nrf5340 data length extension
hello, i'm using nrf connect sdk version 2.3, and nrf5340dk board.
1. i want ble data length extension, so i am using this function after connected call back ,in central uart example project
static int connection_configuration_set()
	int err;
	struct bt_le_conn_param* conn_param;
	struct bt_conn_le_phy_param phy;
	struct bt_conn_le_data_len_param data_len;
	conn_param = BT_LE_CONN_PARAM(INTERVAL_MIN, INTERVAL_MAX, 0, 400);
	phy.pref_tx_phy = BT_GAP_LE_PHY_2M;
	phy.pref_rx_phy = BT_GAP_LE_PHY_2M;
	data_len.tx_max_len 	= 251;
	data_len.tx_max_time 	= 2120;
	err = bt_conn_le_phy_update(default_conn, &phy);
	if (err) {
		printk("PHY update failed: %d\n", err);
		return err;
	printk("PHY update pending");
	err = k_sem_take(&throughput_sem, THROUGHPUT_CONFIG_TIMEOUT);
	if (err) {
		printk("PHY update timeout");
		return err;
	data_length_req = true;
	err = bt_conn_le_data_len_update(default_conn, &data_len);
	if (err) {
		printk("LE data length update failed: %d",
				err);
		return err;
	printk("LE Data length update pending");
	if (err) {
		printk("LE Data Length update timeout");
		return err;
	err = bt_conn_le_param_update(default_conn, conn_param);
	if (err) {
		printk(
				"Connection parameters update failed: %d",
				err);
		return err;
	printk("Connection parameters update pending");
	if (err) {
		printk("Connection parameters update timeout");
		return err;
	return 0;
but le_data_length_updated print that log:
it looks like data length not updated, so i have question for update data length
how can i set 251 byte ble data length
this is my prj.conf
central uart prj.conf
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
# Enable the BLE stack with GATT Client configuration
CONFIG_BT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_CLIENT=y
# Enable the BLE modules from NCS
CONFIG_BT_NUS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_GATT_DM=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
CONFIG_BT_L2CAP_TX_MTU=247
#CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
# This example requires more workqueue stack
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=n
CONFIG_ASSERT=y
central uart child_image/rpc_host.conf
# Copyright (c) 2021 Nordic Semiconductor
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=n
CONFIG_BT_CENTRAL=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_DEVICE_NAME="Zephyr"
CONFIG_BT_SMP=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_GATT_DM_DATA_PRINT=y
CONFIG_SETTINGS=y
CONFIG_NRF_RPC_THREAD_STACK_SIZE=2048
CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
peripheral uart prj.conf
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# Config logger
CONFIG_LOG=y
CONFIG_LOG_PRINTK=n
CONFIG_ASSERT=y
CONFIG_SPI=y
CONFIG_SPI_ASYNC=y
CONFIG_SPI_SLAVE=y
peripheral uart project no child_image/rpc_host.conf
