CONFIG_NORDIC_SECURITY_BACKEND=y CONFIG_NRF_SECURITY=y CONFIG_GENERATE_MBEDTLS_CFG_FILE=y # # PSA RNG support # # end of PSA RNG support # # PSA AEAD support # # end of PSA AEAD support # # PSA MAC support # # end of PSA MAC support # # PSA Hash support # # end of PSA Hash support # # PSA Cipher support # # end of PSA Cipher support # # PSA Key derivation support # # end of PSA Key derivation support # # PSA Asymmetric support # # end of PSA Asymmetric support # # PSA Driver Support # CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y CONFIG_PSA_DEFAULT_OFF=y CONFIG_PSA_CRYPTO_ACCELERATOR_DRIVER_PRESENT=y CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y # CONFIG_PSA_CRYPTO_DRIVER_CC3XX is not set CONFIG_PSA_CRYPTO_DRIVER_OBERON=y # CONFIG_PSA_CRYPTO_DRIVER_ALG_CBC_NO_PADDING_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_CBC_PKCS7_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_CCM_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_CHACHA20_POLY1305_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_CTR_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_DETERMINISTIC_ECDSA_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_ECB_NO_PADDING_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_ECDH_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_ECDSA_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_GCM_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_1_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_224_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_256_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_384_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_512_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ALG_STREAM_CIPHER_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ECC_MONTGOMERY_255_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ECC_SECP_R1_224_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_ECC_SECP_R1_256_OBERON is not set # CONFIG_PSA_CRYPTO_DRIVER_BUILTIN is not set # # PSA API support # CONFIG_MBEDTLS_USE_PSA_CRYPTO=y # end of PSA API support CONFIG_MBEDTLS_PLATFORM_MEMORY=y CONFIG_MBEDTLS_PLATFORM_C=y CONFIG_MBEDTLS_MEMORY_C=y CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y CONFIG_MBEDTLS_AES_DECRYPT_ALT=y CONFIG_MBEDTLS_CHACHA20_ALT=y CONFIG_MBEDTLS_POLY1305_ALT=y CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y CONFIG_MBEDTLS_ECJPAKE_ALT=y CONFIG_MBEDTLS_SHA1_ALT=y CONFIG_MBEDTLS_SHA224_ALT=y CONFIG_MBEDTLS_SHA256_ALT=y CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1 CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y # CONFIG_NRF_SECURITY_ADVANCED is not set CONFIG_OBERON_ONLY_PSA_ENABLED=y CONFIG_OBERON_ONLY_ENABLED=y # # Legacy mbed TLS crypto APIs # CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6 CONFIG_MBEDTLS_MPI_MAX_SIZE=256 # CONFIG_CC3XX_BACKEND is not set CONFIG_OBERON_BACKEND=y CONFIG_NRF_SECURITY_RNG=y CONFIG_MBEDTLS_CTR_DRBG_USE_128_BIT_KEY=y CONFIG_MBEDTLS_HMAC_DRBG_C=y CONFIG_MBEDTLS_AES_C=y # # Cipher Selection # # # AEAD - Authenticated Encryption with Associated Data # # end of AEAD - Authenticated Encryption with Associated Data CONFIG_MBEDTLS_HKDF_C=y # # RSA Encoding Selection # CONFIG_MBEDTLS_GENPRIME=y CONFIG_MBEDTLS_PKCS1_V15=y CONFIG_MBEDTLS_PKCS1_V21=y # # SHA - Secure Hash Algorithm # CONFIG_MBEDTLS_SHA224_C=y CONFIG_MBEDTLS_SHA256_C=y CONFIG_MBEDTLS_SHA384_C=y # end of SHA - Secure Hash Algorithm CONFIG_MBEDTLS_CIPHER_C=y CONFIG_MBEDTLS_MD_C=y # CONFIG_MBEDTLS_PK_C is not set # CONFIG_MBEDTLS_PK_PARSE_C is not set # end of Legacy mbed TLS crypto APIs # # Zephyr legacy configurations # # end of Zephyr legacy configurations # end of nrf_security module # CONFIG_NRF_RPC is not set CONFIG_NRF_802154_SOURCE_NRFXLIB=y # CONFIG_NRF_DM is not set # CONFIG_SW_CODEC_LC3_T2_SOFTWARE is not set # CONFIG_LC3_PLC_DISABLED is not set CONFIG_LC3_ENC_CHAN_MAX=1 CONFIG_LC3_DEC_CHAN_MAX=1 # # Encoder sample rates # CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y # end of Encoder sample rates # # Decoder sample rates # CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y # end of Decoder sample rates # end of Nordic nrfxlib CONFIG_ZEPHYR_NRFXLIB_MODULE=y # end of nrfxlib (C:/ncs/v2.2.0/nrfxlib) # # connectedhomeip (C:/ncs/v2.2.0/modules/lib/matter) # # CONFIG_CHIP is not set CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y # end of connectedhomeip (C:/ncs/v2.2.0/modules/lib/matter) # # Optional modules. Make sure they're installed, via the project manifest. # CONFIG_HAS_CMSIS_CORE=y CONFIG_HAS_CMSIS_CORE_M=y # CONFIG_CMSIS_DSP is not set # CONFIG_CMSIS_NN is not set # CONFIG_LIBMETAL is not set # CONFIG_LVGL is not set # CONFIG_HAS_MEC_HAL is not set # CONFIG_HAS_MPFS_HAL is not set # CONFIG_OPENAMP is not set # CONFIG_SOF is not set # CONFIG_MIPI_SYST_LIB is not set # CONFIG_HAS_TELINK_DRIVERS is not set # CONFIG_TINYCBOR is not set CONFIG_MCUBOOT_BOOTUTIL_LIB=y CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF=y # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3 # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set # # Unavailable modules, please install those via the project manifest. # # # hal_gigadevice module not available. # # # Trusted-firmware-a module not available. # # end of Modules CONFIG_BOARD_REVISION="0.7.0" # CONFIG_NET_DRIVERS is not set # CONFIG_BOARD_NRF9160DK_NRF9160 is not set CONFIG_BOARD_NRF9160DK_NRF9160_NS=y # # Board Options # # end of Board Options # CONFIG_SOC_SERIES_BEETLE is not set # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set # CONFIG_SOC_SERIES_MPS2 is not set # CONFIG_SOC_SERIES_MPS3 is not set # CONFIG_SOC_SERIES_MUSCA_B1 is not set # CONFIG_SOC_SERIES_MUSCA_S1 is not set # CONFIG_SOC_SERIES_AST10X0 is not set # CONFIG_SOC_SERIES_SAMD20 is not set # CONFIG_SOC_SERIES_SAMD21 is not set # CONFIG_SOC_SERIES_SAMD51 is not set # CONFIG_SOC_SERIES_SAME51 is not set # CONFIG_SOC_SERIES_SAME53 is not set # CONFIG_SOC_SERIES_SAME54 is not set # CONFIG_SOC_SERIES_SAML21 is not set # CONFIG_SOC_SERIES_SAMR21 is not set # CONFIG_SOC_SERIES_SAMR34 is not set # CONFIG_SOC_SERIES_SAMR35 is not set # CONFIG_SOC_SERIES_SAM3X is not set # CONFIG_SOC_SERIES_SAM4E is not set # CONFIG_SOC_SERIES_SAM4L is not set # CONFIG_SOC_SERIES_SAM4S is not set # CONFIG_SOC_SERIES_SAME70 is not set # CONFIG_SOC_SERIES_SAMV71 is not set # CONFIG_SOC_SERIES_VALKYRIE is not set # CONFIG_SOC_SERIES_VIPER is not set # CONFIG_SOC_SERIES_PSOC62 is not set # CONFIG_SOC_SERIES_PSOC63 is not set # CONFIG_SOC_SERIES_GD32E10X is not set # CONFIG_SOC_SERIES_GD32E50X is not set # CONFIG_SOC_SERIES_GD32F3X0 is not set # CONFIG_SOC_SERIES_GD32F403 is not set # CONFIG_SOC_SERIES_GD32F4XX is not set # CONFIG_SOC_SERIES_XMC_4XXX is not set # CONFIG_SOC_SERIES_CYCLONE5 is not set # CONFIG_SOC_SERIES_MEC1501X is not set # CONFIG_SOC_SERIES_MEC1701X is not set # CONFIG_SOC_SERIES_MEC172X is not set # CONFIG_SOC_SERIES_NRF51X is not set # CONFIG_SOC_SERIES_NRF52X is not set # CONFIG_SOC_SERIES_NRF53X is not set CONFIG_SOC_SERIES_NRF91X=y # CONFIG_SOC_SERIES_NPCX7 is not set # CONFIG_SOC_SERIES_NPCX9 is not set # CONFIG_SOC_SERIES_M48X is not set # CONFIG_SOC_SERIES_IMX_6X_M4 is not set # CONFIG_SOC_SERIES_IMX7_M4 is not set # CONFIG_SOC_SERIES_IMX8ML_M7 is not set # CONFIG_SOC_SERIES_IMX8MM_M4 is not set # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set # CONFIG_SOC_SERIES_IMX_RT5XX is not set # CONFIG_SOC_SERIES_IMX_RT6XX is not set # CONFIG_SOC_SERIES_IMX_RT is not set # CONFIG_SOC_SERIES_KINETIS_K2X is not set # CONFIG_SOC_SERIES_KINETIS_K6X is not set # CONFIG_SOC_SERIES_KINETIS_K8X is not set # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set # CONFIG_SOC_SERIES_KINETIS_KL2X is not set # CONFIG_SOC_SERIES_KINETIS_KV5X is not set # CONFIG_SOC_SERIES_KINETIS_KWX is not set # CONFIG_SOC_SERIES_LPC11U6X is not set # CONFIG_SOC_SERIES_LPC51U68 is not set # CONFIG_SOC_SERIES_LPC54XXX is not set # CONFIG_SOC_SERIES_LPC55XXX is not set # CONFIG_SOC_SERIES_S32ZE_R52 is not set # CONFIG_SOC_EOS_S3 is not set # CONFIG_SOC_SERIES_RCAR_GEN3 is not set # CONFIG_SOC_SERIES_DA1469X is not set # CONFIG_SOC_SERIES_RP2XXX is not set # CONFIG_SOC_SERIES_EFM32GG11B is not set # CONFIG_SOC_SERIES_EFM32HG is not set # CONFIG_SOC_SERIES_EFM32JG12B is not set # CONFIG_SOC_SERIES_EFM32PG12B is not set # CONFIG_SOC_SERIES_EFM32PG1B is not set # CONFIG_SOC_SERIES_EFM32WG is not set # CONFIG_SOC_SERIES_EFR32BG13P is not set # CONFIG_SOC_SERIES_EFR32FG13P is not set # CONFIG_SOC_SERIES_EFR32FG1P is not set # CONFIG_SOC_SERIES_EFR32MG12P is not set # CONFIG_SOC_SERIES_EFR32MG21 is not set # CONFIG_SOC_SERIES_STM32F0X is not set # CONFIG_SOC_SERIES_STM32F1X is not set # CONFIG_SOC_SERIES_STM32F2X is not set # CONFIG_SOC_SERIES_STM32F3X is not set # CONFIG_SOC_SERIES_STM32F4X is not set # CONFIG_SOC_SERIES_STM32F7X is not set # CONFIG_SOC_SERIES_STM32G0X is not set # CONFIG_SOC_SERIES_STM32G4X is not set # CONFIG_SOC_SERIES_STM32H7X is not set # CONFIG_SOC_SERIES_STM32L0X is not set # CONFIG_SOC_SERIES_STM32L1X is not set # CONFIG_SOC_SERIES_STM32L4X is not set # CONFIG_SOC_SERIES_STM32L5X is not set # CONFIG_SOC_SERIES_STM32MP1X is not set # CONFIG_SOC_SERIES_STM32U5X is not set # CONFIG_SOC_SERIES_STM32WBX is not set # CONFIG_SOC_SERIES_STM32WLX is not set # CONFIG_SOC_TI_LM3S6965 is not set # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set # CONFIG_SOC_SERIES_CC32XX is not set # CONFIG_SOC_SERIES_MSP432P4XX is not set # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set # # Hardware Configuration # CONFIG_CPU_HAS_ARM_MPU=y CONFIG_CPU_HAS_NRF_IDAU=y CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000 CONFIG_SOC_FAMILY="nordic_nrf" CONFIG_SOC_FAMILY_NRF=y CONFIG_HAS_HW_NRF_CC310=y CONFIG_HAS_HW_NRF_CLOCK=y CONFIG_HAS_HW_NRF_DPPIC=y CONFIG_HAS_HW_NRF_EGU0=y CONFIG_HAS_HW_NRF_EGU1=y CONFIG_HAS_HW_NRF_EGU2=y CONFIG_HAS_HW_NRF_EGU3=y CONFIG_HAS_HW_NRF_EGU4=y CONFIG_HAS_HW_NRF_EGU5=y CONFIG_HAS_HW_NRF_GPIO0=y CONFIG_HAS_HW_NRF_GPIOTE=y CONFIG_HAS_HW_NRF_IPC=y CONFIG_HAS_HW_NRF_KMU=y CONFIG_HAS_HW_NRF_NVMC_PE=y CONFIG_HAS_HW_NRF_POWER=y CONFIG_HAS_HW_NRF_PWM0=y CONFIG_HAS_HW_NRF_REGULATORS=y CONFIG_HAS_HW_NRF_RTC0=y CONFIG_HAS_HW_NRF_RTC1=y CONFIG_HAS_HW_NRF_SAADC=y CONFIG_HAS_HW_NRF_SPIM3=y CONFIG_HAS_HW_NRF_TIMER0=y CONFIG_HAS_HW_NRF_TIMER1=y CONFIG_HAS_HW_NRF_TIMER2=y CONFIG_HAS_HW_NRF_TWIM2=y CONFIG_HAS_HW_NRF_UARTE0=y CONFIG_HAS_HW_NRF_VMC=y CONFIG_HAS_HW_NRF_WDT0=y CONFIG_NRF_HW_RTC1_RESERVED=y CONFIG_NRF_ENABLE_ICACHE=y CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0 CONFIG_SOC_NRF9160=y CONFIG_SOC_NRF9160_SICA=y CONFIG_NRF_SOC_SECURE_SUPPORTED=y # CONFIG_NRF_TRACE_PORT is not set # CONFIG_SOC_LOG_LEVEL_OFF is not set # CONFIG_SOC_LOG_LEVEL_ERR is not set # CONFIG_SOC_LOG_LEVEL_WRN is not set CONFIG_SOC_LOG_LEVEL_INF=y # CONFIG_SOC_LOG_LEVEL_DBG is not set CONFIG_SOC_LOG_LEVEL=3 # end of Hardware Configuration CONFIG_SOC_COMPATIBLE_NRF=y # # ARM Options # CONFIG_ARCH="arm" CONFIG_CPU_CORTEX=y # CONFIG_CODE_DATA_RELOCATION_SRAM is not set CONFIG_CPU_CORTEX_M=y CONFIG_ISA_THUMB2=y CONFIG_ASSEMBLER_ISA_THUMB2=y CONFIG_COMPILER_ISA_THUMB2=y CONFIG_STACK_ALIGN_DOUBLE_WORD=y # CONFIG_RUNTIME_NMI is not set CONFIG_FAULT_DUMP=2 CONFIG_BUILTIN_STACK_GUARD=y CONFIG_ARM_STACK_PROTECTION=y CONFIG_ARM_NONSECURE_FIRMWARE=y CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS=y CONFIG_ARM_STORE_EXC_RETURN=y CONFIG_FP_HARDABI=y # CONFIG_FP_SOFTABI is not set CONFIG_FP16=y CONFIG_FP16_IEEE=y # CONFIG_FP16_ALT is not set CONFIG_CPU_CORTEX_M33=y CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y CONFIG_CPU_CORTEX_M_HAS_DWT=y CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y CONFIG_CPU_CORTEX_M_HAS_VTOR=y CONFIG_CPU_CORTEX_M_HAS_SPLIM=y CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y CONFIG_CPU_CORTEX_M_HAS_CMSE=y CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_SE=y CONFIG_ARMV7_M_ARMV8_M_FP=y CONFIG_ARMV8_M_DSP=y # # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options # CONFIG_GEN_ISR_TABLES=y # CONFIG_ZERO_LATENCY_IRQS is not set # CONFIG_SW_VECTOR_RELAY is not set # CONFIG_CORTEX_M_DWT is not set # CONFIG_TRAP_UNALIGNED_ACCESS is not set # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y CONFIG_ARM_TRUSTZONE_M=y # # ARM TrustZone-M Options # # # Non-secure firmware # # CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS is not set # end of ARM TrustZone-M Options CONFIG_GEN_IRQ_VECTOR_TABLE=y CONFIG_ARM_MPU=y CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32 # CONFIG_MPU_STACK_GUARD is not set CONFIG_MPU_ALLOW_FLASH_WRITE=y # CONFIG_CUSTOM_SECTION_ALIGN is not set CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32 # end of ARM Options CONFIG_ARM=y CONFIG_ARCH_IS_SET=y # # General Architecture Options # # CONFIG_SEMIHOST is not set # CONFIG_ARCH_LOG_LEVEL_OFF is not set # CONFIG_ARCH_LOG_LEVEL_ERR is not set # CONFIG_ARCH_LOG_LEVEL_WRN is not set CONFIG_ARCH_LOG_LEVEL_INF=y # CONFIG_ARCH_LOG_LEVEL_DBG is not set CONFIG_ARCH_LOG_LEVEL=3 CONFIG_LITTLE_ENDIAN=y # CONFIG_TRUSTED_EXECUTION_SECURE is not set CONFIG_TRUSTED_EXECUTION_NONSECURE=y CONFIG_HW_STACK_PROTECTION=y # CONFIG_USERSPACE is not set CONFIG_KOBJECT_TEXT_AREA=256 CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100 CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16 CONFIG_GEN_PRIV_STACKS=y # CONFIG_STACK_GROWS_UP is not set # # Interrupt Configuration # # CONFIG_DYNAMIC_INTERRUPTS is not set CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4 CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set CONFIG_GEN_SW_ISR_TABLE=y CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4 CONFIG_GEN_IRQ_START_VECTOR=0 # CONFIG_EXTRA_EXCEPTION_INFO is not set # end of Interrupt Configuration # end of General Architecture Options CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y CONFIG_ARCH_HAS_STACK_PROTECTION=y CONFIG_ARCH_HAS_USERSPACE=y CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y CONFIG_ARCH_SUPPORTS_COREDUMP=y CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y CONFIG_ARCH_HAS_THREAD_ABORT=y CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y CONFIG_CPU_HAS_TEE=y CONFIG_CPU_HAS_FPU=y CONFIG_CPU_HAS_MPU=y CONFIG_MPU=y # CONFIG_MPU_LOG_LEVEL_OFF is not set # CONFIG_MPU_LOG_LEVEL_ERR is not set # CONFIG_MPU_LOG_LEVEL_WRN is not set CONFIG_MPU_LOG_LEVEL_INF=y # CONFIG_MPU_LOG_LEVEL_DBG is not set CONFIG_MPU_LOG_LEVEL=3 CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y CONFIG_MPU_GAP_FILLING=y CONFIG_SRAM_REGION_PERMISSIONS=y # # Floating Point Options # CONFIG_FPU_SHARING=y # end of Floating Point Options # # Cache Options # # end of Cache Options CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y # # General Kernel Options # # CONFIG_KERNEL_LOG_LEVEL_OFF is not set # CONFIG_KERNEL_LOG_LEVEL_ERR is not set # CONFIG_KERNEL_LOG_LEVEL_WRN is not set CONFIG_KERNEL_LOG_LEVEL_INF=y # CONFIG_KERNEL_LOG_LEVEL_DBG is not set CONFIG_KERNEL_LOG_LEVEL=3 CONFIG_MULTITHREADING=y CONFIG_NUM_COOP_PRIORITIES=16 CONFIG_NUM_PREEMPT_PRIORITIES=15 CONFIG_MAIN_THREAD_PRIORITY=0 CONFIG_COOP_ENABLED=y CONFIG_PREEMPT_ENABLED=y CONFIG_PRIORITY_CEILING=-127 # CONFIG_SCHED_DEADLINE is not set # CONFIG_SCHED_CPU_MASK is not set CONFIG_IDLE_STACK_SIZE=320 CONFIG_ISR_STACK_SIZE=2048 CONFIG_THREAD_STACK_INFO=y # CONFIG_THREAD_CUSTOM_DATA is not set CONFIG_ERRNO=y CONFIG_SCHED_DUMB=y # CONFIG_SCHED_SCALABLE is not set # CONFIG_SCHED_MULTIQ is not set # CONFIG_WAITQ_SCALABLE is not set CONFIG_WAITQ_DUMB=y # # Kernel Debugging and Metrics # CONFIG_BOOT_BANNER=y CONFIG_BOOT_DELAY=0 # CONFIG_THREAD_MONITOR is not set # CONFIG_THREAD_NAME is not set # CONFIG_THREAD_RUNTIME_STATS is not set # end of Kernel Debugging and Metrics # # Work Queue Options # CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1 # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set # end of Work Queue Options # # Atomic Operations # CONFIG_ATOMIC_OPERATIONS_BUILTIN=y # end of Atomic Operations # # Timer API Options # CONFIG_TIMESLICING=y