app_timer2 - spurious reorder of timeouts
Dear Nordic support,
I've identified a case in app_timer2.c code in nRF5 SDK v17.1.0 where the timers are not executed in expected order:
APP_TIMER_DEF(m_timer_1);
APP_TIMER_DEF(m_timer_2);
APP_TIMER_DEF(m_timer_3);
APP_TIMER_DEF(m_timer_4);
static void timer_handler(void * p_context)
    NRF_LOG_INFO("Timer %d expired", (int)p_context);
    /* APPTIMER ISSUE SHOWCASE START */
    #define TRIGGER_ISSUE 1
    err_code = app_timer_start(m_timer_1, APP_TIMER_TICKS(1000), (void*)1);
    err_code = app_timer_start(m_timer_2, APP_TIMER_TICKS(2000), (void*)2);
    err_code = app_timer_start(m_timer_3, APP_TIMER_TICKS(3000), (void*)3);
#if TRIGGER_ISSUE
    CRITICAL_REGION_ENTER();
    err_code = app_timer_start(m_timer_4, APP_TIMER_TICKS(4000), (void*)4);
    err_code = app_timer_stop(m_timer_2);
#if TRIGGER_ISSUE
    CRITICAL_REGION_EXIT();
    /* APPTIMER ISSUE SHOWCASE END */
When `TRIGGER_ISSUE` is `0` then following log can be observed:
00> <info> app_timer: RTC: initialized.
00> <info> app: BSP example started.
00> <debug> app_timer: Start request (expiring at 16384/0x00004000).
00> <debug> app_timer: Activating timer (CC:16384/00004000).
00> <debug> app_timer: Setting CC to 0x00004000 (err: 0)
00> <debug> app_timer: Start request (expiring at 32768/0x00008000).
00> <debug> app_timer: Start request (expiring at 49152/0x0000C000).
00> <debug> app_timer: Start request (expiring at 65536/0x00010000).
00> <debug> app_timer: Stop request.
00> <debug> app_timer: Compare EVT
00> <debug> app_timer: Timer expired (context: 1)
00> <info> app: Timer 1 expired
00> <debug> app_timer: Activating timer (CC:49152/0000C000).
00> <debug> app_timer: Setting CC to 0x0000C000 (err: 0)
00> <debug> app_timer: Timer expired (context: 3)
00> <info> app: Timer 3 expired
00> <debug> app_timer: Activating timer (CC:65536/00010000).
00> <debug> app_timer: Setting CC to 0x00010000 (err: 0)
00> <debug> app_timer: Timer expired (context: 4)
00> <info> app: Timer 4 expired
Timers 1, 3, 4 are correctly expiring in the expected order.
However, if `TRIGGER_ISSUE` is `1` then:
00> <debug> app_timer: Timer expired before scheduled to RTC.
Not only are the timers expired in wrong order: 1, 4, 3, but also timer 3 expiration was postponed until timer 4 expiration, which means that app_timer2 reordered the timers' timeouts.
After adding some more detailed logging to app_timer2.c the root cause can be identified:
00> <info> app_timer: Proc trigger 0 for p_timer=0x20000090, handler=0x00003DD1, end_val=0x4000
00> <info> app_timer: Processing p_timer=0x20000090
00> <debug> app_timer: Start request (expiring at 16384/0x00004000). p_timer=0x20000090
00> <debug> app_timer: 0) p_t=0x20000090 cc=0x4000
00> <debug> app_timer: END OF DUMP
00> <info> app_timer: END OF PROCESSING
00> <debug> app_timer: Activating timer (CC:0x4000), p_timer=0x20000090.
