SPI example for nRF52833 with nRF Connect SDK 2.3.0
Dear Support Team,
I just started evaluating a nRF52833 DK board with the nRF Connect SDK 2.3.0. At this point I would like to start playing with the SPI but unfortunately I can't find any working example that I could use.
Could you please point me to a working example without using the deprecated configuration parameters?
Thank you very much in advance and all the best,
Viktor
  • Hi Viktor,
    Spi-dev-a@-0 is the name of the devicetree node. As an example you can look at the example DTS file in Devicetree Guide - Syntax and structure:
    /dts-v1/;
            a-node {
                    subnode_nodelabel: a-sub-node {
                            foo = <3>;
    Here, a-sub-node is the same as spi-dev-a@0 in your case.
    For SPI devices, the 'reg' property is the chip select number. One SPI node (SPI0, SPI1, etc.) does not affect the reg property of another SPI node. If, however, you have more sub-nodes under an SPI node, then you need to make sure they have different chip select numbers. For example, the Thingy53 has three different SPI sub-nodes under SPI3, which must have different chip select numbers. This is from thingy53_nrf5340_common.dts:
    &spi3 {
    	status = "okay";
    	cs-gpios = <&gpio0 22 GPIO_ACTIVE_LOW>,
    		   <&gpio1 4  GPIO_ACTIVE_LOW>,
    		   <&gpio0 24 GPIO_ACTIVE_LOW>;
    	pinctrl-0 = <&spi3_default>;
    	pinctrl-1 = <&spi3_sleep>;
    	adxl362: spi-dev-adxl362@0 {
    		compatible = "adi,adxl362";
    		spi-max-frequency = <8000000>;
    		reg = <0>;
    		int1-gpios = <&gpio0 19 0>;
    	bmi270: spi-dev-bmi270@1 {
    		compatible = "bosch,bmi270";
    		status = "disabled";
    		reg = <1>;
    	nrf_radio_fem_spi: fem_spi@2 {
    		compatible = "nordic,nrf21540-fem-spi";
    		reg = <2>;
    The 'reg' property is used for different things based on the device. For more information see Devicetree Guide - Important properties.
    Marte
  • Hi Marte,
    Thank you very much! This is very helpful information!
    All the best,
    Viktor
  • Hi all,
    Perhaps I should open a new thread but since my problem is close to this one, I'll tap it in here.
    I tried to use this example in a clean  nRF Connect SDK 2.6.0. project on nRF52840 DK just to try and get simple spi master operation going. However, I'm running into all sorts of build error which don't make sense to me.
    My overlay is:
    &pinctrl {
    	spi1_default: spi1_default {
    		group1 {
    			psels = <NRF_PSEL(SPIM_SCK, 1, 15)>,
    					<NRF_PSEL(SPIM_MOSI, 1, 13)>,
    					<NRF_PSEL(SPIM_MISO, 1, 14)>;
    	spi1_sleep: spi1_sleep {
    		group1 {
    			low-power-enable;
    my_spi_master: &spi1 {
    	compatible = "nordic,nrf-spi";
    	status = "okay";
    	pinctrl-0 = <&spi1_default>;
    	pinctrl-1 = <&spi1_sleep>;
    	cs-gpios = <&gpio0 28 GPIO_ACTIVE_LOW>;
    	reg_my_spi_master: spi-dev-a@0 {
    		reg = <0>;
    &pwm0 {
    main.c is:
    #include <zephyr/kernel.h>
    #include <zephyr/device.h>
    #include <zephyr/drivers/spi.h>
    #define MY_SPI_MASTER DT_NODELABEL(my_spi_master)
    #define DEVICE_ID
    uint8_t TX0BUFF[3];
    uint8_t TX1BUFF[3];
    // SPI master functionality
    const struct device *spi_dev;
    struct spi_cs_control spim_cs = {
    	.gpio = SPI_CS_GPIOS_DT_SPEC_GET(DT_NODELABEL(reg_my_spi_master)),
    	.delay = 0,
    static const struct spi_config spi_cfg = {
    	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB |
    				 SPI_MODE_CPOL | SPI_MODE_CPHA,
    	.frequency = 1600000,
    	.slave = 0,
    	.cs = &spim_cs,
    static void spi_init(void)
    	spi_dev = DEVICE_DT_GET(MY_SPI_MASTER);
    	if(!device_is_ready(spi_dev)) {
    		printk("SPI master device not ready!\n");
    	if(!device_is_ready(spim_cs.gpio.port)){
    		printk("SPI master chip select device not ready!\n");
    static int spi_test(void)
    	static uint8_t tx_buffer[3];