CONFIG_TIMESLICE_SIZE=0 CONFIG_TIMESLICE_PRIORITY=0 # CONFIG_TIMESLICE_PER_THREAD is not set CONFIG_POLL=y # end of Timer API Options # # Other Kernel Object Options # # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set CONFIG_NUM_MBOX_ASYNC_MSGS=10 # CONFIG_PIPES is not set CONFIG_KERNEL_MEM_POOL=y # end of Other Kernel Object Options CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y CONFIG_SWAP_NONATOMIC=y CONFIG_SYS_CLOCK_EXISTS=y CONFIG_TIMEOUT_64BIT=y CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365 CONFIG_XIP=y # # Initialization Priorities # CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30 CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40 CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50 CONFIG_APPLICATION_INIT_PRIORITY=90 # end of Initialization Priorities # # Security Options # # CONFIG_STACK_CANARIES is not set CONFIG_STACK_POINTER_RANDOM=0 # end of Security Options # # SMP Options # CONFIG_MP_NUM_CPUS=1 # end of SMP Options CONFIG_TICKLESS_KERNEL=y CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y # CONFIG_THREAD_LOCAL_STORAGE is not set # end of General Kernel Options # # Device Options # # end of Device Options # # Virtual Memory Support # # end of Virtual Memory Support # # Device Drivers # # CONFIG_IEEE802154 is not set # CONFIG_LORA is not set CONFIG_CONSOLE=y CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128 CONFIG_CONSOLE_HAS_DRIVER=y # CONFIG_CONSOLE_HANDLER is not set CONFIG_CONSOLE_INIT_PRIORITY=60 CONFIG_UART_CONSOLE=y # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set # CONFIG_UART_CONSOLE_MCUMGR is not set CONFIG_UART_CONSOLE_INPUT_EXPIRED=y CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000 # CONFIG_RAM_CONSOLE is not set # CONFIG_IPM_CONSOLE_SENDER is not set # CONFIG_IPM_CONSOLE_RECEIVER is not set # CONFIG_UART_MCUMGR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set CONFIG_UART_CONSOLE_LOG_LEVEL=3 # CONFIG_GSM_MUX is not set # CONFIG_EFI_CONSOLE is not set CONFIG_HAS_SEGGER_RTT=y # CONFIG_USE_SEGGER_RTT is not set # CONFIG_EC_HOST_CMD_PERIPH is not set CONFIG_ETH_INIT_PRIORITY=80 # CONFIG_MDIO is not set # # Capabilities # CONFIG_SERIAL_HAS_DRIVER=y CONFIG_SERIAL_SUPPORT_ASYNC=y CONFIG_SERIAL_SUPPORT_INTERRUPT=y # CONFIG_UART_LOG_LEVEL_OFF is not set # CONFIG_UART_LOG_LEVEL_ERR is not set # CONFIG_UART_LOG_LEVEL_WRN is not set CONFIG_UART_LOG_LEVEL_INF=y # CONFIG_UART_LOG_LEVEL_DBG is not set CONFIG_UART_LOG_LEVEL=3 CONFIG_UART_USE_RUNTIME_CONFIGURE=y # CONFIG_UART_ASYNC_API is not set # CONFIG_UART_LINE_CTRL is not set # CONFIG_UART_DRV_CMD is not set # CONFIG_UART_WIDE_DATA is not set # CONFIG_UART_PIPE is not set # # Serial Drivers # CONFIG_UART_NRFX=y CONFIG_UART_0_NRF_UARTE=y CONFIG_UART_0_ENHANCED_POLL_OUT=y CONFIG_UART_0_INTERRUPT_DRIVEN=y # CONFIG_UART_0_NRF_PARITY_BIT is not set CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32 CONFIG_UART_ENHANCED_POLL_OUT=y CONFIG_NRF_UARTE_PERIPHERAL=y # # Interrupt Controllers # CONFIG_INTC_INIT_PRIORITY=40 # CONFIG_INTC_LOG_LEVEL_OFF is not set # CONFIG_INTC_LOG_LEVEL_ERR is not set # CONFIG_INTC_LOG_LEVEL_WRN is not set CONFIG_INTC_LOG_LEVEL_INF=y # CONFIG_INTC_LOG_LEVEL_DBG is not set CONFIG_INTC_LOG_LEVEL=3 # CONFIG_MULTI_LEVEL_INTERRUPTS is not set # CONFIG_INTC_ESP32 is not set # end of Interrupt Controllers # # Timer Drivers # # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0 CONFIG_TICKLESS_CAPABLE=y # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y # end of Timer Drivers # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set CONFIG_ENTROPY_LOG_LEVEL_INF=y # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set CONFIG_ENTROPY_LOG_LEVEL=3 CONFIG_ENTROPY_INIT_PRIORITY=50 # CONFIG_ENTROPY_PSA_CRYPTO_RNG is not set CONFIG_ENTROPY_HAS_DRIVER=y # CONFIG_PCIE is not set # CONFIG_PCIE_ENDPOINT is not set # CONFIG_GPIO_LOG_LEVEL_OFF is not set # CONFIG_GPIO_LOG_LEVEL_ERR is not set # CONFIG_GPIO_LOG_LEVEL_WRN is not set CONFIG_GPIO_LOG_LEVEL_INF=y # CONFIG_GPIO_LOG_LEVEL_DBG is not set CONFIG_GPIO_LOG_LEVEL=3 # CONFIG_GPIO_GET_DIRECTION is not set # CONFIG_GPIO_GET_CONFIG is not set CONFIG_GPIO_NRFX=y # CONFIG_FXL6408_LOG_LEVEL_OFF is not set # CONFIG_FXL6408_LOG_LEVEL_ERR is not set # CONFIG_FXL6408_LOG_LEVEL_WRN is not set CONFIG_FXL6408_LOG_LEVEL_INF=y # CONFIG_FXL6408_LOG_LEVEL_DBG is not set CONFIG_FXL6408_LOG_LEVEL=3 # CONFIG_SPI_ASYNC is not set # CONFIG_SPI_SLAVE is not set # CONFIG_SPI_EXTENDED_MODES is not set CONFIG_SPI_INIT_PRIORITY=70 CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200 # CONFIG_SPI_LOG_LEVEL_OFF is not set # CONFIG_SPI_LOG_LEVEL_ERR is not set # CONFIG_SPI_LOG_LEVEL_WRN is not set CONFIG_SPI_LOG_LEVEL_INF=y # CONFIG_SPI_LOG_LEVEL_DBG is not set CONFIG_SPI_LOG_LEVEL=3 CONFIG_SPI_NRFX=y CONFIG_SPI_3_NRF_SPIM=y CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8 # CONFIG_SDHC is not set # CONFIG_I2C_CALLBACK is not set # CONFIG_I2C_TARGET is not set CONFIG_I2C_NRFX=y CONFIG_I2C_2_NRF_TWIM=y CONFIG_I2C_INIT_PRIORITY=50 # CONFIG_I2C_LOG_LEVEL_OFF is not set # CONFIG_I2C_LOG_LEVEL_ERR is not set # CONFIG_I2C_LOG_LEVEL_WRN is not set CONFIG_I2C_LOG_LEVEL_INF=y # CONFIG_I2C_LOG_LEVEL_DBG is not set CONFIG_I2C_LOG_LEVEL=3 # CONFIG_I3C is not set # CONFIG_I2S is not set # CONFIG_DAI is not set # CONFIG_PWM is not set # CONFIG_PINMUX