00> <info> app_timer: RTC1 IRQ pending: 0
00> <info> app_timer: Proc trigger 0 for p_timer=0x200000B0, handler=0x00003DD1, end_val=0x8000
00> <info> app_timer: Processing p_timer=0x200000B0
00> <debug> app_timer: Start request (expiring at 32768/0x00008000). p_timer=0x200000B0
00> <debug> app_timer: 0) p_t=0x200000B0 cc=0x8000
00> <info> app_timer: Proc trigger 0 for p_timer=0x200000D0, handler=0x00003DD1, end_val=0xC000
00> <info> app_timer: Processing p_timer=0x200000D0
00> <debug> app_timer: Start request (expiring at 49152/0x0000C000). p_timer=0x200000D0
00> <debug> app_timer: 1) p_t=0x200000D0 cc=0xC000
00> <info> app_timer: Proc trigger 0 for p_timer=0x200000F0, handler=0x00003DD1, end_val=0x10001
00> <info> app_timer: RTC1 IRQ pending: 1
00> <info> app_timer: app_timer_stop: p_timer=0x200000B0
00> <info> app_timer: Proc trigger 1 for p_timer=0x200000B0, handler=0x00003DD1, end_val=0xFFFFFFFF
00> <info> app_timer: Processing p_timer=0x200000F0
00> <debug> app_timer: Start request (expiring at 65537/0x00010001). p_timer=0x200000F0
00> <debug> app_timer: 0) p_t=0x200000F0 cc=0x10001
00> <debug> app_timer: 1) p_t=0x200000B0 cc=0xFFFFFFFF ////<<< ISSUE HAPPENS HERE
00> <debug> app_timer: 2) p_t=0x200000D0 cc=0xC000
00> <debug> app_timer: WRONG ORDER
00> <debug> app_timer: Removed p_timer=0x200000B0 from list
00> <debug> app_timer: Stop request, p_timer=0x200000B0
00> <debug> app_timer: Compare EVT p_timer=0x20000090 at CC=0x4000
00> <debug> app_timer: Timer expired (context: 1), p_timer=0x20000090
00> <debug> app_timer: Activating timer (CC:0x10001), p_timer=0x200000F0.
00> <debug> app_timer: 0) p_t=0x200000D0 cc=0xC000
00> <debug> app_timer: Setting CC to 0x00010001 (err: 0)
00> <debug> app_timer: Compare EVT p_timer=0x200000F0 at CC=0x10001
00> <debug> app_timer: Timer expired (context: 4), p_timer=0x200000F0
00> <debug> app_timer: Activating timer (CC:0xC000), p_timer=0x200000D0.
00> <debug> app_timer: Timer expired (context: 3), p_timer=0x200000D0
We request to start yet another timer (timer4) in critical section. However, because we are in critical section we cannot add this timer right away as timers' list processing is postponed to RTC ISR context. Timer start request is added to the queue and that's it.
Then we request to stop already started timer (timer2) and it's internal `end_val` is set to 0xFFFFFFFF. However, because we execute in critical section, app_timer RTC ISR does not execute right away so this timer is not removed from the timers queue yet. This timer stop request is added to the queue and that's it.
Now the critical section ends and we enter RTC ISR:
- Start request is first in request queue so the algorithm goes through timers' linked list and encounters 0xFFFFFFFF end_val - so it inserts this timer before this.
- Stop request is second in request queue so now the timer marked with 0xFFFFFFFF is removed from the linked list.
The problem is that there could be some more timers started before critical section (timer3 in our example) but after timer2 start and inserted after the stopped timer in the linked list, meaning that they will expire only after timer4 expires. This completely breaks the timeline of scheduled timers, as timer3 will have chance to expire only after timer4 is stopped or expires.
The critical section in the example can symbolize any context in which app_timers are stopped and started but cannot be processed right away as RTC ISR cannot preempt. It can be BLE observer handler context, for example (actually `components/ble/common/ble_conn_params.c` code can help trigger the issue as there are timers started and stopped in BLE observer handler).
I find this issue as critical. Ideally a fixed app_timer2.c code could be provided.
Interestingly, v17.0.2 app_timer2.c version does not have this bug, but I believe it has different limitations, so I presume using previous version is not an ideal workaround.
