I'm trying to build my projects using a Github actions workflow using github.com/.../nrf-docker. I can build the project fine locally but it seems like the docker container has some incompatibility with the DFU configuration.
I've recreated the issue in a minimal way using the the zephyr peripheral ibs example. you can see the repository here: https://github.com/Robert-PillConnect/peripheral/
I've made the following changes compared to the original sample:
1) prj.confg has additional lines for enabling dfu
# Enable mcumgr. CONFIG_MCUMGR=y # Some command handlers require a large stack. CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 # Ensure an MCUboot-compatible binary is generated. CONFIG_BOOTLOADER_MCUBOOT=y # Enable flash operations. CONFIG_FLASH=y # Required by the `taskstat` command. CONFIG_THREAD_MONITOR=y # Enable statistics and statistic names. CONFIG_STATS=y CONFIG_STATS_NAMES=y # Enable most core commands. CONFIG_MCUMGR_CMD_IMG_MGMT=y CONFIG_MCUMGR_CMD_OS_MGMT=y CONFIG_MCUMGR_CMD_STAT_MGMT=y # Allow for large Bluetooth data packets. CONFIG_BT_L2CAP_TX_MTU=252 CONFIG_BT_BUF_ACL_RX_SIZE=256 # Enable the Bluetooth (unauthenticated) and shell mcumgr transports. CONFIG_MCUMGR_SMP_BT=y CONFIG_MCUMGR_SMP_BT_AUTHEN=n CONFIG_MCUMGR_SMP_SHELL=y # Add 256 bytes to accommodate upload command (lfs_stat overflows) CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
2) main has been updated to include a call to smp_bt_register()
void main(void) { struct bt_gatt_attr *vnd_ind_attr; char str[BT_UUID_STR_LEN]; int err; err = bt_enable(NULL); if (err) { printk("Bluetooth init failed (err %d)\n", err); return; } bt_ready(); bt_gatt_cb_register(&gatt_callbacks); bt_conn_auth_cb_register(&auth_cb_display); err = smp_bt_register(); if (err) { printk("SMP BT register failed (err: %d)", err); } vnd_ind_attr = bt_gatt_find_by_uuid(vnd_svc.attrs, vnd_svc.attr_count, &vnd_enc_uuid.uuid); bt_uuid_to_str(&vnd_enc_uuid.uuid, str, sizeof(str)); printk("Indicate VND attr %p (UUID %s)\n", vnd_ind_attr, str); /* Implement notification. At the moment there is no suitable way * of starting delayed work so we do it here */ while (1) { k_sleep(K_SECONDS(1)); /* Current Time Service updates only when time is changed */ cts_notify(); /* Heartrate measurements simulation */ hrs_notify(); /* Battery level simulation */ bas_notify(); /* Vendor indication simulation */ if (simulate_vnd && vnd_ind_attr) { if (indicating) { continue; } ind_params.attr = vnd_ind_attr; ind_params.func = indicate_cb; ind_params.destroy = indicate_destroy; ind_params.data = &indicating; ind_params.len = sizeof(indicating); if (bt_gatt_indicate(NULL, &ind_params) == 0) { indicating = 1U; } } } }
The github workflow is below:
name: Build and Release on: push: paths: - "**.c" - "**.h" - "**.feature" - "Kconfig" - ".github/workflows/build-and-release.yaml" - "west.yml" - "*.conf" repository_dispatch: types: - source-update workflow_dispatch: permissions: id-token: write contents: write issues: write jobs: build: runs-on: ubuntu-22.04 environment: name: production strategy: matrix: board: [nrf52840dk_nrf52840] loglevel: [debug] steps: - uses: actions/checkout@v3 with: path: firmware - name: Build with debug enabled working-directory: firmware if: matrix.loglevel == 'debug' run: | docker run --rm -v ${PWD}:/workdir/project nordicplayground/nrfconnect-sdk:main west build -p always -b ${{ matrix.board }} --build-dir /workdir/project/build - name: Copy firmware working-directory: firmware run: | cp build/zephyr/merged.hex ../ cp build/zephyr/app_signed.hex ../ cp build/zephyr/app_update.bin ../ cp firmware.conf ../ - uses: actions/upload-artifact@v3 with: if-no-files-found: error name: ${{ matrix.board }}-${{ matrix.loglevel }}-${{ needs.date-string.outputs.dateAsString }}-${{ github.sha }} path: | merged.hex app_signed.hex app_update.bin firmware.conf
I also committed a copy with the DFU disabled so you can see that it builds fine without DFU and fails with:
without DFU: https://github.com/Robert-PillConnect/peripheral/actions/runs/4730783013/jobs/8394934571 (note there's an error it can't find the output file but the build runs fine)
With DFU: https://github.com/Robert-PillConnect/peripheral/actions/runs/4730759754/jobs/8394868103
Here's the log from the failed docker build:
Run docker run --rm -v ${PWD}:/workdir/project nordicplayground/nrfconnect-sdk:main west build -p always -b nrf52840dk_nrf52840 --build-dir /workdir/project/build Unable to find image 'nordicplayground/nrfconnect-sdk:main' locally main: Pulling from nordicplayground/nrfconnect-sdk 2ab09b027e7f: Already exists 521a4cda3a3c: Pulling fs layer 15a79ec269fc: Pulling fs layer 9ef436cfd470: Pulling fs layer 7da6860ce4d6: Pulling fs layer 7da6860ce4d6: Waiting 521a4cda3a3c: Download complete 521a4cda3a3c: Pull complete 7da6860ce4d6: Verifying Checksum 7da6860ce4d6: Download complete 15a79ec269fc: Verifying Checksum 15a79ec269fc: Download complete 9ef436cfd470: Verifying Checksum 9ef436cfd470: Download complete 15a79ec269fc: Pull complete 9ef436cfd470: Pull complete 7da6860ce4d6: Pull complete Digest: sha256:d35dccc25d809552ea5dc81ad4a2a8dfd7950415ca84220615050dfadcccce1b Status: Downloaded newer image for nordicplayground/nrfconnect-sdk:main -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /workdir/project -- CMake version: 3.26.3 -- Found Python3: /usr/bin/python3.10 (found suitable exact version "3.10.6") found components: Interpreter -- Cache files will be written to: /workdir/.cache//zephyr -- Zephyr version: 3.3.99 (/workdir/zephyr) -- Found west (found suitable version "1.0.0", minimum required is "0.7.1") -- Board: nrf52840dk_nrf52840 -- Found host-tools: zephyr 0.15.2 (/workdir/zephyr-sdk) -- Found toolchain: zephyr 0.15.2 (/workdir/zephyr-sdk) -- Found Dtc: /usr/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /workdir/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts -- Generated zephyr.dts: /workdir/project/build/zephyr/zephyr.dts -- Generated devicetree_generated.h: /workdir/project/build/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /workdir/project/build/zephyr/dts.cmake warning: MCUMGR (defined at subsys/mgmt/mcumgr/Kconfig:5) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: ZCBOR (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUMGR and/or look up MCUMGR in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: Experimental symbol BT_IAS is enabled. Parsing /workdir/zephyr/Kconfig /workdir/project/prj.conf:48: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_CMD_IMG_MGMT Loaded configuration '/workdir/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig' Merged configuration '/workdir/project/prj.conf' /workdir/project/prj.conf:49: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_CMD_OS_MGMT /workdir/project/prj.conf:50: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_CMD_STAT_MGMT /workdir/project/prj.conf:57: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_SMP_BT /workdir/project/prj.conf:58: warning: attempt to assign the value 'n' to the undefined symbol MCUMGR_SMP_BT_AUTHEN /workdir/project/prj.conf:59: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_SMP_SHELL error: Aborting due to Kconfig warnings CMake Error at /workdir/zephyr/cmake/modules/kconfig.cmake:329 (message): command failed with return code: 1 Call Stack (most recent call first): /workdir/nrf/cmake/modules/kconfig.cmake:29 (include) /workdir/zephyr/cmake/modules/zephyr_default.cmake:113 (include) /workdir/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /workdir/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:4 (find_package) -- Configuring incomplete, errors occurred! FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/workdir/project/build -GNinja -DBOARD=nrf52840dk_nrf52840 -S/workdir/project Error: Process completed with exit code 1.
Any idea why this is failing?