is not set # CONFIG_ADC is not set # CONFIG_DAC is not set # CONFIG_W1 is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set CONFIG_CLOCK_CONTROL_LOG_LEVEL=3 CONFIG_CLOCK_CONTROL_NRF=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50 # CONFIG_PTP_CLOCK is not set # CONFIG_IPM is not set CONFIG_FLASH_HAS_DRIVER_ENABLED=y CONFIG_FLASH_HAS_PAGE_LAYOUT=y CONFIG_FLASH_JESD216=y CONFIG_FLASH=y # CONFIG_FLASH_LOG_LEVEL_OFF is not set # CONFIG_FLASH_LOG_LEVEL_ERR is not set # CONFIG_FLASH_LOG_LEVEL_WRN is not set # CONFIG_FLASH_LOG_LEVEL_INF is not set CONFIG_FLASH_LOG_LEVEL_DBG=y CONFIG_FLASH_LOG_LEVEL=4 # CONFIG_FLASH_JESD216_API is not set CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_INIT_PRIORITY=50 CONFIG_SOC_FLASH_NRF=y CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set CONFIG_SPI_NOR=y CONFIG_SPI_NOR_SFDP_MINIMAL=y # CONFIG_SPI_NOR_SFDP_DEVICETREE is not set # CONFIG_SPI_NOR_SFDP_RUNTIME is not set CONFIG_SPI_NOR_INIT_PRIORITY=80 CONFIG_SPI_NOR_CS_WAIT_DELAY=0 CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 # CONFIG_SPI_NOR_IDLE_IN_DPD is not set # CONFIG_SENSOR_LOG_LEVEL_OFF is not set # CONFIG_SENSOR_LOG_LEVEL_ERR is not set # CONFIG_SENSOR_LOG_LEVEL_WRN is not set CONFIG_SENSOR_LOG_LEVEL_INF=y # CONFIG_SENSOR_LOG_LEVEL_DBG is not set CONFIG_SENSOR_LOG_LEVEL=3 CONFIG_SENSOR_INIT_PRIORITY=90 # CONFIG_SENSOR_INFO is not set # # Device Drivers # # CONFIG_BME680 is not set # CONFIG_BQ274XX is not set CONFIG_TMP112_FULL_SCALE_RUNTIME=y CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y # CONFIG_COUNTER is not set # CONFIG_DMA is not set # CONFIG_USB_DEVICE_DRIVER is not set # CONFIG_CRYPTO is not set # CONFIG_DISPLAY is not set # CONFIG_LED_STRIP is not set CONFIG_LED=y # CONFIG_LED_LOG_LEVEL_OFF is not set # CONFIG_LED_LOG_LEVEL_ERR is not set # CONFIG_LED_LOG_LEVEL_WRN is not set CONFIG_LED_LOG_LEVEL_INF=y # CONFIG_LED_LOG_LEVEL_DBG is not set CONFIG_LED_LOG_LEVEL=3 CONFIG_LED_INIT_PRIORITY=90 CONFIG_LED_GPIO=y # CONFIG_CAN is not set # CONFIG_AUDIO is not set # CONFIG_NEURAL_NET_ACCEL is not set CONFIG_HWINFO=y # CONFIG_HWINFO_LOG_LEVEL_OFF is not set # CONFIG_HWINFO_LOG_LEVEL_ERR is not set # CONFIG_HWINFO_LOG_LEVEL_WRN is not set CONFIG_HWINFO_LOG_LEVEL_INF=y # CONFIG_HWINFO_LOG_LEVEL_DBG is not set CONFIG_HWINFO_LOG_LEVEL=3 CONFIG_HWINFO_NRF=y # CONFIG_ESPI is not set # CONFIG_PS2 is not set # CONFIG_VIDEO is not set # CONFIG_EEPROM is not set # CONFIG_PECI is not set # CONFIG_PECI_INTERRUPT_DRIVEN is not set # CONFIG_REGULATOR is not set # CONFIG_MEMC is not set # CONFIG_VIRTUALIZATION is not set # CONFIG_EDAC is not set # CONFIG_PM_CPU_OPS is not set # # Miscellaneous Drivers # # CONFIG_GROVE_LCD_RGB is not set # end of Miscellaneous Drivers # CONFIG_DISK_DRIVERS is not set # CONFIG_CACHE is not set # CONFIG_SYSCON is not set # CONFIG_BBRAM is not set # CONFIG_FPGA is not set # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set CONFIG_PINCTRL_LOG_LEVEL_INF=y # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set CONFIG_PINCTRL_LOG_LEVEL=3 CONFIG_PINCTRL_STORE_REG=y # CONFIG_PINCTRL_DYNAMIC is not set CONFIG_PINCTRL_NRF=y # CONFIG_MBOX is not set # CONFIG_MM_DRV is not set # CONFIG_POWER_DOMAIN is not set # CONFIG_USBC_TCPC_DRIVER is not set # CONFIG_USBC_LOG_LEVEL_OFF is not set # CONFIG_USBC_LOG_LEVEL_ERR is not set # CONFIG_USBC_LOG_LEVEL_WRN is not set CONFIG_USBC_LOG_LEVEL_INF=y # CONFIG_USBC_LOG_LEVEL_DBG is not set CONFIG_USBC_LOG_LEVEL=3 # CONFIG_USBC_VBUS_DRIVER is not set # CONFIG_MIPI_DSI is not set # CONFIG_COREDUMP_DEVICE is not set # end of Device Drivers # # C Library # CONFIG_REQUIRES_FULL_LIBC=y CONFIG_SUPPORT_MINIMAL_LIBC=y CONFIG_PICOLIBC_SUPPORTED=y # CONFIG_PICOLIBC is not set CONFIG_NEWLIB_LIBC=y # CONFIG_EXTERNAL_LIBC is not set CONFIG_HAS_NEWLIB_LIBC_NANO=y CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048 CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set # CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set CONFIG_STDOUT_CONSOLE=y # end of C Library # # Additional libraries # # # OS Support Library # # CONFIG_JSON_LIBRARY is not set # CONFIG_RING_BUFFER is not set CONFIG_NOTIFY=y # CONFIG_BASE64 is not set # CONFIG_PRINTK_SYNC is not set CONFIG_MPSC_PBUF=y CONFIG_ONOFF=y # CONFIG_SPSC_PBUF is not set # CONFIG_SHARED_MULTI_HEAP is not set # CONFIG_WINSTREAM is not set # CONFIG_MPSC_CLEAR_ALLOCATED is not set CONFIG_REBOOT=y # CONFIG_UTF8 is not set CONFIG_CBPRINTF_COMPLETE=y # CONFIG_CBPRINTF_NANO is not set CONFIG_CBPRINTF_FULL_INTEGRAL=y # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set CONFIG_CBPRINTF_FP_SUPPORT=y # CONFIG_CBPRINTF_FP_A_SUPPORT is not set # CONFIG_CBPRINTF_FP_ALWAYS_A is not set CONFIG_CBPRINTF_N_SPECIFIER=y # CONFIG_CBPRINTF_LIBC_SUBSTS is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF=y # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3 # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set # # Heap and Memory Allocation # # CONFIG_SYS_HEAP_VALIDATE is not set CONFIG_SYS_HEAP_ALLOC_LOOPS=3 # CONFIG_SYS_HEAP_RUNTIME_STATS is not set # CONFIG_SYS_HEAP_LISTENER is not set CONFIG_SYS_HEAP_SMALL_ONLY=y # CONFIG_SYS_HEAP_BIG_ONLY is not set # CONFIG_SYS_HEAP_AUTO is not set # CONFIG_SYS_MEM_BLOCKS is not set # end of Heap and Memory Allocation # end of OS Support Library # CONFIG_GETOPT is not set