Secure connection to AWS IoT over WiFi
We are using nRF5340 and nRF7002 to build a WiFi connected device that integrates into our backend via AWS IoT Core. We are evaluating what the best way is to secure the private key for the TLS client authentication and whether we need an external Hardware Security Module for that or can support everything with the nRF5340 itself.
In general I see two possibilities to do the handshake:
1. Store the private key in a secure storage and have the TLS handshake executed in a secure environment
2. Generate a symmetric key in a secure environment and store it in a secure storage. Encrypt the private key with the symmetric key in the secure environment and store the encrypted private key on flash. Get the private key decrypted before connection and keep it only in memory, but never on flash in plain text.
The first one would obviously be desirable, because the key would never leave the secure environment after provisioning.
According to the docs, the nRF5340 is equipped with a KMU that could be used for securely storing keys and Cryptocell that could be used to perform the secure operations of signing, decrypting and encrypting and with TFM it should be possible to set up a secure environment.
So my questions are mainly:
* How secure is the usage of the functionality provided in the nRF5340 compared to an external dedicated Hardware Security Module?
* Is there a way (or even a sample) for the nRF5340+nRF7002 to transparently set up a client-authenticated TLS tunnel using a private key stored in the KMU?
* How does the Nordic Security Module relate to TFM?
Thanks already for the support!
    That depends on the module you are comparing with. The nRF5340 has a number of security features, like the KMU that can protect keys from being accessible from the CPU or debugger, and it has features that prevents code/data readout via a debugger etc. There are however security features you may find in other products that are not on the nRF5340, but what you need here is very application specific so it is up to you to specify your requirements / features you need, and then we can help to describe which of these exists and how they work in the nRF5340.
    We do not have any solution for that at this point. (WiFi support is currently in an early stage and more features and examples will be added in the future).
    The Nordic security module is a SW component that handles integration with various crypto libraries and APIs. An important point here is that regardless of the backends, the future proof API to use with regards to crypto is PSA Crytpo, which is what is used in the crypto examples in the SDK. TF-M implements a secure processing environment. Typically, secrets will be handled by TF-M, and other parts of the application will then be non-secure and not have access to certain data (liek keys) and hardware. See An Introduction to Trusted Firmware-M (TF-M). You can also see more in the Security chapter in the SDK documentation.
  • Hi Einar,
    thanks for the response! I think I start to get an understanding of the separation and capabilities. For us it would then make sense to use the TF-M to protect the bootchain, securely de- and encrypt the private key for the client authentication certificate and protect the WiFi credentials.
    To get the TF-M image included and get familiar with the functionality, I want to combine the samples under wifi/provisioning and crypto/aes_cbc. For that I added following configs to the prj.conf in wifi/provisioning:
    CONFIG_BUILD_WITH_TFM=y
    CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
    CONFIG_NRF_SECURITY=y
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_HEAP_SIZE=8192
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
    and changed following configs (due to RAM limitations):
    CONFIG_NET_BUF_RX_COUNT=8
    CONFIG_NET_BUF_TX_COUNT=8
    CONFIG_HEAP_MEM_POOL_SIZE=76800
    Unfortunately, the build doesn't work because of undefined references to those two functions:
    mbedtls_entropy_init()
    mbedtls_hardware_poll()
    It seems to me that wpa_supplicant needs the entropy source which is provided by mbedtls, but including the nrf security backend does not provide an implementation when enabled I played around a lot with the various entropy configs, but can't figure out how to include the correct combination. Can you help there?
    board target is nrf7002dk_nrf5340_cpuapp_ns, NCS version is v2.3.0
    On the main branch it also doesn't work. There the Kconfig resolution already fails.
    It turns out that TF-M and Wi-Fi is unfortunately not supported at the moment. I have discussed with the team and we have a ticket for it, so this will come, but I do not have a time-frame for it.
  • Ouh, that's a pity! Just to be clear: It is also not possible to let WiFi use the "non-secure" crypto and have the TF-M for other crypto operations? It is simply not possible to use TF-M and WiFi in the same build currently?
  • I cannot say it is not possible, it is just that we have not worked on it yet and I am not able to say what is needed in order to support it.