    	static uint8_t rx_buffer[3];
    	const struct spi_buf tx_buf = {
    		.buf = tx_buffer,
    		.len = sizeof(tx_buffer)
    	const struct spi_buf_set tx = {
    		.buffers = &tx_buf,
    		.count = 1
    	struct spi_buf rx_buf = {
    		.buf = rx_buffer,
    		.len = sizeof(rx_buffer),
    	const struct spi_buf_set rx = {
    		.buffers = &rx_buf,
    		.count = 1
    	first 2 bytes of tx specify read/write action and on which register to perform
    	last byte of rx contains the respons from the accelerometer
    	tx_buffer[0] = TX0BUFF;
    	tx_buffer[1] = TX1BUFF;
    	int error = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
    	if(error != 0){
    		printk("SPI transceive error: %i\n", error);
    		return error;
    	if(DEVICE_ID == rx_buffer[2])
    		printk("Successfull ACC communication\n");
    		printk("Faild ACC communication\n");
    	return 0;
            return 0;
    proj.conf:
    # Enable DK LED and Buttons library
    CONFIG_DK_LIBRARY=y
    # This example requires more workqueue stack
    # Config logger
    CONFIG_LOG=y
    CONFIG_LOG_PRINTK=y
    CONFIG_SPI=y
    CONFIG_GPIO=y
    CONFIG_NRFX_SPIM1=y
    The errors I get:
        "resource": "/c:/NordicSemi/v1.9.1/zephyr/dts/bindings/pinctrl/atmel,sam0-pinctrl.yaml",
        "owner": "DeviceTree types",
        "severity": 8,
        "message": "Invalid type definition: Map keys must be unique at line 37, column 1:\n\n\r\nproperties:\n^\n",
        "startLineNumber": 1,
        "startColumn": 1,
        "endLineNumber": 1,
        "endColumn": 1
        "resource": "/c:/NordicSemi/v1.9.1/zephyr/dts/bindings/spi/st,stm32-spi-subghz.yaml",
        "severity": 8,
        "message": "Invalid type definition: Map keys must be unique at line 10, column 1:\n\n\r\ninclude:\n^\n",
        "startColumn": 1,
        "endLineNumber": 1,
        "endColumn": 1
    "resource": "/c:/nordicsemi/v1.9.1/zephyr/kconfig",
    "owner": "kconfig",
    "severity": 8,
    "message": "C:\\nordicsemi\\v2.6.0\\nrf\\subsys\\nfc\\lib\\kconfig:89: error: couldn't parse 'default y if $(dt_has_compat,$(DT_COMPAT_NORDIC_NRF_EGU)) || \t\t $(dt_has_compat,$(DT_COMPAT_NORDIC_NRF_SWI))': macro expanded to blank string",
    "startLineNumber": 8,
    "startColumn": 1,
    "endLineNumber": 8,
    "endColumn": 100000
        "resource": "/c:/nordicsemi/v2.6.0/zephyr/kconfig",
        "owner": "kconfig",
        "severity": 8,
        "message": "C:\\nordicsemi\\v2.6.0\\zephyr\\soc\\arm\\nxp_imx\\rt5xx\\kconfig.defconfig.series:36: error: couldn't parse 'default $(dt_node_reg_addr_hex,$(DT_CHOSEN_FLASH_PARENT),1) \t\tif $(dt_node_has_compat,$(DT_CHOSEN_FLASH_PARENT),$(DT_COMPAT_FLEXSPI))': macro expanded to blank string",
        "startColumn": 1,
        "endLineNumber": 8,
        "endColumn": 100000
        "resource": "/c:/Users/pekka.lemmetyinen/spi_simple/src/main.c",
        "owner": "C/C++: IntelliSense",
        "code": "29",
        "severity": 8,
        "message": "expected an expression",
        "source": "C/C++",
        "startLineNumber": 80,
        "startColumn": 15,
        "endLineNumber": 80,
        "endColumn": 17
        "owner": "Kconfig options",
        "code": "missing_kconfig_param",
        "severity": 4,
        "message": "The GPIO drivers must be enabled by CONFIG_GPIO to be included in the build",
        "startLineNumber": 4,
        "startColumn": 1,
        "endLineNumber": 4,
        "endColumn": 33
        "severity": 4,
        "message": "The SPI drivers must be enabled by CONFIG_SPI to be included in the build",
        "startLineNumber": 5,
        "startColumn": 1,
        "endLineNumber": 5,
        "endColumn": 32
        "resource": "/c:/NordicSemi/v2.6.0/zephyr/modules/hal_nordic/nrfx/Kconfig",
        "owner": "nrf-connect",
        "severity": 4,
        "message": "NRFX_SPIM1 (defined at C:/NordicSemi/v2.6.0/zephyr/modules/hal_nordic\\nrfx/Kconfig:286,",
