Hi! I'm using the nRF52-DK development kit to implement secure communications via Bluetooth Low Energy (BLE) on Zephyr. For that I'm using the "Peripheral NFC Pairing" example from the nRF Connect SDK (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bluetooth/peripheral_nfc_pairing/README.html) for pairing in LE Secure Connections with Out Of Band (OOB) mode. In this example I'm using the nRF52-DK board with NFC antenna (NFC Forum Tag) and my smartphone (Huawei P30 Lite) as the NFC Poller Device. To verify the exchanged BLE packets I'm using an nRF Dongle with Wireshark as a BLE Sniffer.
However, I'm having problems with this example on verifying the packets exchanged since as soon as I touch the NFC antenna with my smartphone I cannot see any Security Manager Protocol (SMP) packet exchanged in Wireshark. I needed to visualize these packets to ensure that Pairing Feature Exchange and next pairing steps (key exchange) are occurring as intended (LE Secure Connections OOB pairing).
Another problem that I also detected is that after a first pairing of my smartphone with the board (accepting the pairing request announced in the pop-up window displayed on the smartphone), in subsequent pairings the pop-up window does not appear again (even when cleaning the bonds of the nRF52-DK board), so in these cases the pairing does not work with the intended security level. The only solution found for this problem was to clear the cache of the smartphone's Bluetooth application. However, this situation proves to be quite uncomfortable since it is necessary to restart the smartphone whenever the application's cache is cleared. I would like to know if there is another option to clear all BLE bonds from android smartphones.
I also leave the prj.conf file below.
CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_DK_LIBRARY=y CONFIG_NFC_T4T_NRFXLIB=y CONFIG_NFC_NDEF=y CONFIG_NFC_NDEF_MSG=y CONFIG_NFC_NDEF_RECORD=y CONFIG_NFC_NDEF_LE_OOB_REC=y CONFIG_NFC_NDEF_CH_MSG=y CONFIG_NFC_NDEF_TNEP_RECORD=y CONFIG_NFC_TNEP_TAG=y CONFIG_NFC_NDEF_PARSER=y CONFIG_NFC_NDEF_CH_PARSER=y CONFIG_NFC_NDEF_LE_OOB_REC_PARSER=y CONFIG_NFC_TNEP_CH=y CONFIG_BT=y CONFIG_BT_SMP=y CONFIG_BT_SMP_APP_PAIRING_ACCEPT=y # Added # enable the possibility of LE Secure Connections CONFIG_BT_TINYCRYPT_ECC=y # specify Secure Connections Only mode CONFIG_BT_SMP_SC_ONLY=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME="Nordic_NFC_pairing" CONFIG_BT_DIS=y CONFIG_BT_DIS_PNP=y CONFIG_BT_DIS_MANUF="NordicSemiconductor" CONFIG_BT_DIS_PNP_VID_SRC=2 CONFIG_BT_DIS_PNP_VID=0x1915 CONFIG_BT_DIS_PNP_PID=0xEEEB CONFIG_BT_DIS_PNP_VER=0x0100 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_MAIN_STACK_SIZE=3072 CONFIG_BT_SETTINGS=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y CONFIG_DK_LIBRARY=y CONFIG_POLL=y
I look forward to any help, thank you!
