nRF Connect SDK v2.3.0 for VS code setting
Hi Team,
I cannot build sample code (like a LED Button Service (LBS)) with nRF Connect SDK v2.3.0 for VS code setting.
And I found "west" error by debugging comment. Refer to attachment image.
Please let us know how to solve this problem.
Best Regards,
Tsutsumi
    > And when you select the application name as "blinky",  do you see the sample, as follows:
    No, as following.
    >Also, Do you open the VSCode via Toolchain Manager?
    Yes, as following.
    > And do you have the latest nRF command line tools installed?
    Yes, as following.
    Best Regards,
    Tsutsumi
  • Could you attach the "Support Information" here?
    You can get this by selecting the "Generate Support Information" option.
    -Priyanka
    Please refer to following.
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.18362",
        "vscode": "1.77.3",
        "electron": "19.1.11",
        "node": "v16.14.2"
      "system": {
        "date": "2023-04-21T10:36:22.621Z",
        "vscodeRoot": "c:\\Users\\hkt11068\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "00:01:51",
        "osUptime": "26:26:16",
        "cpu": {
          "model": "Intel(R) Core(TM) i5-8365U CPU @ 1.60GHz",
          "speed": "1896 MHz",
          "count": 4
        "memory": {
          "total": "7.82 GB",
          "free": "0.38 GB"
      "workspace": {
        "name": "test_1",
        "workspaceFile": null,
        "folders": [
          "c:\\ncs\\myapps\\test_1"
      "extensions": {
        "internal": {
            "version": "2023.2.56",
            "path": "c:\\Users\\hkt11068\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.2.56-win32-x64",
            "isActive": true
            "version": "2022.11.29",
            "path": "c:\\Users\\hkt11068\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.11.29",
            "isActive": true
            "version": "2022.11.153",
            "path": "c:\\Users\\hkt11068\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2022.11.153",
            "isActive": true
            "version": "2022.11.50",
            "path": "c:\\Users\\hkt11068\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2022.11.50",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.10.0",
          "ms-vscode.cpptools": "1.14.5",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.19",
          "ms-vscode.js-debug": "1.77.2",
          "ms-vscode.js-debug-companion": "1.0.18",
          "ms-vscode.vscode-js-profile-table": "1.0.3",
          "cschlosser.doxdocgen": "1.4.0",
          "jeff-hykin.better-cpp-syntax": "1.17.2",
          "josetr.cmake-language-support-vscode": "0.0.9",
          "mcu-debug.debug-tracker-vscode": "0.0.15",
          "mcu-debug.memory-view": "0.0.20",
          "mcu-debug.rtos-views": "0.0.6",
          "ms-dotnettools.vscode-dotnet-runtime": "1.6.0",
          "ms-vscode-remote.remote-containers": "0.288.1",
          "ms-vscode-remote.remote-ssh": "0.100.0",
          "ms-vscode-remote.remote-ssh-edit": "0.84.0",
          "ms-vscode-remote.remote-wsl": "0.77.0",
          "ms-vscode.cmake-tools": "1.14.30",
          "ms-vscode.remote-explorer": "0.4.0",
          "trond-snekvik.kconfig-lang": "1.2.0",
          "twxs.cmake": "0.0.17"
      "tools": {
        "c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.15.2",
        "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink.exe": "7.86e",
        "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.21.0",
        "nrfutil": "Not found",
        "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\cmake.exe": "3.20.5",
        "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\Scripts\\west.exe": "0.14.0",
        "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\python.exe": "3.8.2",
        "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\ninja.exe": "1.9.0",
        "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\gperf.exe": "3.1",
        "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\dtc.exe": "1.4.7",
        "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\gn.exe": "2082",
        "c:\\ncs\\toolchains\\v2.3.0\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
        "gdbPath": "c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
      "sdks": [],
      "toolchains": [
          "version": "2.3.0",
          "path": "c:\\ncs\\toolchains\\v2.3.0"
      "connectedDevices": [],
      "deviceProviders": [
        "nrfjprog"
      "config": {
          "topdir": "c:\\ncs\\v2.3.0",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.3.0}"
          "ozonePath": "",
          "applications": [
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig",
            "executeInDefaultShell": false
          "welcome": {
            "showOnStartup": true
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "enableTelemetry": true,
          "taskBindings": {},
          "debugging": {
            "backend": "nRF Debug",
            "flash": true,
            "bindings": {}
          "activeAppFollowActiveEditor": true
          "terminalMode": "character",
          "scrollBack": 1000