        "source": "kconfig",
        "startLineNumber": 286,
        "startColumn": 1,
        "endLineNumber": 286,
        "endColumn": 2147483647
    1. I don't get what this has to do with Atmel SAM or ST STM32 devices or their configs?
    2. I've configured CONFIGURE_SPI and GPIO in prpj.conf. VS Code is flagging that the drivers for
    needs to be configured. But I have done in prj.conf...?!?
    Bit of hand holding required, please, so that I would get the spi side up and running.
    Kind regards
    Peks1
  • Hi Peks1,
    First of all, I recommend looking at the build log in the terminal tab instead of the errors in the problems tab, as this gives you a better overview of the errors. Additionally, the errors from the problems tab might sometimes come from Intellisense and does not necessarily represent the build errors.
    When building your code, I get the following build log:
     *  Executing task: nRF Connect: Generate config nrf52840dk_nrf52840 for /home/marte/Downloads/hello_world
    Building hello_world
    west build --build-dir /home/marte/Downloads/hello_world/build /home/marte/Downloads/hello_world --pristine --board nrf52840dk_nrf52840 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/home/marte/nordic
    -- Application: /home/marte/Downloads/hello_world
    -- CMake version: 3.30.2
    -- Found Python3: /usr/bin/python3 (found suitable version "3.10.12", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /home/marte/.cache/zephyr
    -- Zephyr version: 3.5.99 (/home/marte/ncs/zephyr)
    -- Board: nrf52840dk_nrf52840
    -- Found host-tools: zephyr 0.16.5 (/home/marte/zephyr-sdk-0.16.5)
    -- Found toolchain: zephyr 0.16.5 (/home/marte/zephyr-sdk-0.16.5)
    -- Found Dtc: /home/marte/zephyr-sdk-0.16.5/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/marte/ncs/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
    -- Found devicetree overlay: /home/marte/Downloads/hello_world/app.overlay
    -- Generated zephyr.dts: /home/marte/Downloads/hello_world/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/marte/Downloads/hello_world/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /home/marte/Downloads/hello_world/build/zephyr/dts.cmake
    warning: NRFX_SPIM1 (defined at modules/hal_nordic/nrfx/Kconfig:286,
    modules/hal_nordic/nrfx/Kconfig:286) was assigned the value 'y' but got the value 'n'. Check these
    unsatisfied dependencies: n (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NRFX_SPIM1 and/or look up NRFX_SPIM1 in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    Parsing /home/marte/ncs/zephyr/Kconfig
    Loaded configuration '/home/marte/ncs/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
    Merged configuration '/home/marte/Downloads/hello_world/prj.conf'
    Configuration saved to '/home/marte/Downloads/hello_world/build/zephyr/.config'
    Kconfig header saved to '/home/marte/Downloads/hello_world/build/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: /home/marte/zephyr-sdk-0.16.5/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /home/marte/zephyr-sdk-0.16.5/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Using ccache: /usr/bin/ccache
    -- Configuring done (3.9s)
    -- Generating done (0.1s)
    -- Build files have been written to: /home/marte/Downloads/hello_world/build
    [1/157] Preparing syscall dependency handling
    [3/157] Generating include/generated/version.h
    -- Zephyr version: 3.5.99 (/home/marte/ncs/zephyr), build: v3.5.99-ncs1
    [31/157] Building C object CMakeFiles/app.dir/src/main.c.obj
    FAILED: CMakeFiles/app.dir/src/main.c.obj
