Dear Nordic Teams :
I find the layout guideline shows the C3 return path for filtering the harmonic.
The GND pin is connected to the IC's system ground directly. Do I need to separate the pin from IC's GND to prevent the noise coupling?
Dear Nordic Teams :
C3 should be grounded only to the center pad via the VSS_PA pin, like this the reference layout(s) show:
https://www.nordicsemi.com/Products/nRF52840/Compatible-downloads?lang=en#infotabs
https://www.nordicsemi.com/Products/nRF52832/Download?lang=en#infotabs
Kenneth
The pin assignment of nRF52840 aQFN73 B7 is VSS/Power, GND and F23 is VSS_PA/power, Ground (radio supply).
I think the B7 & F23 are RF GND and they might be independent of system GND. The reference layout connects the system GND and RF GND together.
I don't see a question here, but just follow the reference layout and pcb guidelines, and for instance placement of vias and clearance of ground like the reference layout and you will be good. You can in any case ask someone here to perform a layout review for you.
Kenneth
I find there are large 3rd harmonic power on DEC4 both on my PCB and DK. You mention the B7 pin is for filtering harmonic gnd, but it is still connected with system gnd. Whether noise would be coupled to other nets or traces through the GND?
If you have problems with the design, please make a new case for someone to review your design.
Kenneth