I am attaching a modified `examples/peripheral/bsp` nRF5 SDK v17.1.0 project that recreates the issue and git patch with added app_timer2.c logs for the convenience.app_timer2_issue_demo.zipapp_timer2_logs_diff.patch
 * Copyright (c) 2018 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
#include "app_timer.h"
#include "nrf_atfifo.h"
#include "nrf_sortlist.h"
#include "nrf_delay.h"
#if APP_TIMER_WITH_PROFILER
#if APP_TIMER_CONFIG_USE_SCHEDULER
#include "app_scheduler.h"
#include <stddef.h>
#define NRF_LOG_MODULE_NAME APP_TIMER_LOG_NAME
#if APP_TIMER_CONFIG_LOG_ENABLED
#define NRF_LOG_LEVEL       APP_TIMER_CONFIG_LOG_LEVEL
#define NRF_LOG_INFO_COLOR  APP_TIMER_CONFIG_INFO_COLOR
#define NRF_LOG_DEBUG_COLOR APP_TIMER_CONFIG_DEBUG_COLOR
#else //APP_TIMER_CONFIG_LOG_ENABLED
#define NRF_LOG_LEVEL       0
#endif //APP_TIMER_CONFIG_LOG_ENABLED
#include "nrf_log.h"
NRF_LOG_MODULE_REGISTER();
#include "drv_rtc.h"
 * Maximum possible relative value is limited by safe window to detect cases when requested
 * compare event has already occured.
#define APP_TIMER_SAFE_WINDOW APP_TIMER_TICKS(APP_TIMER_SAFE_WINDOW_MS)
#define APP_TIMER_RTC_MAX_VALUE   (DRV_RTC_MAX_CNT - APP_TIMER_SAFE_WINDOW)
/* Check if timer is idle */
#define APP_TIMER_IS_IDLE(timer) (timer->end_val == APP_TIMER_IDLE_VAL)
static drv_rtc_t m_rtc_inst = DRV_RTC_INSTANCE(1);
static uint8_t m_max_user_op_queue_utilization;     /**< Maximum observed timer user operations queue utilization. */
static uint8_t m_current_user_op_queue_utilization; /**< Currently observed timer user operations queue utilization. */
#endif /* APP_TIMER_WITH_PROFILER */
 * @brief Timer requests types.
typedef enum
    TIMER_REQ_START,
    TIMER_REQ_STOP,
    TIMER_REQ_STOP_ALL
} app_timer_req_type_t;
 * @brief Operation request structure.
typedef struct
    app_timer_req_type_t type;    /**< Request type. */
    app_timer_t *        p_timer; /**< Timer instance. */
} timer_req_t;
static app_timer_t * volatile mp_active_timer; /**< Timer currently handled by RTC driver. */
static bool                   m_global_active; /**< Flag used to globally disable all timers. */
static uint64_t m_base_counter;
static uint64_t m_stamp64;
/* Request FIFO instance. */
NRF_ATFIFO_DEF(m_req_fifo, timer_req_t, APP_TIMER_CONFIG_OP_QUEUE_SIZE);
/* Sortlist instance. */
static bool compare_func(nrf_sortlist_item_t * p_item0, nrf_sortlist_item_t *p_item1);
NRF_SORTLIST_DEF(m_app_timer_sortlist, compare_func); /**< Sortlist used for storing queued timers. */
 * @brief Return current 64 bit timestamp
static uint64_t get_now(void)
    uint64_t now = m_base_counter + drv_rtc_counter_get(&m_rtc_inst);
    /* it is possible that base was not updated and overflow occured, in that case 'now' will be
     * 24bit value behind. Additional timestamp updated on every 24 bit period is used to detect
     * that case. Apart from that 'now' should never be behind previously read timestamp.
    if (now < m_stamp64) {
        now += (DRV_RTC_MAX_CNT + 1);
    return now;
 * @brief Function used for comparing items in sorted list.
static inline bool compare_func(nrf_sortlist_item_t * p_item0, nrf_sortlist_item_t *p_item1)
    app_timer_t * p0 = CONTAINER_OF(p_item0, app_timer_t, list_item);
    app_timer_t * p1 = CONTAINER_OF(p_item1, app_timer_t, list_item);
    uint64_t p0_end = p0->end_val;
    uint64_t p1_end = p1->end_val;
    return (p0_end <= p1_end) ? true : false;
static void scheduled_timeout_handler(void * p_event_data, uint16_t event_size)
    ASSERT(event_size == sizeof(app_timer_event_t));
    app_timer_event_t const * p_timer_event = (app_timer_event_t *)p_event_data;
    p_timer_event->timeout_handler(p_timer_event->p_context);
static inline void sortlist_dump(void)
    uint64_t prev_end_val = 0;
    uint32_t timer_idx = 0;
    app_timer_t const * p_next = (app_timer_t const *)m_app_timer_sortlist.p_cb->p_head;
    while (p_next)
        NRF_LOG_DEBUG("%d) p_t=%p cc=0x%x", timer_idx++, p_next, p_next->end_val);
        if (p_next->end_val < prev_end_val)
            NRF_LOG_DEBUG("WRONG ORDER");
        if (p_next->end_val != APP_TIMER_IDLE_VAL)
            prev_end_val = p_next->end_val;
        p_next = (app_timer_t const *)p_next->list_item.p_next;
    NRF_LOG_DEBUG("END OF DUMP");
 * @brief Function called on timer expiration
 * If end value is not reached it is assumed that it was partial expiration and time is put back
 * into the list. Otherwise function calls user handler if timer was not stopped before. If timer
 * is in repeated mode then timer is rescheduled.