CONFIG_POSIX_MAX_FDS=4 # CONFIG_POSIX_API is not set # CONFIG_PTHREAD_IPC is not set CONFIG_POSIX_CLOCK=y CONFIG_MAX_TIMER_COUNT=5 # CONFIG_POSIX_MQUEUE is not set # CONFIG_POSIX_FS is not set # CONFIG_EVENTFD is not set # CONFIG_OPENAMP_RSC_TABLE is not set # # Util libraries # # CONFIG_FNMATCH is not set # end of Util libraries # CONFIG_SMF is not set # end of Additional libraries # # Sub Systems and OS Services # # CONFIG_BT is not set # # Controller Area Network (CAN) bus subsystem # # CONFIG_ISOTP is not set # end of Controller Area Network (CAN) bus subsystem # CONFIG_CONSOLE_SUBSYS is not set # CONFIG_CPLUSPLUS is not set # # System Monitoring Options # # CONFIG_THREAD_ANALYZER is not set # end of System Monitoring Options # # Debugging Options # # CONFIG_DEBUG is not set # CONFIG_STACK_USAGE is not set # CONFIG_STACK_SENTINEL is not set CONFIG_PRINTK=y CONFIG_EARLY_CONSOLE=y CONFIG_ASSERT=y CONFIG_ASSERT_LEVEL=2 CONFIG_SPIN_VALIDATE=y # CONFIG_FORCE_NO_ASSERT is not set CONFIG_ASSERT_VERBOSE=y # CONFIG_ASSERT_NO_FILE_INFO is not set # CONFIG_ASSERT_NO_COND_INFO is not set # CONFIG_ASSERT_NO_MSG_INFO is not set # CONFIG_ASSERT_TEST is not set # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set # CONFIG_DEBUG_INFO is not set # CONFIG_DEBUG_THREAD_INFO is not set # CONFIG_DEBUG_COREDUMP is not set # end of Debugging Options # CONFIG_DISK_ACCESS is not set # CONFIG_EMUL is not set # CONFIG_CHARACTER_FRAMEBUFFER is not set # # File Systems # CONFIG_FILE_SYSTEM=y # CONFIG_FS_LOG_LEVEL_OFF is not set # CONFIG_FS_LOG_LEVEL_ERR is not set # CONFIG_FS_LOG_LEVEL_WRN is not set CONFIG_FS_LOG_LEVEL_INF=y # CONFIG_FS_LOG_LEVEL_DBG is not set CONFIG_FS_LOG_LEVEL=3 CONFIG_APP_LINK_WITH_FS=y CONFIG_FILE_SYSTEM_MAX_TYPES=2 CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1 # CONFIG_FAT_FILESYSTEM_ELM is not set CONFIG_FILE_SYSTEM_LITTLEFS=y # # LittleFS Settings # CONFIG_FS_LITTLEFS_NUM_FILES=4 CONFIG_FS_LITTLEFS_NUM_DIRS=4 CONFIG_FS_LITTLEFS_READ_SIZE=16 CONFIG_FS_LITTLEFS_PROG_SIZE=16 CONFIG_FS_LITTLEFS_CACHE_SIZE=64 CONFIG_FS_LITTLEFS_LOOKAHEAD_SIZE=32 CONFIG_FS_LITTLEFS_BLOCK_CYCLES=512 # end of LittleFS Settings CONFIG_FS_LITTLEFS_FC_HEAP_SIZE=0 CONFIG_FS_LITTLEFS_HEAP_PER_ALLOC_OVERHEAD_SIZE=32 # CONFIG_FS_LITTLEFS_BLK_DEV is not set CONFIG_FCB=y CONFIG_NVS=y # CONFIG_NVS_LOOKUP_CACHE is not set # CONFIG_NVS_LOG_LEVEL_OFF is not set # CONFIG_NVS_LOG_LEVEL_ERR is not set # CONFIG_NVS_LOG_LEVEL_WRN is not set CONFIG_NVS_LOG_LEVEL_INF=y # CONFIG_NVS_LOG_LEVEL_DBG is not set CONFIG_NVS_LOG_LEVEL=3 # end of File Systems # # Inter Processor Communication # # CONFIG_RPMSG_SERVICE is not set # CONFIG_IPC_SERVICE is not set # end of Inter Processor Communication # CONFIG_JWT is not set # # Logging # CONFIG_LOG=y CONFIG_LOG_MODE_DEFERRED=y # CONFIG_LOG_MODE_IMMEDIATE is not set # CONFIG_LOG_MODE_MINIMAL is not set # CONFIG_LOG_FRONTEND is not set # CONFIG_LOG_MULTIDOMAIN is not set # # Logging levels filtering # # CONFIG_LOG_RUNTIME_FILTERING is not set CONFIG_LOG_OVERRIDE_LEVEL=0 CONFIG_LOG_MAX_LEVEL=4 # end of Logging levels filtering # # Processing # # CONFIG_LOG_PRINTK is not set CONFIG_LOG_MODE_OVERFLOW=y # CONFIG_LOG_BLOCK_IN_THREAD is not set CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10 CONFIG_LOG_PROCESS_THREAD=y CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0 CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000 CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048 # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y # CONFIG_LOG_TIMESTAMP_64BIT is not set # CONFIG_LOG_SPEED is not set # end of Processing # # Output Formatting # # # Prepend non-hexdump log message with function name # # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y # end of Prepend non-hexdump log message with function name # CONFIG_LOG_MIPI_SYST_ENABLE is not set # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set CONFIG_LOG_BACKEND_SHOW_COLOR=y # CONFIG_LOG_INFO_COLOR_GREEN is not set CONFIG_LOG_TAG_MAX_LEN=0 CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set # end of Output Formatting # # Backends # # CONFIG_LOG_BACKEND_FS is not set # CONFIG_LOG_BACKEND_NET is not set CONFIG_LOG_BACKEND_UART=y CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1 CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y # CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set # CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0 # CONFIG_LOG_BACKEND_IPC_SERVICE is not set # end of Backends # # Misc # CONFIG_LOG_DOMAIN_ID=0 CONFIG_LOG_USE_VLA=y # CONFIG_LOG_ALWAYS_RUNTIME is not set # CONFIG_LOG_FMT_SECTION is not set # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set # CONFIG_LOG_MEM_UTILIZATION is not set CONFIG_LOG_FAILURE_REPORT_PERIOD=1000 # end of Misc CONFIG_LOG_OUTPUT=y # end of Logging # # Device Management # # # Host command handler subsystem # # CONFIG_EC_HOST_CMD is not set # end of Host command handler subsystem # CONFIG_MCUMGR is not set # CONFIG_HAWKBIT is not set # CONFIG_UPDATEHUB is not set # CONFIG_OSDP is not set # end of Device Management # CONFIG_MODBUS is not set # # Networking # CONFIG_NET_BUF=y CONFIG_NET_BUF_USER_DATA_SIZE=0 # CONFIG_NET_BUF_LOG is not set # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set CONFIG_NET_BUF_LOG_LEVEL_INF=y # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set