nrf52840 zephyr disable uart0 warning
It has been asked before but I couldn't find a satisfying answer so far. To reduce base power consumption of 600uA to roughly 3uA I disabled serial by setting CONFIG_SERIAL=n in prj.conf. But I get the following warning:
warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: SERIAL (=n), SERIAL_HAS_DRIVER (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_CONSOLE and/or look up UART_CONSOLE in
the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
It does work however, and the powerconsumption is reduced. I'm on SDK v2.3.0.
I also tried to just disable serial in the device tree, but it's called somewhere in the project (probably <zephyr/logging/log.h>, so the build crashes unless I do the above.)
&pinctrl {
    uart0_default: uart0_default {
    		status="disabled";
I also tried disabling using setting the powerstate at runtime, but I cannot figure the arguments I've to put in the function, as the signature has changed over time and I'm unable to find a current example. The latest I could find is of Zephyr 1.4.
int pm_device_state_set(conststructdevice*dev, uint32_t device_power_state,pm_device_cbcb,void*arg)
Question why is this warning and what is the right way to disable serial (or reduce power).
Edit: I guess it should be
err = pm_device_action_run(device, PM_DEVICE_ACTION_SUSPEND);
during runtime.
  • CONFIG_SERIAL=n in prj.conf. But I get the following warning:
    Use the "Kconfig" search in VS Code to determine what sets this to "y".
    Just looks like you set UART_CONSOLE in you project config somewhere, and it is automatically set to "n" when you disable SERIAL, which makes sense to me.
    You try to disable uart0 inside pinctrl, and not inside the driver itself. Try:
    &uart0 {
        status = "disabled";
    Then after you build, have a look at build/zephyr/zephyr.dts to verify that all the drivers have the expected status.
    Both DeviceTree and Power Management are good ways to disable a peripheral to save power.
    Use the DeviceTree if you never intend to use that peripheral.
    Use the Power Management if you intend to use the peripheral sporadically.
    Sigurd Hellesvik
  • Nope, disabling like that in the devicetree does not work,
    /home/bergm006/ncs/v2.3.0/zephyr/include/zephyr/device.h:83:41: error: '__device_dts_ord_114' undeclared here (not in a function); did you mean '__device_dts_ord_11'?
       83 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
    I did not include device.h in my project.
    #include <stdio.h>
    #include <zephyr/kernel.h>
    #include <zephyr/types.h>
    #include <zephyr/pm/pm.h>
    #include <zephyr/pm/device.h>
    #include <stddef.h>
    #include <string.h>
    #include <errno.h>
    #include <zephyr/sys/byteorder.h>
    #include <zephyr/settings/settings.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <zephyr/drivers/i2c.h>
    Can you post your prj.conf as well?
    Sigurd Hellesvik
  • CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
    CONFIG_HEAP_MEM_POOL_SIZE=2048
    CONFIG_BT=y
    CONFIG_BT_SMP=y
    CONFIG_BT_SIGNING=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DIS=y
    CONFIG_BT_ATT_PREPARE_COUNT=5
    CONFIG_BT_PRIVACY=y
    CONFIG_BT_DEVICE_NAME="xxx"
    CONFIG_BT_DEVICE_APPEARANCE=3137
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    CONFIG_BT_DEVICE_NAME_MAX=65
    CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
    CONFIG_BT_SETTINGS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_I2C=y
    CONFIG_EVENTS=y
    CONFIG_SERIAL=n
    CONFIG_LOG=n
    CONFIG_PM=y
    CONFIG_PM_DEVICE=y
    (The error only occures when CONFIG_SERIAL=y, when '=n, the warning of the first post appears.)
  • To make things simpler the hello world project has the same issue.
    void main(void)
    	while(1) {
    		k_sleep(K_MSEC(1000));
    &uart0 {
    proj.conf empty (and when I add CONFIG_SERIAL=n the same warning appears)