 * @param p_timer Timer instance.
 * @return True if reevaluation of sortlist needed (becasue it was updated).
static bool timer_expire(app_timer_t * p_timer)
    ASSERT(p_timer->handler);
    bool ret = false;
    if ((m_global_active == true) && (p_timer != NULL))
        if (get_now() >= p_timer->end_val) {
            bool cont;
            /* timer expired */
            /* In case of single shot, set timer to idle. */
            if (p_timer->repeat_period == 0)
                p_timer->end_val = APP_TIMER_IDLE_VAL;
            app_timer_event_t timer_event;
            timer_event.timeout_handler = p_timer->handler;
            timer_event.p_context       = p_timer->p_context;
            uint32_t err_code = app_sched_event_put(&timer_event,
                                                    sizeof(timer_event),
                                                    scheduled_timeout_handler);
    #else
            NRF_LOG_DEBUG("Timer expired (context: %d), p_timer=%p", (uint32_t)p_timer->p_context, p_timer)
            p_timer->handler(p_timer->p_context);
            /* check active flag as it may have been stopped in the user handler */
            if (p_timer->repeat_period && !APP_TIMER_IS_IDLE(p_timer))
                p_timer->end_val += p_timer->repeat_period;
                cont = true;
                cont = false;
            if (cont)
                NRF_LOG_DEBUG("Timer rescheduled p_timer=%p to CC: 0x%x", p_timer, p_timer->end_val)
                nrf_sortlist_add(&m_app_timer_sortlist, &p_timer->list_item);
                sortlist_dump();
                ret = true;
        else if (!APP_TIMER_IS_IDLE(p_timer))
            sortlist_dump();
            ret = true;
    return ret;
 * @brief Function is configuring RTC driver to trigger timeout interrupt for given timer.
 * It is possible that RTC driver will indicate that timeout already occured. In that case timer
 * expires and function indicates that RTC was not configured.
 * @param [in,out] p_rerun Flag indicating that sortlist reevaluation is required.
 * @return True if RTC was successfully configured, false if timer already expired and RTC was not
 *         configured.
static bool rtc_schedule(app_timer_t * p_timer, bool * p_rerun)
    ret_code_t ret = NRF_ERROR_TIMEOUT;
    *p_rerun = false;
    /* In case timer got stopped in between, end_val will be very far in the
     * future. RTC will be reconfigured on the next iteration.
    uint64_t end_val = p_timer->end_val;
    int64_t remaining = (int64_t)(end_val - get_now());
    if (remaining > 0) {
        uint32_t cc_val = ((uint32_t)remaining > APP_TIMER_RTC_MAX_VALUE) ?
                (app_timer_cnt_get() + APP_TIMER_RTC_MAX_VALUE) : end_val;
        ret = drv_rtc_windowed_compare_set(&m_rtc_inst, 0, cc_val, APP_TIMER_SAFE_WINDOW);
        NRF_LOG_DEBUG("Setting CC to 0x%08x (err: %d)", cc_val & DRV_RTC_MAX_CNT, ret);
        if (ret == NRF_SUCCESS)
            return true;
        drv_rtc_compare_disable(&m_rtc_inst, 0);
    if (ret == NRF_ERROR_TIMEOUT)
        *p_rerun = timer_expire(p_timer);
        NRF_LOG_ERROR("Unexpected error: %d", ret);
        ASSERT(0);
    return false;
static inline app_timer_t * sortlist_pop(void)
    nrf_sortlist_item_t * p_next_item = nrf_sortlist_pop(&m_app_timer_sortlist);
    return p_next_item ? CONTAINER_OF(p_next_item, app_timer_t, list_item) : NULL;
static inline app_timer_t * sortlist_peek(void)
    nrf_sortlist_item_t const * p_next_item = nrf_sortlist_peek(&m_app_timer_sortlist);
 * @brief Function for deactivating all timers which are in the sorted list (active timers).