CONFIG_NET_BUF_LOG_LEVEL=3 # CONFIG_NET_BUF_POOL_USAGE is not set CONFIG_NETWORKING=y # CONFIG_NET_HOSTNAME_ENABLE is not set # # Link layer options # # CONFIG_NET_L2_DUMMY is not set # CONFIG_NET_L2_BT_SHELL is not set # CONFIG_NET_L2_VIRTUAL is not set # CONFIG_NET_L2_PPP is not set # CONFIG_NET_L2_OPENTHREAD is not set # CONFIG_NET_L2_CUSTOM_IEEE802154 is not set # CONFIG_NET_L2_CANBUS_RAW is not set # CONFIG_NET_L2_WIFI_MGMT is not set # CONFIG_NET_L2_WIFI_SHELL is not set # CONFIG_NET_L2_PTP is not set # end of Link layer options # # IP stack # CONFIG_NET_IP=y # CONFIG_NET_NATIVE is not set # CONFIG_NET_OFFLOAD is not set CONFIG_NET_INIT_PRIO=90 CONFIG_NET_IP_DSCP_ECN=y CONFIG_NET_IF_MAX_IPV6_COUNT=1 CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=2 CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=3 CONFIG_NET_IF_IPV6_PREFIX_COUNT=2 CONFIG_NET_INITIAL_HOP_LIMIT=64 CONFIG_NET_IPV6_MAX_NEIGHBORS=8 # CONFIG_NET_IPV6_FRAGMENT is not set CONFIG_NET_IPV6_ND=y CONFIG_NET_IPV6_DAD=y CONFIG_NET_IPV6_RA_RDNSS=y # CONFIG_NET_6LO is not set CONFIG_NET_IPV6_LOG_LEVEL=0 CONFIG_NET_ICMPV6_LOG_LEVEL=0 CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL=0 CONFIG_NET_IPV4=y CONFIG_NET_INITIAL_TTL=64 CONFIG_NET_IF_MAX_IPV4_COUNT=1 CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1 CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT=1 # CONFIG_NET_ICMPV4_ACCEPT_BROADCAST is not set # CONFIG_NET_IPV4_ACCEPT_ZERO_BROADCAST is not set # CONFIG_NET_IPV4_IGMP is not set # CONFIG_NET_DHCPV4 is not set # CONFIG_NET_IPV4_HDR_OPTIONS is not set # CONFIG_NET_IPV4_FRAGMENT is not set CONFIG_NET_IPV4_LOG_LEVEL=0 CONFIG_NET_ICMPV4_LOG_LEVEL=0 # CONFIG_NET_SHELL is not set CONFIG_NET_TC_TX_COUNT=0 CONFIG_NET_TC_RX_COUNT=1 # CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set CONFIG_NET_TC_THREAD_COOPERATIVE=y # CONFIG_NET_TC_THREAD_PREEMPTIVE is not set CONFIG_NET_TC_NUM_PRIORITIES=16 CONFIG_NET_TC_MAPPING_STRICT=y CONFIG_NET_TX_DEFAULT_PRIORITY=1 CONFIG_NET_RX_DEFAULT_PRIORITY=0 CONFIG_NET_IP_ADDR_CHECK=y CONFIG_NET_MAX_ROUTERS=2 CONFIG_NET_ROUTE=y CONFIG_NET_MAX_ROUTES=8 CONFIG_NET_MAX_NEXTHOPS=8 # CONFIG_NET_ROUTE_MCAST is not set # CONFIG_NET_TCP is not set # CONFIG_NET_TEST_PROTOCOL is not set CONFIG_NET_UDP=y CONFIG_NET_UDP_CHECKSUM=y # CONFIG_NET_UDP_MISSING_CHECKSUM is not set CONFIG_NET_UDP_LOG_LEVEL=0 CONFIG_NET_MAX_CONN=8 CONFIG_NET_MAX_CONTEXTS=6 # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set CONFIG_NET_CONTEXT_SYNC_RECV=y CONFIG_NET_CONTEXT_CHECK=y # CONFIG_NET_CONTEXT_PRIORITY is not set # CONFIG_NET_CONTEXT_TXTIME is not set # CONFIG_NET_CONTEXT_RCVTIMEO is not set # CONFIG_NET_CONTEXT_SNDTIMEO is not set # CONFIG_NET_CONTEXT_RCVBUF is not set # CONFIG_NET_CONTEXT_SNDBUF is not set CONFIG_NET_CONTEXT_DSCP_ECN=y # CONFIG_NET_TEST is not set # CONFIG_NET_TRICKLE is not set CONFIG_NET_BUF_RX_COUNT=16 CONFIG_NET_BUF_TX_COUNT=16 CONFIG_NET_BUF_FIXED_DATA_SIZE=y # CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set CONFIG_NET_BUF_DATA_SIZE=128 CONFIG_NET_DEFAULT_IF_FIRST=y # CONFIG_NET_DEFAULT_IF_UP is not set # CONFIG_NET_PROMISCUOUS_MODE is not set # CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set # # Stack usage # CONFIG_NET_TX_STACK_SIZE=1200 CONFIG_NET_RX_STACK_SIZE=1500 # end of Stack usage # CONFIG_NET_MGMT is not set # CONFIG_NET_STATISTICS is not set # CONFIG_NET_LOG is not set CONFIG_NET_PKT_LOG_LEVEL=0 # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0 # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set CONFIG_NET_CORE_LOG_LEVEL=0 CONFIG_NET_IF_LOG_LEVEL=0 CONFIG_NET_TC_LOG_LEVEL=0 CONFIG_NET_UTILS_LOG_LEVEL=0 CONFIG_NET_CONTEXT_LOG_LEVEL=0 CONFIG_NET_CONN_LOG_LEVEL=0 CONFIG_NET_ROUTE_LOG_LEVEL=0 # end of IP stack # # Network Packet Filtering # # CONFIG_NET_PKT_FILTER is not set # end of Network Packet Filtering # # Network Protocols # # CONFIG_COAP is not set # CONFIG_DNS_SD is not set CONFIG_MQTT_LIB=y CONFIG_MQTT_LOG_LEVEL=0 CONFIG_MQTT_KEEPALIVE=1200 CONFIG_MQTT_LIB_TLS=y # CONFIG_MQTT_LIB_WEBSOCKET is not set # CONFIG_MQTT_LIB_CUSTOM_TRANSPORT is not set # CONFIG_TFTP_LIB is not set # CONFIG_HTTP_PARSER is not set # CONFIG_HTTP_PARSER_URL is not set # CONFIG_HTTP_CLIENT is not set CONFIG_NET_HTTP_LOG_LEVEL=0 # CONFIG_WEBSOCKET_CLIENT is not set # CONFIG_LWM2M is not set # CONFIG_SOCKS is not set CONFIG_SNTP=y CONFIG_SNTP_LOG_LEVEL=0 # end of Network Protocols # # Network Libraries # CONFIG_NET_CONFIG_AUTO_INIT=y CONFIG_NET_CONFIG_INIT_PRIO=95 CONFIG_NET_CONFIG_INIT_TIMEOUT=30 # CONFIG_NET_CONFIG_NEED_IPV6_ROUTER is not set # CONFIG_NET_CONFIG_NEED_IPV4 is not set CONFIG_NET_CONFIG_LOG_LEVEL=0 # CONFIG_NET_CONFIG_SETTINGS is not set # CONFIG_NET_CONFIG_CLOCK_SNTP_INIT is not set CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50 CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_NET_SOCKETS_POLL_MAX=3 CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000 # CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set CONFIG_NET_SOCKETS_TLS_PRIORITY=45 CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40 # CONFIG_NET_SOCKETS_OFFLOAD_DISPATCHER is not set # CONFIG_NET_SOCKETS_PACKET is not set # CONFIG_NET_SOCKETS_CAN is not set # CONFIG_NET_SOCKETPAIR is not set CONFIG_NET_SOCKETS_LOG_LEVEL=0 # CONFIG_TLS_CREDENTIALS is not set # end of Network Libraries # # Network additional services # # CONFIG_NET_CONNECTION_MANAGER is not set # CONFIG_NET_CAPTURE is not set # end of Network additional services # end of Networking # # Portability # # end of Portability # # Power Management # # CONFIG_PM_LOG_LEVEL_OFF is not set # CONFIG_PM_LOG_LEVEL_ERR is not set # CONFIG_PM_LOG_LEVEL_WRN is not set CONFIG_PM_LOG_LEVEL_INF=y # CONFIG_PM_LOG_LEVEL_DBG is not set CONFIG_PM_LOG_LEVEL=3 # CONFIG_PM_S2RAM is not set CONFIG_PM_POLICY_DEFAULT=y # CONFIG_PM_POLICY_CUSTOM is not set # end of Power Management # CONFIG_SHELL is not set # CONFIG_STATS is not set # CONFIG_USB_DEVICE_STACK is not set # CONFIG_USBC_STACK is not set # CONFIG_SD_STACK is not set CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y CONFIG_IMG_BLOCK_BUF_SIZE=512 CONFIG_IMG_ERASE_PROGRESSIVELY=y # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set CONFIG_IMG_MANAGER_LOG_LEVEL_INF=y # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set CONFIG_IMG_MANAGER_LOG_LEVEL=3 CONFIG_UPDATEABLE_IMAGE_NUMBER=1 # # Random Number Generators # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y # CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set CONFIG_CSPRING_ENABLED=y CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y # end of Random Number Generators # # Storage # CONFIG_FLASH_MAP=y # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set CONFIG_STREAM_FLASH=y CONFIG_STREAM_FLASH_ERASE=y CONFIG_STREAM_FLASH_PROGRESS=y # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set CONFIG_STREAM_FLASH_LOG_LEVEL_DBG=y CONFIG_STREAM_FLASH_LOG_LEVEL=4 # end of Storage CONFIG_SETTINGS=y # CONFIG_SETTINGS_LOG_LEVEL_OFF is not set # CONFIG_SETTINGS_LOG_LEVEL_ERR is not set # CONFIG_SETTINGS_LOG_LEVEL_WRN is not set # CONFIG_SETTINGS_LOG_LEVEL_INF is not set CONFIG_SETTINGS_LOG_LEVEL_DBG=y CONFIG_SETTINGS_LOG_LEVEL=4 # CONFIG_SETTINGS_RUNTIME is not set CONFIG_SETTINGS_DYNAMIC_HANDLERS=y CONFIG_SETTINGS_FCB=y # CONFIG_SETTINGS_FS is not set # CONFIG_SETTINGS_NVS is not set # CONFIG_SETTINGS_CUSTOM is not set # CONFIG_SETTINGS_NONE is not set CONFIG_SETTINGS_FCB_NUM_AREAS=8 CONFIG_SETTINGS_FCB_MAGIC=0xc0ffeeee # CONFIG_TASK_WDT is not set # # Testing # # CONFIG_ZTEST is not set # CONFIG_ZTEST_MOCKING is not set # CONFIG_ZTRESS is not set # CONFIG_TEST is not set # CONFIG_TEST_USERSPACE is not set # end of Testing # CONFIG_TIMING_FUNCTIONS is not set # CONFIG_TRACING is not set # CONFIG_RTIO is not set # end of Sub Systems and OS Services CONFIG_TOOLCHAIN_ZEPHYR_0_15=y CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y # # Build and Link Features # # # Linker Options # # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set CONFIG_LINKER_ORPHAN_SECTION_WARN=y # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set CONFIG_HAS_FLASH_LOAD_OFFSET=y CONFIG_USE_DT_CODE_PARTITION=y CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y CONFIG_LD_LINKER_TEMPLATE=y # CONFIG_CMAKE_LINKER_GENERATOR is not set # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set CONFIG_KERNEL_ENTRY="__start" CONFIG_LINKER_SORT_BY_ALIGNMENT=y CONFIG_SRAM_OFFSET=0 # # Linker Sections # # CONFIG_LINKER_USE_BOOT_SECTION is not set # CONFIG_LINKER_USE_PINNED_SECTION is not set CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015 # end of Linker Sections # end of Linker Options # # Compiler Options # # CONFIG_CODING_GUIDELINE_CHECK is not set # CONFIG_NATIVE_APPLICATION is not set CONFIG_SIZE_OPTIMIZATIONS=y # CONFIG_SPEED_OPTIMIZATIONS is not set # CONFIG_DEBUG_OPTIMIZATIONS is not set # CONFIG_NO_OPTIMIZATIONS is not set CONFIG_COMPILER_COLOR_DIAGNOSTICS=y # CONFIG_FORTIFY_SOURCE_NONE is not set CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set CONFIG_COMPILER_OPT="" # CONFIG_MISRA_SANE is not set # end of Compiler Options # CONFIG_ASSERT_ON_ERRORS is not set # CONFIG_NO_RUNTIME_CHECKS is not set CONFIG_RUNTIME_ERROR_CHECKS=y # # Build Options # CONFIG_KERNEL_BIN_NAME="zephyr" CONFIG_OUTPUT_STAT=y # CONFIG_OUTPUT_SYMBOLS is not set CONFIG_OUTPUT_DISASSEMBLY=y # CONFIG_OUTPUT_DISASSEMBLE_ALL is not set CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set # CONFIG_BUILD_NO_GAP_FILL is not set CONFIG_BUILD_OUTPUT_BIN=y # CONFIG_BUILD_OUTPUT_EXE is not set # CONFIG_BUILD_OUTPUT_S19 is not set # CONFIG_BUILD_OUTPUT_UF2 is not set # CONFIG_BUILD_OUTPUT_STRIPPED is not set # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set # CONFIG_APPLICATION_DEFINED_SYSCALL is not set # CONFIG_MAKEFILE_EXPORTS is not set CONFIG_BUILD_OUTPUT_META=y # CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set # end of Build Options CONFIG_WARN_DEPRECATED=y CONFIG_ENFORCE_ZEPHYR_STDINT=y # end of Build and Link Features # # Boot Options # # CONFIG_IS_BOOTLOADER is not set CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="" # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set # CONFIG_BOOTLOADER_BOSSA is not set # end of Boot Options # # Compatibility # CONFIG_COMPAT_INCLUDES=y # end of Compatibility # CONFIG_LEGACY_INCLUDE_PATH is not set # end of Zephyr Kernel # CONFIG_APPLICATION_MODULE_LOG_LEVEL_OFF is not set # CONFIG_APPLICATION_MODULE_LOG_LEVEL_ERR is not set # CONFIG_APPLICATION_MODULE_LOG_LEVEL_WRN is not set # CONFIG_APPLICATION_MODULE_LOG_LEVEL_INF is not set CONFIG_APPLICATION_MODULE_LOG_LEVEL_DBG=y CONFIG_APPLICATION_MODULE_LOG_LEVEL=4
