NCS BLE Disconnect issue.
Hi All.
NCS 2.3.0,  peripheral LBS example.
   I want try to disconnect session between peripheral and central .
Then I call the bt_conn_disconnect(default_conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);  to disconnect .It's worked .
But i added the the bt_conn_disconnect fuction into k_work,   when i call disconnect fuction disconnected callback  will be happen after 5S .
But it's  weird , i added the the bt_conn_disconnect fuction into button callback , the disconnected callback  will happen immediate.
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/kernel.h>
#include <soc.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <bluetooth/services/lbs.h>
#include <zephyr/settings/settings.h>
#include <dk_buttons_and_leds.h>
#define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED          DK_LED1
#define CON_STATUS_LED          DK_LED2
#define RUN_LED_BLINK_INTERVAL  1000
#define USER_LED                DK_LED3
#define USER_BUTTON             DK_BTN1_MSK
static bool app_button_state;
struct bt_conn *default_conn;
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_LBS_VAL),
static struct k_work advertise_work;
static struct k_work_delayable nus_msg_timer;
 * @brief 连接之后没有
void nus_msg_connect_timeout(struct k_work *work)
	int err;
	printk("time %d\r\n",k_uptime_get_32());
	if(default_conn != NULL)
		err = bt_conn_disconnect(default_conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
		if (err) {
			printk("Disconnection failed (err %d)\r\n", err);
			return ;
		printk("call Disconnect!\r\n");
void nus_msg_connect(void)
    k_work_cancel_delayable(&nus_msg_timer);
    k_work_schedule(&nus_msg_timer, K_MSEC(5000));
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)\n", err);
		return;
	if (!default_conn) {
		default_conn = bt_conn_ref(conn);
	printk("Connected\n");
	dk_set_led_on(CON_STATUS_LED);
	nus_msg_connect();
	printk("Disconnected (reason %u)\n", reason);
	if (default_conn == conn) {
		bt_conn_unref(default_conn);
		default_conn = NULL;
	dk_set_led_off(CON_STATUS_LED);
	k_work_submit(&advertise_work);
#ifdef CONFIG_BT_LBS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		printk("Security changed: %s level %u\n", addr, level);
	} else {
		printk("Security failed: %s level %u err %d\n", addr, level,
			err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected        = connected,
	.disconnected     = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_LBS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void app_led_cb(bool led_state)
	dk_set_led(USER_LED, led_state);
static bool app_button_cb(void)
	return app_button_state;
static struct bt_lbs_cb lbs_callbacs = {
	.led_cb    = app_led_cb,
	.button_cb = app_button_cb,
static void button_changed(uint32_t button_state, uint32_t has_changed)
	int err;
	if (has_changed & USER_BUTTON) {
		uint32_t user_button_state = button_state & USER_BUTTON;
		bt_lbs_send_button_state(user_button_state);
		app_button_state = user_button_state ? true : false;
	else if(has_changed & DK_BTN2_MSK)
			if (err) {
				return ;
			printk("Disconnect!\r\n");
static int init_button(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		printk("Cannot init buttons (err: %d)\n", err);
	return err;
static void advertise(struct k_work *work)
    int ret;
    bt_le_adv_stop();
    /* Check UICR to see what channel is selected for this HW */
    ret = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), NULL, 0);
    if (ret) {
        printk("Advertising failed to start (ret %d)\r\n", ret);
		return ;
    printk("Advertising successfully started\r\n");
void main(void)
	int blink_status = 0;
	int err;
	printk("Starting Bluetooth Peripheral LBS example\n");
	k_work_init(&advertise_work, advertise);
    k_work_init_delayable(&nus_msg_timer , nus_msg_connect_timeout);
	err = dk_leds_init();
	if (err) {
		printk("LEDs init failed (err %d)\n", err);
		return;
	err = init_button();
	if (err) {
		printk("Button init failed (err %d)\n", err);
		return;
	if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
		err = bt_conn_auth_cb_register(&conn_auth_callbacks);
		if (err) {
			printk("Failed to register authorization callbacks.\n");
			return;
		err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
		if (err) {
			printk("Failed to register authorization info callbacks.\n");
			return;
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_lbs_init(&lbs_callbacs);
	if (err) {
		printk("Failed to init LBS (err:%d)\n", err);
		return;
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
			      sd, ARRAY_SIZE(sd));
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
	printk("Advertising successfully started\n");
	for (;;) {
		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
may you give me some advice?
Thank you very much.
Wang