static void sorted_list_stop_all(void)
    app_timer_t * p_next;
    do
        p_next = sortlist_pop();
        if (p_next)
            p_next->end_val = APP_TIMER_IDLE_VAL;
    } while (p_next);
 * @brief Function for handling RTC counter overflow.
 * Increment base counter used to calculate 64 bit timestamp.
static void on_overflow_evt(void)
    NRF_LOG_DEBUG("Overflow EVT");
    m_base_counter += (DRV_RTC_MAX_CNT + 1);
 * #brief Function for handling RTC compare event - active timer expiration.
static void on_compare_evt(drv_rtc_t const * const  p_instance)
    if (mp_active_timer)
        /* If assert fails it suggests that safe window should be increased. */
        ASSERT(app_timer_cnt_diff_compute(drv_rtc_counter_get(p_instance),
                                          drv_rtc_compare_get(p_instance, 0)) < APP_TIMER_SAFE_WINDOW);
        NRF_LOG_INST_DEBUG(mp_active_timer->p_log, "Compare EVT p_timer=%p at CC=0x%x", mp_active_timer, NRF_RTC1->COUNTER, mp_active_timer->end_val);
        UNUSED_RETURN_VALUE(timer_expire(mp_active_timer));
        mp_active_timer = NULL;
        NRF_LOG_WARNING("Compare event but no active timer (already stopped?)");
 * @brief Channel 1 is triggered in the middle of 24 bit period to updated control timestamp in
 * place where there is no risk of overflow.
static void on_compare1_evt(drv_rtc_t const * const  p_instance)
    m_stamp64 = get_now();
 * @brief Function updates RTC.
 * Function is called at the end of RTC interrupt when all new user request and/or timer expiration
 * occured. It configures RTC if there is any pending timer, reconfigures if the are timers with
 * shorted timeout than active one or stops RTC if there is no active timers.
static void rtc_update(drv_rtc_t const * const  p_instance)
    while(1)
        app_timer_t * p_next = sortlist_peek();
        bool rtc_reconf = false;
        if (p_next) //Candidate for active timer
            /* If timer was stopped just remove it from the sortlist and continue.
             * Note that it is possible, that stop/start requests are pending in
             * the request queue if added from higher priority context. In
             * that case end_val was first set to invalid value and then to the
             * new timeout in the future. In that case, timer location in sortlist
             * is invalid. However, it will all be sorted out when stop and start
             * requests are handled.
            if (APP_TIMER_IS_IDLE(p_next)) {
                (void)sortlist_pop();
                continue;
            else if (mp_active_timer == NULL)
                //There is no active timer so candidate will become active timer.
                rtc_reconf = true;
            else if (p_next->end_val < mp_active_timer->end_val)
                //Candidate has shorter timeout than current active timer. Candidate will replace active timer.
                //Active timer is put back into sorted list.
                rtc_reconf = true;
                if (!APP_TIMER_IS_IDLE(mp_active_timer))
                    NRF_LOG_INST_DEBUG(mp_active_timer->p_log, "Timer preempted: p_timer=%p, end_val=0x%x", mp_active_timer, mp_active_timer->end_val);
                    NRF_LOG_INST_DEBUG(mp_active_timer->p_log, "Preempted by: p_timer=%p, end_val=0x%x", p_next, p_next->end_val);
                    nrf_sortlist_add(&m_app_timer_sortlist, &mp_active_timer->list_item);
                    sortlist_dump();
            if (rtc_reconf)
                bool rerun;
                NRF_LOG_INST_DEBUG(p_next->p_log, "Activating timer (CC:0x%x), p_timer=%p.", p_next->end_val, p_next);
                sortlist_dump();
                if (rtc_schedule(p_next, &rerun))
                    if (!APP_TIMER_KEEPS_RTC_ACTIVE && (mp_active_timer == NULL))
                        drv_rtc_start(p_instance);
                    mp_active_timer = p_next;
                    if (rerun == false)
                        //RTC was successfully updated and sortlist was not updated. Function can be terminated.
