Is there any documentation regarding the AGC_CONFIG reg in the NRF24l01?
thx!
thx!
Hi Proto,
Could you give me more information on where you found that AGC_CONFIG ?
Hi Hung,
"There's also an undocumented multi-byte register at address 1e...." [last paragraph] nerdralph.blogspot.ca/.../nrf24l01-reloaded.html
"#define AGC_CONFIG 0x1E / ** <nRF24L01 + AGC configuration register */ It is in a file sdk from the vendor, in early versions." www.progtown.com/topic1648341-nrf24l01-counterparts-of-packets.html
Not sure if the info is accurate, thanks!
Hi Proto,
AGC_CONFIG is not an official, documented register. You don't have to worry about it and should not write to it. AGC is configured by default.
