Installing OTBR manually (Raspberry Pi) on Ubuntu fails
Dear Support Team,
I am following the guide at https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.3.0/nrf/protocols/matter/getting_started/testing/thread_one_otbr.html to implement an OTBR and chiptool on my Raspberry Pi 3 device. Previously, I was able to set up a working OTBR on the Pi running the 2021-05-07-raspios-buster-armhf-lite OS.
However, I have encountered an issue when attempting to run the OTBR on the Pi while using Ubuntu Server 22.04.2 LTS (64 bit) or Ubuntu Server 20.04.5 LTS (64 bit). Every time I enter the command "INFRA_IF_NAME=wlan0 ./script/setup", the build freezes at the same place "[403/454] Building CXX object src/dbus/server/CMakeFiles/otbr-dbus-server.dir/dbus_object.cpp.o" ( I am unable to open another connection to the Pi using Putty so I guess the CPU froze).
I would greatly appreciate your help in resolving this issue. Please let me know if you need any additional information.
Thank you.
    Which SD card are you using on your Raspberry Pi, and what size is it?
    Please run "ip a" on the Pi and share the log here.
    Marte
    I'm using an 16GB microSD HC A1 class 10.
    I ran the cmd "ip a" after the build got stuck at "[403/454] Building CXX object src/dbus/server/CMakeFiles/otbr-dbus-server.dir/dbus_object.cpp.o", here's the result :
    rasp@raspberrypi:~/ot-br-posix$ ip a
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        inet 127.0.0.1/8 scope host lo
           valid_lft forever preferred_lft forever
        inet6 ::1/128 scope host
    2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
        link/ether b8:27:eb:54:55:16 brd ff:ff:ff:ff:ff:ff
    3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
        link/ether b8:27:eb:01:00:43 brd ff:ff:ff:ff:ff:ff
        inet 192.168.2.13/24 metric 600 brd 192.168.2.255 scope global dynamic wlan0
           valid_lft 85610sec preferred_lft 85610sec
        inet6 2a01:cb04:b43:a300:ba27:ebff:fe01:43/64 scope global dynamic mngtmpaddr noprefixroute
           valid_lft 86375sec preferred_lft 575sec
        inet6 fe80::ba27:ebff:fe01:43/64 scope link
    I see no issues from the "ip a" command. You may be running out of RAM. Can you run "htop" in parallel with the "INFRA_IF_NAME=wlan0 ./script/setup" command to observe RAM and CPU usage of running the command?
    Marte
    I have ~ 1GB RAM on the raspberry which was not enough for the build.
    I added 1GB swap memory and I am now able to finish the build succesfully.
    Thank you