                    //If RTC driver indicated that timeout already occured a new candidate will be taken from sorted list.
                    NRF_LOG_INST_DEBUG(p_next->p_log,"Timer expired before scheduled to RTC.");
                //RTC will not be updated. Function can terminate.
        else //No candidate for active timer.
                drv_rtc_stop(p_instance);
 * @brief Function for processing user requests.
 * Function is called only in the context of RTC interrupt.
static void timer_req_process(drv_rtc_t const * const  p_instance)
    nrf_atfifo_item_get_t fifo_ctx;
    timer_req_t *         p_req = nrf_atfifo_item_get(m_req_fifo, &fifo_ctx);
    while (p_req)
        NRF_LOG_INFO("Processing p_timer=%p", p_req->p_timer);
        switch (p_req->type)
            case TIMER_REQ_START:
                /* Check for idle in most of the cases is not needed but it serves
                 * for following corner case:
                 * - timer was active (request processed)
                 * - timer was stopped and started from higher priority which
                 *   interrupted handling timeout. End_val is currently set to the
                 *   timeout value of the next start request. If that value already
                 *   expired, timeout expires before stop, start requests are handled.
                 * - When start request is handled, timer is idle and should not be
                 *   added to the queue but just dropped.
                if (!APP_TIMER_IS_IDLE(p_req->p_timer))
                    nrf_sortlist_add(&m_app_timer_sortlist, &(p_req->p_timer->list_item));
                    NRF_LOG_INST_DEBUG(p_req->p_timer->p_log,"Start request (expiring at %d/0x%08x). p_timer=%p",
                                                  p_req->p_timer->end_val, p_req->p_timer->end_val, p_req->p_timer);
                    sortlist_dump();
            case TIMER_REQ_STOP:
                if (p_req->p_timer == mp_active_timer)
                    NRF_LOG_DEBUG("Removed p_timer=%p from list", p_req->p_timer);
                    bool found = nrf_sortlist_remove(&m_app_timer_sortlist, &(p_req->p_timer->list_item));
                    if (!found)
                         NRF_LOG_INFO("Timer not found on sortlist (stopping expired timer).");
                NRF_LOG_INST_DEBUG(p_req->p_timer->p_log,"Stop request, p_timer=%p", p_req->p_timer);
                sortlist_dump();
            case TIMER_REQ_STOP_ALL:
                sorted_list_stop_all();
                m_global_active = true;
                NRF_LOG_INFO("Stop all request.");
        UNUSED_RETURN_VALUE(nrf_atfifo_item_free(m_req_fifo, &fifo_ctx));
        if (m_max_user_op_queue_utilization < m_current_user_op_queue_utilization)
            m_max_user_op_queue_utilization = m_current_user_op_queue_utilization;
        --m_current_user_op_queue_utilization;
    NRF_LOG_INFO("END OF PROCESSING");
static void rtc_irq(drv_rtc_t const * const  p_instance)
    if (drv_rtc_overflow_pending(p_instance))
        on_overflow_evt();
    if (drv_rtc_compare_pending(p_instance, 0))
        on_compare_evt(p_instance);
    if (drv_rtc_compare_pending(p_instance, 1))
        on_compare1_evt(p_instance);
    timer_req_process(p_instance);
    rtc_update(p_instance);
 * @brief Function for triggering processing user requests.
 * @note All user requests are processed in a single context - RTC interrupt.