    ccache /home/marte/zephyr-sdk-0.16.5/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DNRF52840_XXAA -DPICOLIBC_LONG_LONG_PRINTF_SCANF -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/home/marte/ncs/zephyr/include -I/home/marte/Downloads/hello_world/build/zephyr/include/generated -I/home/marte/ncs/zephyr/soc/arm/nordic_nrf/nrf52 -I/home/marte/ncs/zephyr/soc/common/nordic_nrf/. -I/home/marte/ncs/zephyr/soc/arm/nordic_nrf/common/. -I/home/marte/ncs/nrf/include -I/home/marte/ncs/nrf/tests/include -I/home/marte/ncs/modules/hal/cmsis/CMSIS/Core/Include -I/home/marte/ncs/zephyr/modules/cmsis/. -I/home/marte/ncs/modules/hal/nordic/nrfx -I/home/marte/ncs/modules/hal/nordic/nrfx/drivers/include -I/home/marte/ncs/modules/hal/nordic/nrfx/mdk -I/home/marte/ncs/zephyr/modules/hal_nordic/nrfx/. -I/home/marte/ncs/modules/debug/segger/SEGGER -I/home/marte/ncs/modules/debug/segger/Config -isystem /home/marte/ncs/zephyr/lib/libc/common/include -isystem /home/marte/ncs/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros /home/marte/Downloads/hello_world/build/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/marte/zephyr-sdk-0.16.5/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/marte/ncs/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/marte/Downloads/hello_world=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/marte/ncs/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/marte/ncs=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles/app.dir/src/main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c /home/marte/Downloads/hello_world/src/main.c
    /home/marte/Downloads/hello_world/src/main.c:27:15: warning: initialization of 'const struct device *' from incompatible pointer type 'struct spi_cs_control *' [-Wincompatible-pointer-types]
       27 |         .cs = &spim_cs,
    /home/marte/Downloads/hello_world/src/main.c:27:15: note: (near initialization for 'spi_cfg.cs.gpio.port')
    /home/marte/Downloads/hello_world/src/main.c:22:42: warning: missing braces around initializer [-Wmissing-braces]
       22 | static const struct spi_config spi_cfg = {
       28 | };
    /home/marte/Downloads/hello_world/src/main.c: In function 'spi_test':
    /home/marte/Downloads/hello_world/src/main.c:70:22: warning: assignment to 'uint8_t' {aka 'unsigned char'} from 'uint8_t *' {aka 'unsigned char *'} makes integer from pointer without a cast [-Wint-conversion]
       70 |         tx_buffer[0] = TX0BUFF;
    /home/marte/Downloads/hello_world/src/main.c:71:22: warning: assignment to 'uint8_t' {aka 'unsigned char'} from 'uint8_t *' {aka 'unsigned char *'} makes integer from pointer without a cast [-Wint-conversion]
       71 |         tx_buffer[1] = TX1BUFF;
    /home/marte/Downloads/hello_world/src/main.c:80:22: error: expected expression before '==' token
       80 |         if(DEVICE_ID == rx_buffer[2])
    /home/marte/Downloads/hello_world/src/main.c: At top level:
    /home/marte/Downloads/hello_world/src/main.c:42:12: warning: 'spi_test' defined but not used [-Wunused-function]
       42 | static int spi_test(void)
    /home/marte/Downloads/hello_world/src/main.c:30:13: warning: 'spi_init' defined but not used [-Wunused-function]
       30 | static void spi_init(void)
    [44/157] Building C object zephyr/CMakeFiles/zephyr.dir/home/marte/ncs/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
    FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/marte/Downloads/hello_world/build
     *  The terminal process terminated with exit code: 1.
    The trick to build logs is to start from the top and find the first error, which in this case is the following:
    This error stems from DEVICE_ID not being defined to anything, so the line of code above is basically the same as if( == rx_buffer[2]).
    Your project also gives some build warnings. The build will still finish with these, but they might affect behavior, so you should still look through them.
    Our nRF Connect SDK Intermediate course on DevAcademy has a lesson on SPI, which I recommend going through that. You can find the lesson here: nRF Connect SDK Intermediate Lesson 5 – Serial Peripheral Interface (SPI).
    Marte
  • Hi Marte,
    That's a good pointer to look at the terminal. Thanks!
    There were one or two other small problems which I sorted and it then compiled.
    Yes, I had had a look at the Lesson 5 previously, thanks, - it's not at all wrong to say Zephyr has a bit of a learning curve.
    Thank you for you help!
    Kind regards
    Peks1