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "west",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\hkt11068",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\hkt11068",
          "Path": "c:\\ncs\\toolchains\\v2.3.0\\mingw64\\bin;c:\\ncs\\toolchains\\v2.3.0\\mingw64\\libexec\\git-core;c:\\ncs\\toolchains\\v2.3.0\\opt\\bin;c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.3.0\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\Scripts;C:\\Program Files (x86)\\STMicroelectronics\\st_toolset\\asm;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Program Files (x86)\\Gpg4win\\..\\GnuPG\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\hkt11068\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\EmEditor;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM8;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM32;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "ZEPHYR_BASE": "c:\\ncs\\v2.3.0\\zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk",
          "PYTHONPATH": "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin;c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\Lib;c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Program Files (x86)\\STMicroelectronics\\st_toolset\\asm;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Program Files (x86)\\Gpg4win\\..\\GnuPG\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\hkt11068\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\EmEditor;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM8;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM32;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "PATH": "C:\\Program Files (x86)\\STMicroelectronics\\st_toolset\\asm;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Program Files (x86)\\Gpg4win\\..\\GnuPG\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\hkt11068\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\EmEditor;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM8;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM32;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
        "toolchainPath": "c:\\ncs\\toolchains\\v2.3.0",
        "toolchainBinPath": "c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
        "toolchainVersion": "2.3.0"
      "terminal": {
        "shell": null,
        "defaultProfile": null
      "platform": {
        "os": "win32",
        "vscode": "1.77.3",
        "node": "v16.14.2"
      "system": {
        "date": "2023-04-21T10:36:40.043Z",
        "vscodeUptime": "00:02:09",
        "osUptime": "26:26:33",
        "cpu": {
          "count": 4
        "memory": {
          "total": "7.82 GB",
          "free": "0.63 GB"
      "workspace": {
        "name": "test_1",
        "folders": [
      "extensions": {
        "internal": {
            "isActive": true
            "isActive": true
            "isActive": true
            "isActive": true
        "external": {
      "tools": {
      "sdks": [],
      "toolchains": [
          "version": "2.3.0",
        "nrfjprog"
      "config": {
          "toolchain": {
          "ozonePath": "",
          "applications": [
          "kconfig": {
          "welcome": {
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "debugging": {
            "flash": true,
            "bindings": {}
          "scrollBack": 1000
          "gdbPath": null,
          "pyocdPath": null,
          "stutilPath": null,
          "stlinkPath": null,
      "environment": {
        "westExe": "west",
        "westEnv": {
          "HOMEDRIVE": "C:",
        "inherited": {
          "HOMEDRIVE": "C:",
      "terminal": {
        "shell": null,
    Best Regards,
    Tsutsumi
  • Could you try to "Updat SDK" here:
    Just in case you have a broken SDK, maybe this can help fix it.You can also turn on the logs to see if it's successfully finished.
    -Priyanka
    It's finished successfully finished.
    But the build issue still occerend.
    The following is after "update SDK".
      "platform": {
        "os": "win32",
        "vscode": "1.77.3",
        "node": "v16.14.2"
      "system": {
        "date": "2023-04-21T11:37:17.814Z",
        "vscodeUptime": "00:03:12",
        "osUptime": "27:27:11",
        "cpu": {
          "count": 4
        "memory": {
          "total": "7.82 GB",
          "free": "0.54 GB"
      "workspace": {
        "name": "test_1",
        "folders": [
      "extensions": {
        "internal": {
            "isActive": true
            "isActive": true
            "isActive": true
            "isActive": true
        "external": {
      "tools": {
      "sdks": [],
      "toolchains": [
          "version": "2.3.0",
        "nrfjprog"
      "config": {
          "toolchain": {
          "ozonePath": "",
          "applications": [
          "kconfig": {
          "welcome": {
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "debugging": {
            "flash": true,
            "bindings": {}
          "scrollBack": 1000
          "gdbPath": null,
          "pyocdPath": null,
          "stutilPath": null,
          "stlinkPath": null,
      "environment": {
        "westExe": "west",
        "westEnv": {
          "HOMEDRIVE": "C:",
        "inherited": {
          "HOMEDRIVE": "C:",
      "terminal": {
        "shell": null,
    Best Regards,
    Tsutsumi
