I'm trying to apply DFU with MCUboot and SMP BT protocol
to signing with my key.
I try to set CONFIG_SIGNATURE_KEY_FILE in CMakeList.txt
set(BOOT_SIGNATURE_KEY_FILE $ENV{HOME}/Project/nRFConnectProject/caresix.pem ) if(DEFINED BOOT_SIGNATURE_KEY_FILE) set(CONFIG_BOOT_SIGNATURE_KEY_FILE "\"${BOOT_SIGNATURE_KEY_FILE}\"") set(mcuboot_CONFIG_BOOT_SIGNATURE_KEY_FILE ${CONFIG_BOOT_SIGNATURE_KEY_FILE} ) set(hci_rpmsg_CONFIG_BOOT_SIGNATURE_KEY_FILE ${CONFIG_BOOT_SIGNATURE_KEY_FILE} ) message("Signing Key is applied: ${mcuboot_CONFIG_BOOT_SIGNATURE_KEY_FILE}") endif()
But, Building project is failed and got following message.
FAILED: zephyr/net_core_app_update.bin
cd /Users/woochankim/Project/nRFConnectProject/peripheral_lbs_rf_fem/build_nrf5340dk/modules/mcuboot && /opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-objcopy --input-target=ihex --output-target=binary --gap-fill=0xff /Users/woochankim/Project/nRFConnectProject/peripheral_lbs_rf_fem/build_nrf5340dk/hci_rpmsg/zephyr/signed_by_b0_app.hex /Users/woochankim/Project/nRFConnectProject/peripheral_lbs_rf_fem/build_nrf5340dk/zephyr/net_core_app_to_sign.bin && /opt/nordic/ncs/toolchains/v2.3.0/bin/python3.9 /opt/nordic/ncs/v2.3.0/bootloader/mcuboot/scripts/imgtool.py sign --key /opt/nordic/ncs/v2.3.0/bootloader/mcuboot/"/Users/woochankim/Project/nRFConnectProject/caresix.pem" --header-size 0x200 --align 4 --version 0.0.0+0 --pad-header --slot-size 0x78000 /Users/woochankim/Project/nRFConnectProject/peripheral_lbs_rf_fem/build_nrf5340dk/zephyr/net_core_app_to_sign.bin /Users/woochankim/Project/nRFConnectProject/peripheral_lbs_rf_fem/build_nrf5340dk/zephyr/net_core_app_update.bin
File "/opt/nordic/ncs/v2.3.0/bootloader/mcuboot/scripts/imgtool.py", line 22, in <module>
main.imgtool()
File "/opt/nordic/ncs/toolchains/v2.3.0/Cellar/[email protected]/3.9.6/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/click/core.py", line 829, in __call__
return self.main(*args, **kwargs)
File "/opt/nordic/ncs/toolchains/v2.3.0/Cellar/[email protected]/3.9.6/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/opt/nordic/ncs/toolchains/v2.3.0/Cellar/[email protected]/3.9.6/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/click/core.py", line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/opt/nordic/ncs/toolchains/v2.3.0/Cellar/[email protected]/3.9.6/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/click/core.py", line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/opt/nordic/ncs/toolchains/v2.3.0/Cellar/[email protected]/3.9.6/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/opt/nordic/ncs/v2.3.0/bootloader/mcuboot/scripts/imgtool/main.py", line 365, in sign
key = load_key(key) if key else None
File "/opt/nordic/ncs/v2.3.0/bootloader/mcuboot/scripts/imgtool/main.py", line 85, in load_key
key = keys.load(keyfile)
File "/opt/nordic/ncs/v2.3.0/bootloader/mcuboot/scripts/imgtool/keys/__init__.py", line 46, in load
with open(path, 'rb') as f:
FileNotFoundError: [Errno 2] No such file or directory: '/opt/nordic/ncs/v2.3.0/bootloader/mcuboot//Users/woochankim/Project/nRFConnectProject/caresix.pem'
[78/383] Generating ../../zephyr/net_core_app_signed.hex
FAILED: zephyr/net_core_app_signed.hex
cd /Users/woochankim/Project/nRFConnectProject/peripheral_lbs_rf_fem/build_nrf5340dk/modules/mcuboot && /opt/nordic/ncs/toolchains/v2.3.0/bin/python3.9 /opt/nordic/ncs/v2.3.0/bootloader/mcuboot/scripts/imgtool.py sign --key /opt/nordic/ncs/v2.3.0/bootloader/mcuboot/"/Users/woochankim/Project/nRFConnectProject/caresix.pem" --header-size 0x200 --align 4 --version 0.0.0+0 --pad-header --slot-size 0x78000 /Users/woochankim/Project/nRFConnectProject/peripheral_lbs_rf_fem/build_nrf5340dk/hci_rpmsg/zephyr/signed_by_b0_app.hex /Users/woochankim/Project/nRFConnectProject/peripheral_lbs_rf_fem/build_nrf5340dk/zephyr/net_core_app_signed.hex
main.imgtool()
finally I can find where the key path generated.<zephyr_base>/nrf/modules/mcuboot/CMakeLists.txt
there is a bug
if(IS_ABSOLUTE ${CONFIG_BOOT_SIGNATURE_KEY_FILE}) set(mcuboot_key_file ${CONFIG_BOOT_SIGNATURE_KEY_FILE}) elseif (DEFINED mcuboot_CONF_DIR) if (EXISTS ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE}) set(mcuboot_key_file ${mcuboot_CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE}) endif() endif()
Absolute path always failed, because KCONFIG String CONFIG_BOOT_SIGNATURE_KEY_FILE wrapped with double quotes.
So, we need to fix this problem.
temporary, i add this code front of upper code.
separate_arguments(CONFIG_BOOT_SIGNATURE_KEY_FILE UNIX_COMMAND ${CONFIG_BOOT_SIGNATURE_KEY_FILE} )
thanks!!