static inline void timer_request_proc_trigger(void)
    drv_rtc_irq_trigger(&m_rtc_inst);
 * @brief Function for putting user request into the request queue
static ret_code_t timer_req_schedule(app_timer_req_type_t type, app_timer_t * p_timer)
    nrf_atfifo_item_put_t fifo_ctx;
    timer_req_t * p_req;
    p_req = nrf_atfifo_item_alloc(m_req_fifo, &fifo_ctx);
    if (p_req)
        ++m_current_user_op_queue_utilization;
    if (p_req)
        p_req->type    = type;
        p_req->p_timer = p_timer;
        if (nrf_atfifo_item_put(m_req_fifo, &fifo_ctx))
            NRF_LOG_INFO("Proc trigger %d for p_timer=%p, handler=%p, end_val=0x%x", type, p_timer, p_timer->handler, p_timer->end_val);
            timer_request_proc_trigger();
            NRF_LOG_INFO("RTC1 IRQ pending: %d", NVIC_GetPendingIRQ(RTC1_IRQn));
            NRF_LOG_WARNING("Scheduling interrupted another scheduling.");
        return NRF_SUCCESS;
        return NRF_ERROR_NO_MEM;
ret_code_t app_timer_init(void)
    ret_code_t err_code;
    drv_rtc_config_t config = {
        .prescaler          = APP_TIMER_CONFIG_RTC_FREQUENCY,
        .interrupt_priority = APP_TIMER_CONFIG_IRQ_PRIORITY
    err_code = NRF_ATFIFO_INIT(m_req_fifo);
    if (err_code != NRFX_SUCCESS)
        return err_code;
    err_code = drv_rtc_init(&m_rtc_inst, &config, rtc_irq);
        return err_code;
    drv_rtc_overflow_enable(&m_rtc_inst, true);
    drv_rtc_compare_set(&m_rtc_inst, 1, DRV_RTC_MAX_CNT >> 1, true);
    if (APP_TIMER_KEEPS_RTC_ACTIVE)
        drv_rtc_start(&m_rtc_inst);
    return err_code;
ret_code_t app_timer_create(app_timer_id_t const *      p_timer_id,
                            app_timer_mode_t            mode,
                            app_timer_timeout_handler_t timeout_handler)
    ASSERT(p_timer_id);
    ASSERT(timeout_handler);
    if (timeout_handler == NULL)
        return NRF_ERROR_INVALID_PARAM;
    app_timer_t * p_t = (app_timer_t *) *p_timer_id;
    p_t->end_val = APP_TIMER_IDLE_VAL;
    p_t->handler = timeout_handler;
    p_t->repeat_period = (mode == APP_TIMER_MODE_REPEATED) ? 1 : 0;
    return NRF_SUCCESS;
ret_code_t app_timer_start(app_timer_t * p_timer, uint32_t timeout_ticks, void * p_context)
    ASSERT(p_timer);
    app_timer_t * p_t = (app_timer_t *) p_timer;
    bool cont;
    if (APP_TIMER_IS_IDLE(p_t))
        /* TImer is idle and can be started. Note that timer can still be
         * in use by the engine since stop request may be still pending if
         * it was scheduled from higher priority interrupt (same as this start).
         * In that case, end value is shifted to the future which will prevent
         * previous timeout value to expire.*/
        p_t->end_val = get_now() + timeout_ticks;
        cont = true;
        cont = false;
    /* Timer in use */
    if (!cont)
        return NRF_SUCCESS;
    p_t->p_context = p_context;
    if (p_t->repeat_period)
        p_t->repeat_period = timeout_ticks;
    return timer_req_schedule(TIMER_REQ_START, p_t);
ret_code_t app_timer_stop(app_timer_t * p_timer)
    NRF_LOG_INFO("app_timer_stop: p_timer=%p", p_timer);
    ASSERT(p_timer);
    bool cont;
        /* TImer is idle and can not be stopped. */
        cont = false;
        /* Set end value to invalid (unrealistic future) value. */
        cont = true;
    if (!cont)
        return NRF_SUCCESS;
    return timer_req_schedule(TIMER_REQ_STOP, p_t);
ret_code_t app_timer_stop_all(void)
    //block timer globally
    m_global_active = false;
    return timer_req_schedule(TIMER_REQ_STOP_ALL, NULL);
uint8_t app_timer_op_queue_utilization_get(void)
    return m_max_user_op_queue_utilization;
uint32_t app_timer_cnt_diff_compute(uint32_t   ticks_to,
                                    uint32_t   ticks_from)
    return ((ticks_to - ticks_from) & RTC_COUNTER_COUNTER_Msk);
uint32_t app_timer_cnt_get(void)
    return drv_rtc_counter_get(&m_rtc_inst);
void app_timer_pause(void)
    drv_rtc_stop(&m_rtc_inst);
void app_timer_resume(void)
nRF5 SDK user
