High power consumption in deep sleep mode in nRF5340
I am trying to put the nRF5340 to deep sleep, my application is built with TF-M (_ns).
When tested with the sample system_off application (built without TF-M) I observe 0.25uA.
If I integrate the same into my project, I observe 0.25mA. I assume the device is not entering to deep sleep, am I missing any configuration here? or why I am observing this huge difference?
Below is the prj.conf file used in my project.
CONFIG_BUILD_WITH_TFM=y
CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
CONFIG_TFM_IPC=y
CONFIG_NRF_SPIM3_SECURE=y
CONFIG_NRF_TWIM2_SECURE=y
CONFIG_NRF_TIMER2_SECURE=y
CONFIG_NRF_PWM0_SECURE=y
CONFIG_NRF_TIMER1_SECURE=y
CONFIG_NRF_PWM1_SECURE=y
CONFIG_NRF_GPIOTE0_SECURE=y
CONFIG_ADC=y
CONFIG_PM=y
CONFIG_PM_DEVICE=y
Below is the code snippet of how I am putting the device to deep sleep in non-secure.
pm_state_force(0u, &(struct pm_state_info){PM_STATE_SOFT_OFF, 0, 0});
Please guide me through this
Thank you in advance.
  • Would you mind trying to debug the system_off sample to see if the breakpoint gets reached then?
    [AJ]--> We confirm it is coming to the breakpoint when we debug system_off sample.
    Below are our additional findings:
    Example: system_off
    • Board: nrf5340dk_nrf5340_cpuapp
    • Power consumption at idle: 0.6uA
    • Board: nrf5340dk_nrf5340_cpuapp_ns
    Example: TF-M secure peripheral partition
    • Power consumption at idle: 0.21mA
    • No changes made to the example except put the device into sleep mode as in system_off example and we observe it is taking very high power in idle state.
    We want to know why this huge difference in the power consumption.
    NOTE: All the above are tested with nRF5340-dk
  • Is it the TF-M secure peripheral partition from SDK v2.3.0? I tried it here on a 5340 DK and I measure around 0.8uA in System OFF:
    Changes I made to force it to system OFF:
    --- a/src/main.c
    +++ b/src/main.c
    @@ -7,6 +7,9 @@
     #include <zephyr/kernel.h>
     #include <tfm_veneers.h>
     #include <tfm_ns_interface.h>
    +#include <zephyr/pm/pm.h>
    +#include <zephyr/pm/device.h>
    +#include <zephyr/pm/policy.h>
    --- a/prj.conf
    +++ b/prj.conf
    @@ -6,8 +6,14 @@
     CONFIG_TFM_ISOLATION_LEVEL=1
    +CONFIG_PM=y
    +# Required to disable default behavior of deep sleep on timeout
    +CONFIG_PM_DEVICE=y
     #include "secure_peripheral_partition.h"
    @@ -63,4 +66,5 @@ void main(void)
     	k_work_init_delayable(&send_work, send);
     	k_work_schedule(&send_work, K_NO_WAIT);
    +	pm_state_force(0u, &(struct pm_state_info){PM_STATE_SOFT_OFF, 0, 0});
  • Thank you for quick response.
    I am using v2.2.0 toolchain, let me update the toolchain and get back to you with my findings.
  • We try programming TF-M secure peripheral partition sample application build with v2.3.0 toolchain and confirm we are getting 0.6uA during deep sleep.
    We are working on some changes in our project, let me test and get back to you.
    Thank you.
