nRF5340 AUDIO ,AUDIO FRAME DURATION
My project base on NCS V2.2.0.BIS mode,gateway
My "AUDIO FRAME DURATION" is 10ms.But my audio source is not i2s or usb.
My audio come from uart,1M bit/s.It will take 2-3ms.
and Lc3 encode take 5-6 ms.then time is not enough.
Can I modify this:AUDIO_FRAME_DURATION_US(I tried ,but failed),or an I reduce LC3 encode time.
any advice will be helpful.
  • Thank you for elaborating.
    huniu said:
    2.LC3 encode need 6ms,I invert IO in "encoder_thread",it takes about 6ms.Then I have no time do my own work,such as another encode.
    I am not sure that I understand what you mean when you say 'I invert IO in 'encoder_thread'', could you clarify?
    The rule of thumb is that using the provided LC3 implementation it will require roughly 30% of the CPU time to encode a 96 kbps stream (at 48 kHz sampling), and roughly 15% to decode the same stream. So, if you are only encoding 1 or 2 streams you should still have ample time to do your own application work.
    huniu said:
    3.My codec only suport 44.1K,So I need 44.1K.
    To be specific, is this a hardware codec you are referring to, or a software codec (like the LC3, or an equivalent)?
    In case of the latter please note that you must have the LC3 as the primary codec on your device if you intend to qualify as a LE Audio product (you are allowed to have proprietary secondary codecs in addition to the LC3, of course).
    Karl
  • 1.
    static void encoder_thread(void *arg1, void *arg2, void *arg3)
    	int ret;
    	uint32_t blocks_alloced_num;
    	uint32_t blocks_locked_num;
    	int debug_trans_count = 0;
    	size_t encoded_data_size = 0;
    	void *tmp_pcm_raw_data[CONFIG_FIFO_FRAME_SPLIT_NUM];
    	char pcm_raw_data[FRAME_SIZE_BYTES];
    	static uint8_t *encoded_data;
    	static size_t pcm_block_size;
    	static uint32_t test_tone_finite_pos;
    	while (1) {
    		/* Get PCM data from I2S */
    		/* Since one audio frame is divided into a number of
    		 * blocks, we need to fetch the pointers to all of these
    		 * blocks before copying it to a continuous area of memory
    		 * before sending it to the encoder
    		for (int i = 0; i < CONFIG_FIFO_FRAME_SPLIT_NUM; i++) {
    			ret = data_fifo_pointer_last_filled_get(&fifo_rx, &tmp_pcm_raw_data[i],
    								&pcm_block_size, K_FOREVER);
    			ERR_CHK(ret);
    			memcpy(pcm_raw_data + (i * BLOCK_SIZE_BYTES), tmp_pcm_raw_data[i],
    			       pcm_block_size);
    			data_fifo_block_free(&fifo_rx, &tmp_pcm_raw_data[i]);
    		IO_invert();
    		if (sw_codec_cfg.encoder.enabled) {
    			if (test_tone_size) {
    				/* Test tone takes over audio stream */
    				uint32_t num_bytes;
    				char tmp[FRAME_SIZE_BYTES / 2];
    				ret = contin_array_create(tmp, FRAME_SIZE_BYTES / 2, test_tone_buf,
    							  test_tone_size, &test_tone_finite_pos);
    				ERR_CHK(ret);
    				ret = pscm_copy_pad(tmp, FRAME_SIZE_BYTES / 2,
    						    CONFIG_AUDIO_BIT_DEPTH_BITS, pcm_raw_data,
    						    &num_bytes);
    				ERR_CHK(ret);
    			ret = sw_codec_encode(pcm_raw_data, FRAME_SIZE_BYTES, &encoded_data,
    					      &encoded_data_size);
    			ERR_CHK_MSG(ret, "Encode failed");
    		/* Print block usage */
    		if (debug_trans_count == DEBUG_INTERVAL_NUM) {
    			ret = data_fifo_num_used_get(&fifo_rx, &blocks_alloced_num,
    						     &blocks_locked_num);
    			ERR_CHK(ret);
    			LOG_DBG(COLOR_CYAN "RX alloced: %d, locked: %d" COLOR_RESET,
    				blocks_alloced_num, blocks_locked_num);
    		} else {
    			debug_trans_count++;
    			/* Send encoded data over IPM */
    			streamctrl_encoded_data_send(encoded_data, encoded_data_size);
    		IO_invert();
    		STACK_USAGE_PRINT("encoder_thread", &encoder_thread_data);
    line 33 and line 72.IO invert,take about 6ms
    2.I mean hardware codec.
  • 1. That is not an accurate way to measure the execution time, since the nRF Connect SDK is build on the Zephyr RTOS, and this process runs as a thread - i.e it may be interrupted so long as it fulfills its real-time constraints. The way you are measuring it indicates that it is blocking, but this is not the case - other tasks and threads can run inbetween, depending on their priority.
    You could instead use runtime statistics if you want to know what percent of the CPU is being used by a specific thread, for instance.
    2. Thank you for clarifying.
    Karl
  • 1.You are right,I fixed this.Now is not a problem.
    2.I still confuse.Can BIS mode suport 44.1K biterate.My hardware only suport 44.1K biterate,So I need LC3 suprot 44.1K,but seems like LC3 not suport 44.1K in project NRF5340 Audio.
    Great, I am happy to hear that! :)
    This is correct - there is unfortunately no support for 44.1 kHz in the nRF5340 Audio reference application as of now.
    Karl
