BLE FOTA (SMP) on nRF52840 connected to Gateway via Azure IotHub
I am looking for information on how write a custom SMP client implementation for doing FOTA on a nrf52840 using BLE. I cant use the mcumgr CLI tool as my BLE device is connected to a thirdparty gateway and I only communicate with my BLE device through Azure IotHub using a custom API.
Here is a simple flow chart of my setup:
 | BLE device | <--> | Gateway | <--> | Azure IotHub | <--> | C# FOTA application |
I can do FOTA using the nRF app so my SMP server implementation is working.
Can you point me in the right direction?
SDK: nRF Connect v 2.1.0
Thank you
    We do not have any SMP client implementation for doing DFU from other devices so that is something that is up to you, and also the cloud part. I don't know anything about your Gateway, but it would make sense to see if you can use mcumgr on it, or some other SMP server implementation with image management support.
  • Thanks for the answer. I´m trying to write my own SMP client implementation. I have a couple of issues that you might be able to help me with.
    Prerequisites: BLE device is connected and is setup to support SMP. I have verified OTA transfer in the nRF iOS app.
    Next step is to prepare my signed firmware file for uploading. Each packet has an 8 byte SMP header that looks like this:
       (byte)  2 //Op code MGMT_OP_WRITE,
       (byte) 0 // Flags, always 0,
      (uint16) (n) //Data length,depends on mtu size and payload
      (uint16) 1 // image management group
      (byte) (n) // Sequence, is increment +1 for each packet
      (byte) 1 // Image group command ImageUpload
    After that the CBOR data is added to this packet. The first CBOR packet looks like this:
      "image": 1, // the not active image on my ble device
      "len": (n), // total size of my firmware binary
      "sha": (n), //sha 256 on the fw binary
      "upgrade": false,
      "off": 0
      "data": (n) contains as much data as I can fit within the CBOR. In first packet this is 160 bytes
    After sending this packet to the device I get this response:
    SMP header:
    OpCode: MgmtOpWriteRsp (3)
        DataLength: 12
        GroupId: IMAGE group
        Sequence: 0
        CommandId: 1
    CBOR:
    {"rc": 0, "off": 160}
    I then continue sending the next packet with offset 160 that looks like this (it has the same SMP header as the first one):
      "off": 160,
      "data": (n), // in this case it´s 222 bytes
    After this I dont get any response from the device. I continue sending packets and after around 4 packets i receive the initial packet once again {"rc": 0, "off": 160}.
    I have´nt been able to figure this out. Maybe you see something obvious i´m doing wrong, or maybe you have an idea of where to look for issues?
    Thanks
    I don't see anything obvious. Perhaps you can log or sniff the data and compare the traces from your implementation with a reference implementation and see where there are differences so know were to look closer?
