Reading temperature data from DS18B20 sensor using nRF5340-DK
Hello everyone , I'm having trouble activating my DS18B20 temperature sensor (waterproof) with the nRF5340, SDK v2.3.0, and VS Code. I'm using the "zephyr/samples/sensor/ds18b20" template and have created the overlay file, but when I try to flash it, I get the error " no device found"  despite the wiring is correct
Wiring :
GND + GND (nrf5340)
VCC + VDD (nrf5340)
DATA + P1.10 (nrf5340)
I think that the problem is in the overlay file .
Thanks.
Here is my code
main.c
 * Copyright (c) 2022 Thomas Stranger
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/sensor.h>
 * Get a device structure from a devicetree node with compatible
 * "maxim,ds18b20". (If there are multiple, just pick one.)
static const struct device *get_ds18b20_device(void)
	const struct device *const dev = DEVICE_DT_GET_ANY(maxim_ds18b20);
	if (dev == NULL) {
		/* No such node, or the node does not have status "okay". */
		printk("\nError: no device found.\n");
		return NULL;
	if (!device_is_ready(dev)) {
		printk("\nError: Device \"%s\" is not ready; "
		       "check the driver initialization logs for errors.\n",
		       dev->name);
		return NULL;
	printk("Found device \"%s\", getting sensor data\n", dev->name);
	return dev;
void main(void)
	const struct device *dev = get_ds18b20_device();
	if (dev == NULL) {
		return;
	while (1) {
		struct sensor_value temp;
		sensor_sample_fetch(dev);
		sensor_channel_get(dev, SENSOR_CHAN_AMBIENT_TEMP, &temp);
		printk("Temp: %d.%06d\n", temp.val1, temp.val2);
		k_sleep(K_MSEC(2000));
prj.conf
CONFIG_SENSOR=y
CONFIG_W1=y
CONFIG_LOG=y
CONFIG_SENSOR_LOG_LEVEL_DBG=y
C:\ncs\ds18b20\nrf5340dk_nrf5340_cpuapp.overlay
// To get started, press Ctrl+Space to bring up the completion menu and view the available nodes.
// You can also use the buttons in the sidebar to perform actions on nodes.
// Actions currently available include:
// * Enabling / disabling the node
// * Adding the bus to a bus
// * Removing the node
// * Connecting ADC channels
// For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html
// You can also visit the nRF DeviceTree extension documentation at https://nrfconnect.github.io/vscode-nrf-connect/devicetree/nrfdevicetree.html
 * Copyright (c) 2022, Thomas Stranger
 * Example configuration of a DS18B20 device on an Arduino serial bus.
 * Requires external circuit to provide an open-drain interface.
	w1_0: w1-zephyr-serial-0 {
		compatible = "zephyr,w1-serial";
		#address-cells = <1>;
		#size-cells = <0>;
		status = "okay";
		ds18b20 {
			compatible = "maxim,ds18b20";
			family-code = <0x28>;
			resolution = <12>;
			status = "okay";
