nRF Connect SDK v2.3.0 for VS code setting
Hi Team,
I cannot build sample code (like a LED Button Service (LBS)) with nRF Connect SDK v2.3.0 for VS code setting.
And I found "west" error by debugging comment. Refer to attachment image.
Please let us know how to solve this problem.
Best Regards,
Tsutsumi
  • I have reported this internally and will get back to you as soon as I get a response.
    -Priyanka
  • It looks like your SDK is not being installed correctly.
    You can try to open Toolchina Manager, go to the terminal and execute the command "west update" on the SDK directory.
    After that, try to build the code again.
    There was no "west build" tool before "west update":
    After "west update", there are more commands including "west build":
    Thank you for your information.
    Unfortunatly, I reinstalled my development environment and the situation is worse than last time.
    support information is following.
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at devzone.nordicsemi.com/.
    "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro",
    "osKernel": "10.0.18362",
    "vscode": "1.77.3",
    "electron": "19.1.11",
    "node": "v16.14.2"
    "system": {
    "date": "2023-04-26T06:27:46.172Z",
    "vscodeRoot": "c:\\Users\\hkt11068\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:01:20",
    "osUptime": "05:41:51",
    "cpu": {
    "model": "Intel(R) Core(TM) i5-8365U CPU @ 1.60GHz",
    "speed": "1896 MHz",
    "count": 4
    "memory": {
    "total": "7.82 GB",
    "free": "0.62 GB"
    "workspace": {
    "name": "Untitled (Workspace)",
    "workspaceFile": "1682390291194",
    "folders": [
    "c:\\nordic\\myapps\\peripheral_lbs"
    "extensions": {
    "internal": {
    "version": "2023.4.179",
    "path": "c:\\Users\\hkt11068\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.4.179-win32-x64",
    "isActive": true
    "version": "2023.4.15",
    "path": "c:\\Users\\hkt11068\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2023.4.15",
    "isActive": true
    "version": "2023.4.61",
    "path": "c:\\Users\\hkt11068\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2023.4.61",
    "isActive": true
    "version": "2023.4.17",
    "path": "c:\\Users\\hkt11068\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2023.4.17",
    "isActive": true
    "external": {
    "marus25.cortex-debug": "1.10.0",
    "ms-vscode.cpptools": "1.14.5",
    "ms-vscode-remote.remote-wsl-recommender": "0.0.19",
    "ms-vscode.js-debug": "1.77.2",
    "ms-vscode.js-debug-companion": "1.0.18",
    "ms-vscode.vscode-js-profile-table": "1.0.3",
    "cschlosser.doxdocgen": "1.4.0",
    "endercat.one-dark-github": "0.0.1",
    "jeff-hykin.better-cpp-syntax": "1.17.2",
    "josetr.cmake-language-support-vscode": "0.0.9",
    "luveti.kconfig": "1.0.3",
    "mcu-debug.debug-tracker-vscode": "0.0.15",
    "mcu-debug.memory-view": "0.0.20",
    "mcu-debug.rtos-views": "0.0.6",
    "ms-dotnettools.vscode-dotnet-runtime": "1.6.0",
    "ms-vscode-remote.remote-containers": "0.288.1",
    "ms-vscode-remote.remote-ssh": "0.100.0",
    "ms-vscode-remote.remote-ssh-edit": "0.84.0",
    "ms-vscode-remote.remote-wsl": "0.77.0",
    "ms-vscode.cmake-tools": "1.14.30",
    "ms-vscode.remote-explorer": "0.4.0",
    "trond-snekvik.kconfig-lang": "1.2.0",
    "twxs.cmake": "0.0.17"
    "tools": {
    "c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.15.2",
    "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.86h",
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.21.0",
    "nrfutil": "Not found",
    "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\cmake.exe": "3.20.5",
    "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\Scripts\\west.exe": "0.14.0",
    "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\python.exe": "3.8.2",
    "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\ninja.exe": "1.9.0",
    "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\gperf.exe": "3.1",
    "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\dtc.exe": "1.4.7",
    "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\gn.exe": "2082",
    "c:\\ncs\\toolchains\\v2.3.0\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "gdbPath": "c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
