button exmaple is not working in SDK version 9.0.0
Hello evryone,
i cloned button example form github to sdk version 9.0.0 and i modified the neccesary changes between app.gpiote.c//nrf_drv_gpiote.c files and set the GPIOTE ENABLED to 0 after that it is getting compiled with no errors but the baord shows nothing if the press any of the button can anyone suggest me what modifications has to be done or any changes?
ble_app_template.zip
Thank you
prabhu
  • Hi prabhudurai,
    still havent gone through your code, but had a quick look. I saw this below code in your init_gpio() function
    NRF_GPIO->PIN_CNF[6] = (GPIO_PIN_CNF_DRIVE_H0D1 << GPIO_PIN_CNF_DRIVE_Pos);
    This is wrong as you are setting every other bits to '0' and only setting the drive strength. With this the pin will be configured as input. To do this correctly, you need to do this below
    NRF_GPIO->PIN_CNF[6] &= ~(GPIO_PIN_CNF_DRIVE_Msk); // reset drive setting
    NRF_GPIO->PIN_CNF[6] |= (GPIO_PIN_CNF_DRIVE_H0D1 << GPIO_PIN_CNF_DRIVE_Pos); // set to high drive
    you need to do this for pin settings 7 also.
  • its not possible. because after three seconds we have to check that the button is still pressed and then you can either release the button after the 3 seconds or continue to press it for two more seconds. The decision cannot be made until 5 seconds are expired.
