Possibility to disabling native AFH function and using our own frequency hopping algorithm
Hi everyone,
I am developing a frequency hopping algorithm, including RSSI based channel evaluation and frequency hopping sequence generation. In my project, a nrf52840 device is used as master and 2 nrf52832 devices used as slaves.
The questions are as follows,
1. Is it possible to modify the channel map and update it in 1 second or less? If there's any constraint when updating channel map?
2. Is it possible to modify channel hopping sequence using nrf52 series with nordiac protocol stack?
I already know I can use  sd_ble_opt_get to get the current channel map and sd_ble_opt_set to set a new channel map,but I'm not sure if there's any  API or other methods I can use to make the devices communicate in the channel  sequence my algorithm generated.
panzerp