    "sdks": [],
    "toolchains": [
    "version": "2.3.0",
    "path": "c:\\ncs\\toolchains\\v2.3.0"
    "connectedDevices": [],
    "deviceProvider": "nrfutil",
    "config": {
    "topdir": "c:\\ncs\\v2.3.0",
    "toolchain": {
    "path": "${nrf-connect.toolchain:2.3.0}"
    "ozonePath": "",
    "applications": [
    "${workspaceFolder}"
    "applicationOptions": {},
    "kconfig": {
    "interface": "kconfig",
    "executeInDefaultShell": false
    "welcome": {
    "showOnStartup": true
    "west": {
    "env": {
    "$base": "terminal"
    "boardRoots": [],
    "enableTelemetry": true,
    "taskBindings": {},
    "debugging": {
    "backend": "nRF Debug",
    "flash": true,
    "bindings": {}
    "terminalMode": "character"
    "marus25.cortex-debug": {
    "armToolchainPath": null,
    "armToolchainPrefix": "arm-none-eabi",
    "gdbPath": null,
    "objdumpPath": null,
    "JLinkGDBServerPath": null,
    "openocdPath": null,
    "pyocdPath": null,
    "PEGDBServerPath": null,
    "stutilPath": null,
    "stlinkPath": null,
    "stm32cubeprogrammer": null,
    "registerUseNaturalFormat": true,
    "variableUseNaturalFormat": true,
    "dbgServerLogfile": null,
    "showDevDebugOutput": "none"
    "environment": {
    "westExe": "west",
    "westEnv": {
    "ELECTRON_RUN_AS_NODE": "1",
    "HOME": "C:\\Users\\hkt11068",
    "HOMEDRIVE": "C:",
    "HOMEPATH": "\\Users\\hkt11068",
    "Path": "c:\\ncs\\toolchains\\v2.3.0\\mingw64\\bin;c:\\ncs\\toolchains\\v2.3.0\\mingw64\\libexec\\git-core;c:\\ncs\\toolchains\\v2.3.0\\opt\\bin;c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.3.0\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\Scripts;C:\\Program Files (x86)\\STMicroelectronics\\st_toolset\\asm;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files (x86)\\Gpg4win\\..\\GnuPG\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\hkt11068\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\EmEditor;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM8;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM32;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
    "ZEPHYR_SDK_INSTALL_DIR": "c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk",
    "PYTHONPATH": "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin;c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\Lib;c:\\ncs\\toolchains\\v2.3.0\\opt\\bin\\Lib\\site-packages",
    "Python3_ROOT": "c:\\ncs\\toolchains\\v2.3.0\\opt\\bin"
    "inherited": {
    "HOMEDRIVE": "C:",
    "Path": "C:\\Program Files (x86)\\STMicroelectronics\\st_toolset\\asm;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files (x86)\\Gpg4win\\..\\GnuPG\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\hkt11068\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\EmEditor;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM8;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM32;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
    "PATH": "C:\\Program Files (x86)\\STMicroelectronics\\st_toolset\\asm;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files (x86)\\Gpg4win\\..\\GnuPG\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\hkt11068\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\EmEditor;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM8;C:\\Program Files (x86)\\COSMIC\\FSE_Compilers\\CXSTM32;C:\\Users\\hkt11068\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
    "toolchainPath": "c:\\ncs\\toolchains\\v2.3.0",
    "toolchainBinPath": "c:\\ncs\\toolchains\\v2.3.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
    "toolchainVersion": "2.3.0"
    "terminal": {
    "shell": null,
    "defaultProfile": null
    Best Regars,
    Tsutsumi
    I found one thing.
    I cannot build "Freestanding" but I can build "Workspace" when Create a new application.
    I think my environment has not nRF Connect SDK repository.
    Please let me know how to install nRF Connect SDK repository to my environment.
    Best Regards,
    Tsutsumi
    Your workspace seems to be under a different path than your SDK installation:
    THis is your SDK installation path:
    Please check your installation path from here:
    And try to bring your workspace, sdk etc everything under the same path.
    -Priyanka
